Easy Security Installation Floodlight Camera with Velcro Cable Management
When it comes to securing your home with bright, reliable lighting and crystal-clear video, Wyze offers some of the best floodlight cameras on the market. If you're searching for an
easy-to-install floodlight camera with smart cable management, Wyze's lineup including the
Wyze Cam Floodlight v2,
Wyze Cam Floodlight Pro, and the
Wyze Cam Floodlight Plug-In Mount provide powerful security solutions that combine advanced features with hassle-free setup.
Wyze Cam Floodlight v2: Bright, Smart, and Easy to Install
The
Wyze Cam Floodlight v2 is designed to dominate the dark with its
2800 lumens of super-bright LED lighting and
2K HD video resolution. Its
160° wide-angle view ensures you capture a broad area with vivid color night vision, eliminating blind spots around your home.
Key Features:
- 2800 Lumens LEDs: Two dimmable LED panels provide bright, adjustable lighting to illuminate your yard or driveway.
- 2K Video with Color Night Vision: Capture clear, detailed footage day and night.
- Wide 160° Field of View: Covers a large area to keep your property safe.
- AI-Powered Light Control & Motion Detection: 270° PIR sensor detects motion up to 30 feet, triggering lights and alerts.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
- Two-Way Talk & 105dB Siren: Communicate with visitors or deter intruders instantly.
- Dusk-to-Dawn Automation & Ambient Light Mode: Automatically adjusts lighting based on time and motion.
- IP65 Weather Resistance: Built to withstand rain, snow, and extreme temperatures.
- Easy Setup with Access Point Feature: Connects via Wi-Fi hotspot for ladder-free installation.
Installation & Cable Management
While the Wyze Cam Floodlight v2 requires hardwiring, it supports
plug-in mount options for those without junction boxes, making installation simpler and more flexible.
Wyze Cam Floodlight v2 providing bright security lighting with two-way audio
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Wide Coverage
For those who want the ultimate in floodlight security, the
Wyze Cam Floodlight Pro offers a
180° ultra-wide field of view and
2.5K QHD video resolution for crystal-clear, end-to-end coverage of your property.
Standout Features:
- 3000 Lumens of Brightness: Three adjustable, dimmable LED panels provide powerful illumination.
- 2.5K QHD Video with Color Night Vision: See more detail, even in low light.
- AI-Powered Motion Detection: Vision AI detects people and vehicles, reducing false alarms from irrelevant motion.
- Motion-Activated Voice Deterrence & 105dB Siren: Warn intruders with a customizable voice alert and loud siren.
- Dual-Band Wi-Fi (2.4 & 5 GHz): Faster, more reliable connection.
- Ambient Light Mode & Dusk-to-Dawn Automation: Keeps your home lit softly or brightly as needed.
- IP65 Weatherproof: Durable for all weather conditions.
- Bluetooth Low Energy (BLE) Setup: Quick, ladder-free installation without QR code scanning.
Installation Made Simple
The Floodlight Pro is hardwired but can be paired with the
Wyze Cam Floodlight Plug-In Mount for a
plug-and-play installation that avoids the complexity of junction boxes and messy wiring.
Wyze Cam Floodlight Pro delivering bright, wide-angle security lighting
Wyze Cam Floodlight Plug-In Mount: Simplify Your Installation
If you want to avoid the hassle and cost of hardwiring or installing a junction box, the
Wyze Cam Floodlight Plug-In Mount is the perfect accessory. It allows you to power your floodlight camera through a standard outdoor power outlet with a
20-foot power cord, making installation quick and cable management neat.
Features:
- Compatible with Wyze Cam Floodlight v1, v2, and Pro: Versatile for multiple models.
- 20 ft (6m) Power Cord: Provides flexibility in placement.
- Outdoor Safe & Weather Resistant: Rated for outdoor use in various climates.
- Easy Velcro Cable Management: Keeps cables tidy and secure during installation.
- Plug-and-Play Setup: No electrician needed, perfect for renters or DIY enthusiasts.
- Includes Mounting Kit and Quick Start Guide: Everything you need for a smooth setup.
Wyze Cam Floodlight Plug-In Mount enables easy, no-junction-box installation
Why Choose Wyze Floodlight Cameras with Easy Installation?
Installing a floodlight camera can be intimidating, especially when it involves wiring and cable management. Wyze solves this with smart design and accessories like the Plug-In Mount, allowing you to secure your home quickly and cleanly without professional help.
- Velcro Cable Management included with the Plug-In Mount keeps your installation neat and safe.
- DIY Friendly: Whether you choose the hardwired Floodlight v2 or Pro, or the plug-in mount option, setup is straightforward.
- Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Reliable Weatherproofing: IP65 rating ensures your floodlight camera performs rain or shine.
- Local and Cloud Storage Options: Record continuously or get smart alerts with Cam Plus subscription.
Summary of Products for Easy Security Installation Floodlight Cameras
Product | Resolution | Field of View | Lumens | Installation Type | Wi-Fi Support | Special Features |
Wyze Cam Floodlight v2 | 2K (2304x1296) | 160° | 2800 | Hardwired / Plug-In Mount | 2.4 GHz only | Access Point Setup, Ambient Light Mode, Motion Warning |
Wyze Cam Floodlight Pro | 2.5K QHD (2560x1440) | 180° | 3000 | Hardwired / Plug-In Mount | 2.4 & 5 GHz dual-band | AI Motion Detection, Voice Deterrence, BLE Setup |
Wyze Cam Floodlight Plug-In Mount | N/A | N/A | N/A | Plug-in Power Adapter | N/A | Velcro Cable Management, Outdoor Safe |
Secure your home with bright, intelligent lighting and easy installation solutions from Wyze. Whether you want the powerful
Wyze Cam Floodlight v2 or the advanced
Floodlight Pro, pairing them with the
Plug-In Mount makes setup a breeze — no electrician or messy wiring required.
Product P Tags:
- Wyze Cam Floodlight v2
- Wyze Cam Floodlight Pro
- Wyze Cam Floodlight Plug-In Mount
- Wyze Cam Floodlight Pro + Plug-In Mount Bundle
What are the main features of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 offers 2800 lumens of super-bright, dimmable LED lighting, 2K HD video resolution with color night vision, a 160° wide-angle field of view, AI-powered motion detection, 24/7 local recording with microSD support, two-way talk, a 105dB siren, dusk-to-dawn automation, IP65 weather resistance, and easy Wi-Fi access point setup.How easy is it to install the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 is designed for easy installation. While it requires hardwiring, it also supports plug-in mount options for homes without junction boxes. The access point feature allows for ladder-free Wi-Fi setup, making installation straightforward for DIY users.What makes the Wyze Cam Floodlight Pro different from the v2 model?
The Wyze Cam Floodlight Pro features a 180° ultra-wide field of view, 2.5K QHD video resolution, 3000 lumens of brightness from three adjustable LED panels, advanced AI-powered motion detection for people and vehicles, motion-activated voice deterrence, a 105dB siren, dual-band Wi-Fi (2.4 & 5 GHz), and Bluetooth Low Energy (BLE) setup for quick installation.Can I install Wyze floodlight cameras without hardwiring?
Yes, you can install Wyze floodlight cameras without hardwiring by using the Wyze Cam Floodlight Plug-In Mount. This accessory allows you to power your floodlight camera through a standard outdoor power outlet, making installation plug-and-play and ideal for renters or those without existing junction boxes.What is the Wyze Cam Floodlight Plug-In Mount and how does it help with installation?
The Wyze Cam Floodlight Plug-In Mount is an accessory that enables plug-and-play installation of Wyze floodlight cameras. It comes with a 20-foot outdoor-safe power cord and Velcro cable management, allowing you to neatly and securely manage cables without the need for hardwiring or an electrician.Which Wyze floodlight cameras are compatible with the Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Pro models, providing flexible installation options for various Wyze floodlight cameras.How does Velcro cable management improve Wyze floodlight camera installation?
Velcro cable management, included with the Wyze Cam Floodlight Plug-In Mount, keeps cables tidy, secure, and organized during installation. This ensures a neat appearance and reduces the risk of tripping or cable damage.Are Wyze floodlight cameras weatherproof?
Yes, Wyze floodlight cameras, including the v2 and Pro models, are IP65 weather resistant. This means they are built to withstand rain, snow, and extreme temperatures, making them suitable for outdoor use in various climates.Do Wyze floodlight cameras support smart home integration?
Yes, Wyze floodlight cameras work seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What storage options are available for Wyze floodlight cameras?
Wyze floodlight cameras support both local and cloud storage. You can use a microSD card (up to 256GB) for continuous local recording without subscription fees, or subscribe to Cam Plus for cloud-based smart alerts and additional features.
