Improve Your Wyze Cam Setup with the 20ft USB Extension Cable
If you're looking to enhance your Wyze Cam's vantage point and flexibility, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This extended USB cable allows you to position your Wyze Cam further away from power outlets, giving you more freedom to monitor hard-to-reach or distant areas without compromising on power supply.
Why Choose the Wyze Cam USB Extension Cable?
- Length: 20 feet of cable length provides ample reach for indoor or outdoor setups.
- Compatibility: Works seamlessly with a wide range of Wyze cameras including Wyze Cam OG, Wyze Cam v2/v3/v4, Wyze Cam Pan v2/v3, and Wyze Cam OG Telephoto.
- Durability: Rated IP67 for weather resistance, this cable can withstand outdoor conditions from -30°C to 50°C (-22°F to 122°F).
- Power Output: Supports 5V 2A power delivery ensuring your camera runs smoothly without power drops.
- Connector Type: USB Type A Male to Female for easy plug-and-play connection.
With this cable, you can place your Wyze Cam in the ideal location for maximum coverage, whether it's high on a wall, tucked away in a corner, or mounted outside where power outlets are scarce.
Wyze Cam OG – Enhanced Coverage with Built-In Spotlight
The
Wyze Cam OG is a versatile wired camera designed for both indoor and outdoor use. When paired with the 20ft USB extension cable, you can position it exactly where you need it without worrying about proximity to power sources.
Key Features of Wyze Cam OG
- 120° Field of View: Capture a wide area with a broad viewing angle.
- Built-In Spotlight & Mini-Siren: Deter intruders with a 40-lumen spotlight and a 90-decibel siren.
- 3x Faster Notifications: Stay informed instantly with rapid motion alerts.
- Upgraded Two-Way Audio: Clear communication with enhanced microphone and speaker.
- Weatherproof: IP65 rating means it can handle rain and harsh weather conditions.
- Local Storage Support: Compatible with Wyze microSD cards up to 256GB for continuous recording.
Using the USB extension cable, you can mount the Wyze Cam OG in optimal outdoor locations, such as under eaves or on exterior walls, ensuring your home is protected with a clear, wide-angle view.
Wyze Battery Cam Pro – Wireless Freedom with Pro-Grade Features
For those who prefer a wire-free security solution, the
Wyze Battery Cam Pro offers exceptional flexibility and performance. While it operates on rechargeable batteries, pairing it with accessories like the USB extension cable (for compatible models) or solar panels can extend its uptime and placement options.
Highlights of Wyze Battery Cam Pro
- 2.5K HDR Video Resolution: Crystal-clear video quality with high dynamic range.
- Integrated Spotlight & Siren: 150 lumens of LED light and a siren to alert intruders.
- Radar + PIR Motion Detection: Dual sensors for precise and early motion alerts.
- Removable Rechargeable Batteries: Hot-swap batteries to avoid downtime.
- IP65 Weatherproof: Built to withstand outdoor elements.
- Dual-Band WiFi Support: Connects to both 2.4GHz and 5GHz networks for stable streaming.
- Local Recording: Supports microSD cards for local event storage without subscription.
While the Battery Cam Pro is designed to be wire-free, using a USB extension cable can be helpful when charging or powering the camera in fixed locations, especially if you want to avoid frequent battery swaps.
Maximize Your Wyze Cam Experience
By combining the
Wyze Cam USB Extension Cable - 20ft with your Wyze cameras, you unlock new possibilities for camera placement and security coverage. Whether you have the wired
Wyze Cam OG or the wireless
Wyze Battery Cam Pro, this cable ensures your camera stays powered without limiting your installation options.
"Extend your camera’s reach and power with the Wyze 20ft USB extension cable — perfect for improved vantage points and flexible setups."
Enhance your home security with flexible camera placement using extended USB cables.
Wyze Cam OG’s built-in spotlight ensures clear night vision and deterrence.
Wireless freedom with Wyze Battery Cam Pro, ideal for versatile outdoor monitoring.
Summary of Products for Improved Wyze Cam Setup
Extend your camera’s power reach with a durable, weather-resistant 20ft USB cable compatible with multiple Wyze Cam models.
Wyze Cam OG
Wired camera with wide 120° field of view, built-in spotlight, siren, and fast notifications, perfect for indoor/outdoor use.
Wireless, weatherproof camera with 2.5K HDR video, integrated spotlight, dual motion sensors, and rechargeable batteries for flexible placement.
Enhance your home security system today by combining these products for the ultimate in coverage, convenience, and peace of mind.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera further from power outlets. This provides greater flexibility for indoor and outdoor camera placement without compromising on power supply.Which Wyze Cam models are compatible with the 20ft USB extension cable?
The 20ft USB extension cable is compatible with a wide range of Wyze cameras, including Wyze Cam OG, Wyze Cam v2, v3, v4, Wyze Cam Pan v2, v3, and Wyze Cam OG Telephoto.Is the Wyze Cam USB Extension Cable weatherproof?
Yes, the Wyze Cam USB Extension Cable is rated IP67 for weather resistance, making it suitable for outdoor use in temperatures ranging from -30°C to 50°C (-22°F to 122°F).What type of connector does the Wyze Cam USB Extension Cable use?
The cable features a USB Type A Male to Female connector, allowing for easy plug-and-play installation with your Wyze Cam.Does the Wyze Cam USB Extension Cable support sufficient power for my camera?
Yes, the cable supports 5V 2A power delivery, ensuring your Wyze Cam operates smoothly without power drops, even at extended distances.How does the Wyze Cam OG benefit from the 20ft USB extension cable?
Using the 20ft USB extension cable with the Wyze Cam OG allows you to mount the camera in optimal locations, such as high on walls or under eaves, without worrying about proximity to power sources. This maximizes your coverage and security.What are the key features of the Wyze Cam OG?
The Wyze Cam OG offers a 120° field of view, built-in 40-lumen spotlight, 90-decibel mini-siren, 3x faster notifications, upgraded two-way audio, IP65 weatherproof rating, and supports local storage with microSD cards up to 256GB.Can I use the USB extension cable with the Wyze Battery Cam Pro?
While the Wyze Battery Cam Pro is designed for wireless operation, the USB extension cable can be used for charging or powering the camera in fixed locations, which is helpful if you want to avoid frequent battery swaps.What are the main features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features 2.5K HDR video resolution, a 150-lumen integrated spotlight, siren, radar and PIR motion detection, removable rechargeable batteries, IP65 weatherproof rating, dual-band WiFi support, and local recording via microSD card.How can I maximize my Wyze Cam setup for better home security?
To maximize your Wyze Cam setup, use the 20ft USB extension cable to place your cameras in ideal locations for maximum coverage. Pairing the cable with Wyze Cam OG or using it for charging the Wyze Battery Cam Pro ensures your cameras stay powered and optimally positioned for enhanced security.
