DIY Install Hardwired Floodlight Camera with Wide-Angle View
DIY Install Hardwired Floodlight Camera with Wide View
Enhance your home security with advanced hardwired floodlight cameras that offer wide-angle views, bright illumination, and smart features. Whether you want to monitor your driveway, backyard, or front porch, these Wyze floodlight cameras provide an easy DIY installation experience combined with powerful surveillance capabilities.
Wyze Cam Floodlight v2: Bright, Wide, and Smart Security Lighting
Powerful Illumination and Wide-Angle Coverage
The Wyze Cam Floodlight v2 is designed to dominate the dark with 2800 lumens of bright LED light and a 160° wide-angle view. Its two dimmable LED light panels provide clear, vibrant lighting with a color temperature of 5000K, perfect for illuminating large outdoor areas.
Crisp 2K Video with Color Night Vision
Capture every detail with 2K HD video (2304 x 1296) and enjoy color night vision that keeps your property visible even in low light. The camera records at 20 FPS during the day and 15 FPS at night, ensuring smooth, clear footage.
Smart Features for Seamless Security
  • AI-Powered Light Control adjusts lighting based on motion and ambient conditions.
  • Two-way audio lets you communicate through the built-in speaker and microphone.
  • Dusk-to-dawn automation turns lights on and off automatically.
  • IP65 weather resistance ensures reliable performance in all weather.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Easy Hardwired Installation
Designed for hardwired 110-120V AC power, the Floodlight v2 mounts easily on walls or ceilings, making it a perfect choice for a DIY install that integrates directly into your home’s electrical system. Wyze Cam Floodlight v2 in action illuminating a driveway at night Bright security lighting with wide-angle view
Wyze Cam Floodlight Pro: Ultra-Wide 180° View with AI-Powered Detection
Exceptional Video Quality and Field of View
Step up your security with the Wyze Cam Floodlight Pro, featuring a 2.5K QHD (2560 x 1440) resolution and an ultra-wide 180° diagonal field of view. This camera covers your entire yard end-to-end with crystal-clear detail.
Intelligent Motion Detection and Lighting
Equipped with evolutionary onboard AI computer vision, the Floodlight Pro detects motion from people, vehicles, and other objects you select. It activates its 3,000 lumen LED lights only when necessary, conserving energy while providing bright, targeted illumination.
Advanced Features for Smart Security
  • 3 dimmable light panels with 5000K color temperature.
  • 105dB siren for audible deterrence.
  • Dual-band WiFi support (2.4 & 5 GHz) for stable connectivity.
  • Weatherproof with IP65 rating for all-season durability.
  • Compatible with Alexa, Google Assistant, and IFTTT.
Hardwired Power with Flexible Mounting
Like the Floodlight v2, the Pro model is designed for hardwired 110-120V AC installation on walls or ceilings, making it ideal for a secure, permanent setup. Wyze Cam Floodlight Pro mounted outdoors with a woman and dog nearby Smart floodlight camera with AI detection
Wyze Cam Floodlight Plug-In Mount: Simplify Your Installation
Easy Plug-and-Play Solution
If you want to avoid the complexity and cost of installing a junction box for your hardwired floodlight camera, the Wyze Cam Floodlight Plug-In Mount is the perfect accessory. It offers a 20-foot power cord and a plug-in design that works outdoors safely.
Compatibility and Convenience
  • Compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
  • Outdoor-safe with robust certifications including UL and RoHS.
  • Includes mounting kits and foam tape for secure installation.
  • Operates in temperatures from -22°F to 122°F, suitable for most climates.
This mount allows you to enjoy the benefits of a hardwired floodlight camera without the need for electrical rewiring or junction box installation.
Bundled Convenience: Wyze Cam Floodlight Pro + Plug-In Mount
For the ultimate DIY install experience, consider the Wyze Cam Floodlight Pro + Plug-In Mount bundle. This combo provides the high-performance Floodlight Pro camera with the easy plug-in mount, giving you:
  • 2.5K QHD video with color night vision.
  • 180° ultra-wide field of view.
  • 3000 lumens of bright, dimmable LED lighting.
  • A 20-foot power cord for flexible placement.
  • Simple plug-and-play installation without junction box hassle.
This bundle is perfect for those who want professional-grade security lighting with the convenience of plug-in power.
Why Choose a Hardwired Floodlight Camera with Wide View?
Installing a hardwired floodlight camera with a wide-angle lens is one of the best ways to secure your home’s exterior. These cameras provide bright, reliable lighting combined with high-resolution video to deter intruders and keep you informed. With DIY-friendly options like plug-in mounts, you can enjoy professional security without complicated electrical work.
Summary of Features
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProPlug-In MountFloodlight Pro + Plug-In Mount Bundle
Video Resolution2K HD (2304 x 1296)2.5K QHD (2560 x 1440)N/A2.5K QHD
Field of View160° diagonal180° diagonalN/A180° diagonal
LED Brightness (Lumens)28003000N/A3000
Night VisionColor Night VisionColor Night VisionN/AColor Night Vision
Power SupplyHardwired 110-120V ACHardwired 110-120V ACPlug-in 110-120V ACPlug-in 110-120V AC
Weather ResistanceIP65IP65Outdoor SafeIP65
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/AAlexa, Google Assistant, IFTTT
InstallationWall/Ceiling mountWall/Ceiling mountPlug-n-play mountPlug-n-play mount + camera
Invest in a Wyze hardwired floodlight camera with a wide view to secure your home with bright lighting, sharp video, and smart automation — all with easy DIY installation options tailored to your needs.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProWyze Cam Floodlight v2 + Plug-In Mount
Video Resolution2K HD2.5K QHD2K HD
Field of View160° wide-angle180° ultra-wide160° wide-angle
LED Brightness2800 lumens3000 lumens2800 lumens
Number of Floodlight Heads232
Color Night VisionYesYesYes
Motion DetectionPIR sensor with AI-Powered Light ControlAI computer visionAdvanced motion detection
Motion Detection Area270° PIR motion detection areaAI vision-based, object-selective270° PIR motion detection area
Two-Way TalkYesYesYes
Siren105 dB105 dB105 dB
Ambient Light ModeYesYesYes
Dusk-to-Dawn AutomationYesYesYes
Weather ResistanceIP65IP65IP65
Local Recording24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)
Wi-Fi Compatibility2.4 GHz2.4 & 5 GHz dual-band2.4 GHz
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant
InstallationHardwired, DIY installHardwired, DIY installHardwired, DIY install with plug-in mount option
Plug-In Mount IncludedNoNoYes (includes 20 ft power cord and cable management)
Power Cord LengthN/A20 ft (6m)20 ft (6m)
Price$89.98$149.98$109.96
What are the main benefits of installing a Wyze hardwired floodlight camera with a wide view?Wyze hardwired floodlight cameras offer bright, reliable LED lighting, wide-angle video coverage, and smart features like AI-powered motion detection, color night vision, and smart home integration. These features help deter intruders, monitor large outdoor areas, and keep you informed about activity around your home.
What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?Wyze Cam Floodlight v2 features 2K HD video resolution, a 160° wide-angle view, and 2800 lumens of LED lighting. The Floodlight Pro offers a higher 2.5K QHD resolution, an ultra-wide 180° field of view, 3000 lumens of brightness, and advanced AI-powered motion detection for people, vehicles, and objects.
Can I install Wyze floodlight cameras myself?Yes, Wyze floodlight cameras are designed for easy DIY installation. Both the Floodlight v2 and Pro models can be hardwired to your home’s 110-120V AC electrical system and mounted on walls or ceilings. For even easier installation, the Wyze Cam Floodlight Plug-In Mount allows you to plug the camera into a standard outlet without electrical rewiring.
What is the Wyze Cam Floodlight Plug-In Mount and how does it work?The Wyze Cam Floodlight Plug-In Mount is an accessory that allows you to power your Wyze Cam Floodlight v1, v2, or Pro using a standard outlet. It features a 20-foot power cord, is outdoor-safe, and includes mounting kits for secure installation. This plug-and-play solution eliminates the need for a junction box or electrical rewiring.
Are Wyze floodlight cameras weatherproof?Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro have an IP65 weather resistance rating, ensuring reliable performance in rain, snow, and other outdoor conditions. The Plug-In Mount is also outdoor-safe and certified for use in a wide range of temperatures.
Do Wyze floodlight cameras support smart home integration?Yes, Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing you to integrate them with your smart home system for voice control and automation.
What video quality and night vision features do Wyze floodlight cameras offer?Wyze Cam Floodlight v2 records in 2K HD (2304 x 1296) and the Floodlight Pro in 2.5K QHD (2560 x 1440). Both models feature color night vision, providing clear, detailed footage even in low-light conditions.
What smart security features are included with Wyze floodlight cameras?Wyze floodlight cameras include AI-powered motion detection, two-way audio, dusk-to-dawn automation, and, in the Pro model, a 105dB siren for audible deterrence. These features enhance your home’s security and provide real-time alerts.
Is there a bundle available for easy installation of Wyze Cam Floodlight Pro?Yes, the Wyze Cam Floodlight Pro + Plug-In Mount bundle combines the high-performance Floodlight Pro camera with the easy-to-install plug-in mount. This bundle offers 2.5K QHD video, 180° field of view, 3000 lumens of lighting, and a 20-foot power cord for flexible placement without the need for a junction box.
What areas of my home can I monitor with Wyze floodlight cameras?Wyze floodlight cameras are ideal for monitoring driveways, backyards, front porches, and other large outdoor areas. Their wide-angle lenses and bright LED lights ensure comprehensive coverage and clear video footage.
What are the main features of the Wyze Cam Floodlight v2?How does the AI-powered light control work in the floodlight cameras?Do you have any deals, ongoing sales, discounts, or promotions for the floodlight cameras?
