Easy Install Wyze Cam Floodlight Cameras with Access Point
Easy Install Wyze Cam Floodlight Cameras with Access Point Feature
When it comes to securing your home with bright, intelligent lighting and crystal-clear video, Wyze offers a range of floodlight cameras designed for easy installation and smart home integration. Whether you want a straightforward hardwired solution or a plug-in mount for hassle-free setup without a junction box, Wyze has you covered. This page highlights the best Wyze Cam Floodlight options featuring easy installation and advanced access point capabilities to keep your property safe and well-lit.
Wyze Cam Floodlight v2: Bright, Smart, and Easy to Install
Powerful Lighting and Clear 2K Video
The Wyze Cam Floodlight v2 delivers an impressive 2800 lumens of dimmable LED light with a crisp 5000K color temperature, illuminating your outdoor spaces with vibrant clarity. Its 2K HD video resolution (2304 x 1296) combined with Color Night Vision and a wide 160° diagonal field of view ensures you never miss a detail, day or night.
Smart Features for Enhanced Security
  • AI-Powered Light Control automatically adjusts lighting based on motion and ambient conditions.
  • Two-way audio with built-in speaker and microphone lets you communicate directly through the camera.
  • 105dB siren to deter unwanted visitors.
  • Local storage support up to 256GB microSD card for continuous recording.
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
Easy Installation with Flexible Mounting
The Floodlight v2 supports both wall and ceiling mounts and is hardwired to standard 110-120V AC power. Its IP65 weather resistance rating means it’s built to withstand harsh outdoor conditions.
“Dominate the dark with smart lighting and 2K video clarity.”
Wyze Cam Floodlight v2 illuminating a driveway at night with person detected Alt text: Wyze Cam Floodlight v2 lighting driveway with motion detection
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Wide Coverage
Superior Video Quality and Wide-Angle View
Step up your security with the Wyze Cam Floodlight Pro, featuring 2.5K QHD video (2560 x 1440) and a massive 180° diagonal field of view. This camera captures your entire yard with stunning detail and vibrant color night vision.
Intelligent AI-Powered Lighting
  • Onboard AI computer vision detects people, vehicles, and other objects you select.
  • Adjustable 3,000 lumen LED lights activate only when needed, saving energy and reducing light pollution.
  • Dual-band WiFi (2.4 & 5 GHz) ensures stable connectivity and faster data transmission.
Robust Build and Easy Setup
Like the Floodlight v2, the Pro model is hardwired (110-120V AC) and weather-resistant with an IP65 rating. It supports up to 256GB microSD storage and integrates with Alexa, Google Assistant, and IFTTT.
“A personal home security guard with bright, smart lights.”
Wyze Cam Floodlight Pro mounted on a side door with woman and dog Alt text: Wyze Cam Floodlight Pro installed on home exterior with woman and dog
Plug-In Mount: Simplify Installation Without a Junction Box
Hassle-Free Plug-N-Play Solution
Say goodbye to complicated wiring and costly junction box installations. The Wyze Cam Floodlight Plug-In Mount offers a simple, plug-in power solution compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models.
Features and Benefits
  • 20-foot power cord with durable SJTW cable rated for outdoor use.
  • Easy mounting kit included with silicone ring, screws, foam tape, and quick start guide.
  • Operates safely in temperatures from -22°F to 122°F.
  • Certified for safety and environmental standards including UL153, RoHS, and CP65.
“Easy plug-in mount for any Wyze floodlight camera.”
Bundled Convenience: Wyze Cam Floodlight + Plug-In Mount
Ready-to-Go Security Bundle
For the ultimate easy install experience, consider the Wyze Cam Floodlight Pro + Plug-In Mount or the Wyze Cam Floodlight v2 + Plug-In Mount bundles. These packages combine the power and intelligence of Wyze’s top floodlight cameras with the convenience of plug-in installation.
Bundle Highlights
  • No junction box needed — just plug in and mount.
  • Includes all mounting hardware and a 20-foot power cord for flexible placement.
  • Same advanced camera features: 2K or 2.5K video, color night vision, AI motion detection, and smart assistant compatibility.
  • Weather-resistant and built to last in outdoor environments.
“Smart security made simple with bundled plug-in mounts.”
Outdoor evening scene with Wyze Cam Floodlight illuminating a deck Alt text: Wyze Cam Floodlight Pro lighting an outdoor deck at dusk
Why Choose Wyze Cam Floodlight Cameras with Access Point Feature?
Wyze floodlight cameras are designed for users who want powerful security lighting combined with easy installation and smart home connectivity. The access point feature in these cameras ensures reliable WiFi connection even in challenging outdoor environments, enhancing video streaming and alert responsiveness.
  • Flexible mounting options: wall or ceiling.
  • Plug-in mounts eliminate the need for electrical work.
  • AI-powered motion detection reduces false alerts.
  • Integration with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Durable IP65 weatherproof design for year-round protection.
Protect your home effortlessly with Wyze’s easy install floodlight cameras featuring advanced access point technology.
Summary of Wyze Cam Floodlight Products for Easy Installation
ProductVideo QualityLighting LumensInstallation TypeKey FeaturePrice (USD)
Wyze Cam Floodlight v22K HD2800Hardwired / Plug-InAI Light Control, 160° View89.98
Wyze Cam Floodlight Pro2.5K QHD3000Hardwired / Plug-InAI Object Detection, 180° View149.98
Wyze Cam Floodlight Plug-In MountN/AN/APlug-In Power CordEasy Plug-N-Play Installation19.98
Wyze Cam Floodlight Pro + Plug-In Mount2.5K QHD3000Plug-In BundleComplete Easy Install Solution169.96
Wyze Cam Floodlight v2 + Plug-In Mount2K HD2800Plug-In BundleFlexible Power & Mounting109.96
Enhance your home security with Wyze Cam Floodlight cameras that combine bright, intelligent lighting with easy installation options including plug-in mounts. Choose the model that fits your needs and enjoy peace of mind with smart, reliable outdoor surveillance.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
Price$89.98$169.96$109.96
Video Resolution2K HD2.5K QHD2K HD
Field of View160°180°160°
LED Brightness2800 lumens3000 lumens (3 adjustable panels)2800 lumens
Night VisionColor Night VisionColor Night VisionVibrant Color Night Vision
Motion Detection270° PIR motion detection areaAI computer vision with selectable object detectionAdvanced motion detection
Two-Way TalkYesYesYes
Siren105 dB105 dB105 dB
Local StoragemicroSD up to 256 GB (24/7 recording)microSD up to 256 GBmicroSD up to 256 GB
Cloud Storage & AI DetectionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Ambient Light ModeYesYesYes
Dusk-to-Dawn AutomationYesYesYes
Weather ResistanceIP65IP65IP65
Wi-Fi Compatibility2.4 GHzDual-band 2.4 & 5 GHz2.4 GHz
Power SupplyHardwired 110-120V ACHardwired 110-120V ACFlexible power solution with 20ft cable (plug-in mount)
Plug-In Mount IncludedNoYesYes
Plug-In Mount ColorsN/ABlack, WhiteBlack, White
InstallationRequires hardwired installationPlug-n-play with included plug-in mountPlug-n-play with included plug-in mount
Cable Length (Plug-In Mount)N/A20 ft20 ft
Cable ManagementN/AVelcro strap includedVelcro strap included
What are the installation options for Wyze Cam Floodlight cameras?Wyze Cam Floodlight cameras offer both hardwired and plug-in installation options. You can choose a traditional hardwired setup for a permanent solution or use the Wyze Cam Floodlight Plug-In Mount for easy, junction box-free installation. The plug-in mount comes with a 20-foot outdoor-rated power cord and all necessary mounting hardware.
Which Wyze Cam Floodlight models support plug-in installation?The Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models. You can purchase these cameras bundled with the plug-in mount for a hassle-free, no-junction-box installation.
What is the access point feature in Wyze Cam Floodlight cameras?The access point feature in Wyze Cam Floodlight cameras ensures a reliable WiFi connection, even in challenging outdoor environments. This enhances video streaming quality and alert responsiveness, making your home security system more dependable.
How bright are the Wyze Cam Floodlight v2 and Pro models?The Wyze Cam Floodlight v2 delivers 2800 lumens of dimmable LED light, while the Wyze Cam Floodlight Pro offers an even brighter 3000 lumens. Both models provide vibrant, clear illumination for your outdoor spaces.
What video quality do Wyze Cam Floodlight cameras offer?Wyze Cam Floodlight v2 features 2K HD video resolution (2304 x 1296), and the Wyze Cam Floodlight Pro offers 2.5K QHD video (2560 x 1440). Both models include color night vision and wide-angle views for comprehensive coverage.
Are Wyze Cam Floodlight cameras weatherproof?Yes, all Wyze Cam Floodlight cameras are rated IP65 for weather resistance, making them suitable for year-round outdoor use in various weather conditions.
Do Wyze Cam Floodlight cameras support smart home integration?Yes, Wyze Cam Floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration, voice control, and automation.
What AI-powered features are available in Wyze Cam Floodlight cameras?Wyze Cam Floodlight cameras offer AI-powered motion detection, including person and vehicle detection, as well as AI-powered light control that automatically adjusts lighting based on motion and ambient conditions. The Pro model features advanced onboard AI computer vision for object detection.
How much local storage do Wyze Cam Floodlight cameras support?Wyze Cam Floodlight v2 and Pro models support local storage with microSD cards up to 256GB, allowing for continuous video recording and playback.
What is included in the Wyze Cam Floodlight Plug-In Mount kit?The Wyze Cam Floodlight Plug-In Mount kit includes a 20-foot SJTW outdoor-rated power cord, a silicone ring, screws, foam tape, and a quick start guide for easy installation. The kit is certified for safety and environmental standards including UL153, RoHS, and CP65.
What are the benefits of purchasing a Wyze Cam Floodlight bundle with a plug-in mount?Wyze Cam Floodlight bundles with plug-in mounts provide a complete, easy-install solution. No junction box is needed—just plug in and mount. Bundles include all necessary hardware and offer the same advanced camera features, such as high-resolution video, color night vision, AI motion detection, and smart assistant compatibility.
Can Wyze Cam Floodlight cameras be mounted on both walls and ceilings?Yes, Wyze Cam Floodlight cameras support flexible mounting options, allowing installation on either walls or ceilings to best suit your security needs.
What are the key features of the Wyze Cam Floodlight v2?How does the AI-powered light control work in the Wyze Cam Floodlight cameras?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Floodlight cameras?
