Universal Wyze Mount Long Stem for Battery Cam Pro Support
If you're looking to enhance your Wyze Battery Cam Pro setup with a universal mount featuring a long stem, this guide highlights the perfect Wyze products that complement your mounting needs. Whether you want flexible placement, extended reach, or reliable outdoor security, the Wyze Battery Cam Pro and its accessories provide versatile solutions.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
Key Features and Specifications
- 2.5K HDR Video Resolution: Crystal-clear 2560 x 1440 video quality ensures you never miss a detail.
- Wire-Free & No Hub Required: Completely wireless operation with no need for a central hub.
- Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security and deterrence.
- Radar + PIR Motion Detection: Dual motion sensors for accurate detection and fewer false alarms.
- Removable, Rechargeable Battery Packs: 6200mAh battery lasts up to 6 months on a single charge.
- Weatherproof Design: IP65 rating ensures reliable performance in rain, snow, or sun.
- Wide Field of View: 134° diagonal, 108° horizontal, and 56° vertical for broad coverage.
- Two-Way Audio: Communicate through the camera with a built-in speaker and microphone.
- Standard Mounting Compatibility: Uses a 1/4” - 20 standard thread, perfect for universal mounts with long stems.
Dimensions & Build
- Size: 2.5 x 1.8 x 3.5 inches
- Weight: 0.94 lbs
- Finish: Matte with durable PC plastics for outdoor resilience
The Wyze Battery Cam Pro’s compatibility with standard mounting threads makes it ideal for use with universal mounts featuring long stems, allowing you to position the camera exactly where you need it for optimal surveillance.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Outdoor Use
Enhanced Features
- All the features of the Wyze Battery Cam Pro, plus:
- Solar Panel Integration: Keep your camera powered continuously with solar energy, reducing the need for manual recharging.
- Color Night Vision: Enhanced night vision with white LEDs for clearer nighttime footage.
- Local and Cloud Storage: Supports up to 256 GB microSD cards and cloud recording with Cam Plus subscription.
- Weatherproof & Wire-Free: Perfect for outdoor mounting with universal mounts and long stems.
This bundle is perfect for users who want to mount their Wyze Battery Cam Pro in hard-to-reach outdoor locations using a long stem mount, ensuring continuous power without frequent battery swaps.
Wyze Removable Battery Pack: Convenient Power Backup
Battery Pack Highlights
- Capacity: 6200mAh rechargeable lithium-ion battery.
- Long Life: Powers your Wyze Battery Cam Pro for up to 6 months per charge.
- USB-C Charging: Easy and fast charging with a built-in USB-C port.
- Compact Size: 2.9 in x 1.6 in x 0.9 in, lightweight at 3.9 oz.
- Operating Range: Works reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
Having extra removable battery packs is essential when using a universal mount with a long stem, especially if the camera is mounted in a location that is difficult to access frequently. Swap batteries quickly without dismounting the entire setup.
Why Choose a Universal Mount with a Long Stem for Wyze Battery Cam Pro?
A universal mount with a long stem offers extended reach and flexible positioning options, making it easier to install your Wyze Battery Cam Pro in optimal locations such as high corners, poles, or overhangs. This enhances the camera’s field of view and motion detection capabilities.
- Versatility: Compatible with the standard 1/4” - 20 mounting thread on Wyze Battery Cam Pro.
- Improved Coverage: Elevate your camera for better angles and wider surveillance zones.
- Weather-Resistant Setup: Combine with the IP65-rated camera for durable outdoor security.
Summary
The Wyze Battery Cam Pro and its Solar Panel bundle are the best choices for users seeking a reliable, wire-free security camera that supports universal mounts with long stems. Complement your setup with removable battery packs for uninterrupted power and easy maintenance.
Enhance your home or business security with these versatile Wyze products designed for flexible mounting and long-lasting performance.
Secure your property with flexible mounting options
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Pro + Solar Panel | Wyze Removable Battery Pack |
Type | Camera | Camera + Accessory Bundle | Accessory (Battery) |
Video Resolution | 2.5K HDR | 2.5K HDR | N/A |
Power | Removable, Rechargeable Battery | Removable, Rechargeable Battery + Solar Panel | 6200mAh Rechargeable Battery Pack |
Solar Panel Included | No | Yes | No |
Motion Detection | Radar + PIR | Radar + PIR | N/A |
Integrated Spotlight & Siren | Yes | Yes | N/A |
Weatherproof Rating | IP65 | IP65 | N/A |
WiFi Support | 2.4 & 5 GHz | 2.4 & 5 GHz | N/A |
Local Recording (MicroSD) | Yes | Yes | N/A |
Battery Life | Up to 6 months per charge | Extended with Solar Panel | 6200mAh, up to 6 months per charge |
Charging Method | USB-C | USB-C | USB-C |
Setup | Wireless, No Hub Required | Wireless, No Hub Required | N/A |
Price (USD) | $89.98 (1 Pack) | $109.98 (Bundle) | $22.99 |
Color Options | Black, White | Black, White | White |
Weight | 0.94 lb (Camera) | 0.94 lb (Camera) + Solar Panel weight not specified | 3.9 oz (110g) |
Dimensions | 2.5" x 1.8" x 3.5" | Same as Battery Cam Pro + Solar Panel: 173 mm x 120 mm x 17 mm (Solar Panel) | 2.9" x 1.6" x 0.9" (Battery Pack) |
Additional Features | Dual-band WiFi, Two-way Audio, Bluetooth Setup | Same as Battery Cam Pro + Continuous power from Solar Panel | Replacement battery for Battery Cam Pro and Duo Cam Doorbell |
Charging Time | N/A | N/A | Approx. 9 hours at 25°C (77°F) |
What is the Wyze Battery Cam Pro and what are its key features?
The Wyze Battery Cam Pro is an advanced wireless security camera offering 2.5K HDR video resolution, wire-free operation, integrated spotlight and siren, radar plus PIR motion detection, removable rechargeable battery packs, weatherproof IP65 design, wide field of view, and two-way audio. It is compatible with standard 1/4” - 20 mounting threads, making it ideal for universal mounts with long stems.Can I use a universal mount with a long stem for the Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro is compatible with universal mounts that use a standard 1/4” - 20 thread. A long stem mount allows for flexible placement, extended reach, and optimal positioning in high or hard-to-reach locations, enhancing your camera’s field of view and motion detection.What are the benefits of using a long stem universal mount with the Wyze Battery Cam Pro?
Using a universal mount with a long stem provides extended reach and flexible positioning, making it easier to install your Wyze Battery Cam Pro in optimal locations such as high corners, poles, or overhangs. This setup improves coverage, enhances motion detection, and is ideal for outdoor security.How long does the Wyze Battery Cam Pro battery last and can I use extra battery packs?
The Wyze Battery Cam Pro uses a 6200mAh removable, rechargeable battery pack that can last up to 6 months on a single charge. You can purchase extra removable battery packs for convenient power backup, especially useful when the camera is mounted in hard-to-access locations with a long stem mount.Is the Wyze Battery Cam Pro weatherproof and suitable for outdoor use?
Yes, the Wyze Battery Cam Pro features an IP65 weatherproof rating, making it reliable for outdoor use in rain, snow, or sun. It is designed with durable PC plastics to withstand various weather conditions.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes all the features of the Wyze Battery Cam Pro, plus a solar panel for continuous power, color night vision with white LEDs, support for up to 256 GB microSD cards, and cloud recording with a Cam Plus subscription. This bundle is ideal for mounting in hard-to-reach outdoor locations using a long stem mount.How do I power my Wyze Battery Cam Pro in hard-to-reach locations?
For hard-to-reach locations, you can use the Wyze Battery Cam Pro with a solar panel for continuous power or keep extra removable battery packs on hand for quick swaps. Both options reduce the need for frequent manual recharging, especially when using a long stem mount.What are the dimensions and weight of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro measures 2.5 x 1.8 x 3.5 inches and weighs 0.94 lbs. Its compact and durable design makes it suitable for various mounting options, including universal mounts with long stems.What storage options are available for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB and offers cloud recording through a Cam Plus subscription, ensuring you have flexible options for saving your security footage.Why should I choose Wyze products for flexible security camera mounting?
Wyze products, including the Battery Cam Pro and its accessories, are designed for versatility, durability, and ease of use. Their compatibility with universal mounts and long stems allows for flexible placement, improved coverage, and reliable outdoor security, making them ideal for both home and business use.
What are the key features of the Wyze Battery Cam Pro?Can you tell me more about the solar panel integration with the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
