Secure 20ft USB Power Extension for Wyze Cam Window Install
Secure Power Solutions for Wyze Cam Near Window Frames
When installing your Wyze Cam near a window frame, ensuring a secure and reliable power connection is essential for uninterrupted surveillance. Using the right accessories like a USB extension cable can provide the flexibility and safety needed to position your camera optimally without worrying about short cables or awkward power setups.
Wyze Cam v4: Advanced Security with Flexible Installation
The Wyze Cam v4 is a top choice for indoor and outdoor security, offering crystal-clear 2.5K QHD resolution and enhanced color night vision. Its compact design and multiple mounting options—including stand, wall mount, ceiling mount, and magnetic adhesive mounts—make it ideal for installation near window frames.
  • Video Quality: 2.5K Quad HD (2560x1440) for sharp, detailed footage.
  • Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs.
  • Connectivity: Supports Wi-Fi 6 for a stronger, more reliable connection.
  • Power: Comes with a 6-foot flat micro USB to USB-A cable.
  • Mounting: Magnetic and adhesive mounts allow easy placement on window frames or nearby walls.
  • Weather Resistance: Rated IP65, suitable for outdoor exposure near windows.
  • Smart Features: Motion and sound detection, smoke and CO alerts, Alexa and Google Assistant compatibility.
This camera’s wired power design ensures continuous recording, but when installed near a window frame, the standard 6-foot cable may not always reach your power source conveniently. This is where the Wyze Cam USB Extension Cable becomes invaluable.
"Wyze Cam v4 offers superb image clarity and versatile mounting options, perfect for window frame installations."
Wyze Cam v4 installed near a window frame
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach Safely
The Wyze Cam USB Extension Cable extends your camera’s power cable by 20 feet, providing the freedom to place your Wyze Cam exactly where you need it—even if the nearest power outlet is far from your window frame.
  • Length: 20 feet for maximum flexibility.
  • Compatibility: Works with Wyze Cam v2, v3, v4, Pan v2/v3, OG Standard, and OG Telephoto.
  • Durability: IP67 weather rating ensures the cable withstands outdoor conditions.
  • Connector Type: USB Type A Male to Female.
  • Cable Specs: AWG 18# wire, supports 5V 2A output power.
  • Operating Temperature: -30°C to 50°C (-22°F to 122°F), suitable for various climates.
  • Color: White to blend discreetly with most home exteriors.
Using this extension cable allows you to maintain a secure power connection without unsightly or unsafe cable stretching. It’s perfect for window frame installations where power outlets are not immediately adjacent.
"The 20ft USB extension cable ensures your Wyze Cam stays powered securely, no matter the distance."
Why Choose Wyze for Your Window Frame Security Setup?
Combining the Wyze Cam v4 with the 20ft USB extension cable creates a seamless, secure, and flexible home security solution. This setup is especially beneficial for window frame installations where power access can be limited or inconvenient.
  • Reliable Power: Continuous wired power with extended reach.
  • Enhanced Security: High-resolution video and color night vision capture every detail.
  • Easy Installation: Multiple mounting options and flexible cable length.
  • Smart Home Integration: Works with Alexa and Google Assistant for voice control.
  • Weatherproof: Both camera and cable are rated for outdoor use, ensuring durability.
"Secure your home with Wyze’s trusted camera and accessories designed for flexible, reliable installations."
Summary of Products for Secure Wyze Cam Window Installations
ProductKey FeaturesPrice
Wyze Cam v42.5K QHD, color night vision, Wi-Fi 6, IP65From $35.98
Wyze Cam USB Extension Cable20ft length, IP67 rated, USB Type A connectors$7.99
Enhance your Wyze Cam setup near window frames with these essential products to ensure your home security system is both effective and convenient.
Product Highlights
FeatureWyze Cam v4Wyze Cam USB Extension Cable - 20ft
TypeCameraAccessory
Price$35.98 (single pack)$7.99
Resolution2.5K QHD (2560x1440)N/A
Night VisionEnhanced Color Night VisionN/A
SpotlightMotion-activated spotlightN/A
AudioEnhanced Two-Way Talk, 99dB speaker, built-in sirenN/A
Recording24/7 local recording (microSD card required)N/A
Wi-Fi SupportWi-Fi 6, 2.4 GHz Wi-FiN/A
CompatibilityAlexa, Google Assistant, IFTTTCompatible with Wyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG Telephoto
Weather ResistanceIP65N/A
PowerWired (6-foot flat micro USB to USB-A cable included)N/A
Cable Length6 feet (included cable)20 feet USB extension cable
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic mountN/A
Bluetooth Version5.2N/A
Dimensions2in x 2in x 2 3/8inN/A
Weight0.49 lb (222 g)N/A
UseIndoor/Outdoor security cameraExtends USB cable length for Wyze cameras
Warranty1 Year30-day hassle-free returns
How do I securely power my Wyze Cam when installing it near a window frame?To securely power your Wyze Cam near a window frame, use the included 6-foot flat micro USB to USB-A cable or extend your reach with the Wyze Cam USB Extension Cable. The 20ft extension cable allows you to position your camera optimally without worrying about short cables or unsafe setups, ensuring a reliable and continuous power connection.
What are the benefits of using the Wyze Cam v4 for window frame security?The Wyze Cam v4 offers 2.5K QHD resolution for sharp video, enhanced color night vision, and multiple mounting options including magnetic and adhesive mounts. Its compact, weather-resistant design (IP65 rated) makes it ideal for both indoor and outdoor window frame installations, providing reliable surveillance and smart features like motion detection and voice assistant compatibility.
Is the Wyze Cam USB Extension Cable compatible with all Wyze cameras?The Wyze Cam USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Pan v2/v3, OG Standard, and OG Telephoto models. This ensures flexibility for various Wyze camera setups, especially when installing near window frames or in locations far from power outlets.
Can the Wyze Cam USB Extension Cable be used outdoors?Yes, the Wyze Cam USB Extension Cable is IP67 weather rated, making it suitable for outdoor use. It is designed to withstand harsh weather conditions, ensuring a secure and durable power connection for your Wyze Cam even when installed near exterior window frames.
What is the length and specification of the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long, providing maximum flexibility for camera placement. It features a USB Type A Male to Female connector, AWG 18# wire, and supports 5V 2A output power, making it ideal for extending your camera’s reach safely.
How does the Wyze Cam v4 perform in low light or at night?The Wyze Cam v4 is equipped with enhanced color night vision, featuring 4 IR LEDs and 2 white spotlight LEDs. This allows the camera to capture clear, detailed footage even in low-light conditions, making it perfect for nighttime surveillance near window frames.
Are the Wyze Cam v4 and USB Extension Cable weatherproof?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, and the Wyze Cam USB Extension Cable is rated IP67. Both are designed to withstand outdoor conditions, ensuring reliable operation and durability for window frame installations exposed to the elements.
What smart home features does the Wyze Cam v4 support?The Wyze Cam v4 supports motion and sound detection, smoke and CO alerts, and is compatible with Alexa and Google Assistant for convenient voice control and smart home integration.
Why should I use a USB extension cable for my Wyze Cam near a window?Using a USB extension cable allows you to place your Wyze Cam exactly where you need it, even if the nearest power outlet is far from your window frame. This ensures a secure, tidy, and safe power connection without stretching or straining cables.
What are the key products recommended for secure Wyze Cam window installations?For secure Wyze Cam window installations, it is recommended to use the Wyze Cam v4 for high-quality surveillance and the Wyze Cam USB Extension Cable (20ft) for flexible, reliable power connections. Both products are designed for easy installation and outdoor durability.
What are the key features of the Wyze Cam v4 that make it suitable for window frame installations?Can you explain how the Wyze Cam USB Extension Cable works with different Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam v4?
