Wyze Lock Bolt: Auto-Locking Smart Door Lock with Auto-Unlock
Discover the Wyze Lock Bolt: The Smart Lock That Auto Locks and Unlocks on Approach
Upgrade your home security with the Wyze Lock Bolt, a cutting-edge Bluetooth smart lock designed to replace your traditional deadbolt. This smart lock offers seamless auto-lock and auto-unlock features, ensuring your door locks automatically when you leave and unlocks instantly as you approach — no more fumbling for keys or codes.
"Unlock your door in less than a second with the touch of a finger or a tap in the app."
Ultra-Fast Fingerprint Sensor & Backlit Keypad
The Wyze Lock Bolt features an ultra-fast fingerprint reader that grants you quick, secure access without the hassle of keys. Its backlit keypad includes an anti-peep feature, allowing you to enter your code discreetly even in low light. Whether you prefer biometric access or keypad entry, this lock adapts to your lifestyle.
Auto-Lock and Auto-Unlock Convenience
Never worry about forgetting to lock your door again. The Wyze Lock Bolt automatically locks itself after you leave, providing peace of mind. When you return, the lock senses your approach via Bluetooth and unlocks instantly, welcoming you home effortlessly.
Robust Connectivity and Battery Life
Powered by Bluetooth 5.0, the Wyze Lock Bolt maintains a reliable connection up to 16 feet. It runs on 4 AA batteries (included) with an impressive battery life of 10-12 months, minimizing maintenance. The lock is weather-resistant with an IPX5 rating, suitable for various climates and outdoor conditions.
Easy Installation and Compatibility
Designed to replace your existing deadbolt, the Wyze Lock Bolt fits standard door thicknesses (1-3/8” to 1-3/4”) and backsets (2-3/8” or 2-3/4”). Installation is straightforward, making it a perfect upgrade for any home.
Additional Smart Features
  • Lock and unlock history accessible via the Wyze app
  • Built-in alarm for jam detection
  • Emergency one-time access codes for guests or service providers
Wyze Lock Bolt lifestyle Experience seamless home entry with Wyze Lock Bolt smart lock.
Enhance Your Smart Lock Setup with Wyze Replacement Parts
To keep your Wyze Lock Bolt functioning flawlessly, Wyze offers essential replacement parts designed specifically for this model.
Wyze Lock Bolt Interior Assembly Metal Plate
Secure the interior assembly firmly to your door with this durable metal plate. It ensures stability and longevity of your smart lock installation.
Wyze Lock Bolt Screws
This set of screws is compatible with the Wyze Lock Bolt, perfect for replacements or reinstallation needs.
Wyze Lock Bolt Interior Assembly Battery Cover
Protect your lock’s battery compartment with this replacement battery cover, designed to fit perfectly and maintain the lock’s sleek look.
Wyze Lock Replacement Part Kit
This kit includes various replacement components compatible with the Wyze Lock, helping you maintain or repair your smart lock with ease.
Complete Your Smart Home Security with The Front Porch Security Bundle
For a comprehensive smart home security solution, consider the Front Porch Security Bundle. This package combines the Wyze Lock Bolt with Wyze’s advanced video doorbell and chime, giving you full control and monitoring of your front door.
Features of the Front Porch Security Bundle
  • View your front porch in crisp 1080p HD with Wyze Video Doorbell
  • Two-way audio to greet visitors remotely
  • Lock and unlock your door from anywhere using the Wyze app
  • Receive motion alerts and review lock history for enhanced security
  • Compatible with Alexa and Google Assistant for voice control
This bundle is perfect for homeowners seeking an integrated, smart security system that automates access and keeps you connected to your home at all times. Wyze Lock Bolt with Video Doorbell Smart security made simple with Wyze Lock Bolt and Video Doorbell.
Why Choose Wyze Lock Bolt for Your Smart Lock Needs?
  • Auto-lock and auto-unlock for effortless security
  • Ultra-fast fingerprint sensor for quick access
  • Backlit keypad with anti-peep for secure code entry
  • Long-lasting battery life with easy replacement
  • Weather-resistant design suitable for various environments
  • App control and lock history for full transparency and control
Upgrade your home with the Wyze Lock Bolt and enjoy the convenience of a smart lock that works intuitively with your lifestyle. Wyze Lock Bolt lifestyle Modern design meets smart technology with Wyze Lock Bolt.
Product NameTypePrice (USD)Key Features / DescriptionCompatibilityReturn Policy
Wyze Lock BoltConnected Home79.98Bluetooth smart lock, fingerprint sensor, backlit keypad, auto-lock, hardware encryption, 12-month battery lifeReplaces existing deadbolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the doorWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement Parts2.99Set of replacement screwsWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Replacement interior battery coverWyze Lock Bolt30-day hassle-free returns
Wyze Lock Replacement Part KitReplacement Parts4.99 - 19.99Replacement part kit (includes Adapter Replacement Kit option)Wyze Lock30-day hassle-free returns
The Front Porch Security BundleCameras123.99 - 173.97Includes Wyze Lock or Wyze Lock Bolt, Wyze Video Doorbell & Chime, remote lock/unlock, 1080p HD video, Alexa/Google supportWyze Lock / Wyze Lock BoltNot specified
What is the Wyze Lock Bolt and how does it work?The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your traditional deadbolt. It features auto-lock and auto-unlock capabilities, allowing your door to lock automatically when you leave and unlock instantly as you approach, using your smartphone or fingerprint for seamless access.
How does the Wyze Lock Bolt's fingerprint sensor work?The Wyze Lock Bolt is equipped with an ultra-fast fingerprint sensor that unlocks your door in less than a second. This biometric access provides quick, secure entry without the need for keys or codes.
Can I use a keypad with the Wyze Lock Bolt?Yes, the Wyze Lock Bolt features a backlit keypad with an anti-peep function, allowing you to enter your code discreetly even in low-light conditions. This provides an alternative to fingerprint or app-based access.
What is the battery life of the Wyze Lock Bolt?The Wyze Lock Bolt runs on 4 AA batteries (included) and offers an impressive battery life of 10-12 months, minimizing the need for frequent replacements.
Is the Wyze Lock Bolt weather-resistant?Yes, the Wyze Lock Bolt is weather-resistant with an IPX5 rating, making it suitable for various climates and outdoor conditions.
How far is the Bluetooth range for the Wyze Lock Bolt?The Wyze Lock Bolt uses Bluetooth 5.0 technology, maintaining a reliable connection up to 16 feet from your smartphone.
Is the Wyze Lock Bolt easy to install?Yes, the Wyze Lock Bolt is designed for easy installation and fits standard door thicknesses (1-3/8” to 1-3/4”) and backsets (2-3/8” or 2-3/4”). It replaces your existing deadbolt with minimal effort.
Can I view lock and unlock history with the Wyze Lock Bolt?Yes, you can access your lock and unlock history through the Wyze app, providing full transparency and control over your home security.
Does the Wyze Lock Bolt have a built-in alarm?Yes, the Wyze Lock Bolt includes a built-in alarm that detects jams, alerting you to any issues with your lock.
Are there replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers essential replacement parts for the Lock Bolt, including the interior assembly metal plate, screws, battery cover, and a comprehensive replacement part kit.
What is the Front Porch Security Bundle?The Front Porch Security Bundle combines the Wyze Lock Bolt with the Wyze Video Doorbell and chime, offering 1080p HD video, two-way audio, app control, motion alerts, and compatibility with Alexa and Google Assistant for a complete smart home security solution.
Can I control the Wyze Lock Bolt remotely?Yes, when paired with the Wyze app and the Front Porch Security Bundle, you can lock and unlock your door from anywhere, receive motion alerts, and review lock history for enhanced security.
Is the Wyze Lock Bolt compatible with voice assistants?Yes, the Wyze Lock Bolt is compatible with Alexa and Google Assistant, allowing you to control your lock using voice commands when integrated with the Front Porch Security Bundle.
Does the Wyze Lock Bolt support emergency access codes?Yes, the Wyze Lock Bolt allows you to generate emergency one-time access codes for guests or service providers, ensuring secure and temporary access to your home.
What are the installation requirements for the Wyze Lock Bolt?Can the Wyze Lock Bolt be used with different door thicknesses?Do you have any ongoing sales or discounts for the Wyze Lock Bolt?
