Wyze Cordless Vacuum S: Ultra-Compact Dock & Powerful Suction
Discover the Wyze Cordless Vacuum S with Ultra-Compact Charging Dock
Looking for a cordless vacuum that combines powerful suction, ultra-portability, and smart design? The Wyze Cordless Vacuum S is engineered to deliver exceptional cleaning performance with the convenience of a compact charging dock, making it the perfect addition to any modern home.
Wyze Cordless Vacuum S: Lightweight Yet Mighty
Powerful Suction for Every Cleaning Need
The Wyze Cordless Vacuum S boasts an impressive 20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on carpets, hardwood floors, and pet hair. It offers three suction modes to balance power and battery life:
  • Turbo Mode: 20,000 Pa (10 minutes runtime)
  • Medium Mode: 9,000 Pa (23 minutes runtime)
  • ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility lets you tackle everything from quick touch-ups to intensive cleaning sessions.
Ultra-Lightweight Design
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, this vacuum is as light as 2.8 pounds of feathers. Its ergonomic design makes it effortless to maneuver around furniture, stairs, and tight spaces without fatigue.
Long-Lasting Battery & Fast Charging
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), the vacuum provides up to 40 minutes of runtime on ECO mode. The ultra-compact charging dock uses AC charging and fully recharges the battery in just 4-6 hours, so your vacuum is always ready to go.
Smart Features for Enhanced Usability
  • LED screen displays suction mode and battery status clearly.
  • Two motors deliver consistent power and efficiency.
  • 3-stage filtration system traps dust and allergens effectively.
  • 6 daylight-bright LED lights on the brush head illuminate dark corners and under furniture.
Compact Dimensions & Stylish Look
The main unit measures 12.4 x 4.5 x 8.7 inches, and the fully assembled vacuum extends to 41.1 inches in length. Finished in sleek steel grey with Wyze green accents, it fits seamlessly into any home décor.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Wyze Cordless Vacuum S lifestyle cleaning with pet Effortless vacuuming around your home, even with pets.
Essential Accessories for Your Wyze Cordless Vacuum S
Battery Pack – Double Your Cleaning Time
Need extra juice for larger cleaning jobs? The Wyze Cordless Vacuum S Battery Pack is designed specifically for this model, allowing you to swap batteries and extend your vacuuming sessions without waiting for a recharge.
Charger – Reliable Power Supply
Keep your vacuum powered up with the Wyze Cordless Vacuum S Charger, a replacement part that ensures your charging dock always functions optimally.
Foldable Vacuum Tube – Flexible Cleaning
The Foldable Vacuum Tube bends so you don’t have to, making it easier to reach under furniture and into tight spaces. This accessory is compatible only with Wyze Cordless Vacuum models.
HEPA Filter – Maintain Peak Performance
Replace your vacuum’s filter regularly with the Wyze Cordless Vacuum HEPA Filter (2 Pack) to keep dust and allergens trapped and maintain strong suction power.
Mini Motorized Brush Head – Perfect for Cars and Sofas
This compact brush head is designed for cleaning car seats, sofas, and other upholstery, making your Wyze vacuum even more versatile.
Why Choose Wyze Cordless Vacuum S?
  • Ultra-compact charging dock saves space and keeps your vacuum ready.
  • Lightweight and portable for easy handling and storage.
  • Powerful suction modes to suit all cleaning needs.
  • Smart LED display and filtration system for convenience and health.
  • Wide range of accessories to customize your cleaning experience.
Wyze Cordless Vacuum S lifestyle with dog Perfect for pet owners and busy households.
Specifications at a Glance
FeatureSpecification
Suction Power100 AW / 20,000 Pa (Turbo Mode)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Battery6-cell lithium-ion, 2,000mAh*6
Runtime40 min (ECO), 23 min (Medium), 10 min (Turbo)
Charging Time4-6 hours (AC charging)
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo Mode)
Dimensions12.4 x 4.5 x 8.7 in (main), 41.1 in (assembled)
ColorSteel grey with Wyze green accents
FeaturesLED screen, 2 motors, 3-stage filtration, 6 LED lights
Conclusion
The Wyze Cordless Vacuum S is a top-tier choice for anyone seeking a cordless vacuum with ultra-compact charging dock that doesn’t compromise on power or convenience. Its lightweight design, powerful suction, and smart features make it ideal for homes with pets, busy lifestyles, and those who value efficiency and style. Upgrade your cleaning routine today with the Wyze Cordless Vacuum S and its range of tailored accessories! Wyze Cordless Vacuum lifestyle cleaning hardwood floor Clean every corner of your home effortlessly.
ProductTypePrice (USD)CompatibilityKey FeaturesNotes
Wyze Cordless Vacuum SConnected Home139.99N/A20,000 Pa suction, 2 motors, 40-min interchangeable lithium-ion battery, 2.8 lbs weight, 3-speed settings, 6 LED lights, 3-stage HEPA filtration, easy empty dust cupMain vacuum unit
Wyze Cordless Vacuum S - Battery PackAccessories59.99Wyze Cordless Vacuum SExtra interchangeable battery for extended useLow stock: 36 left
Wyze Cordless Vacuum S - ChargerReplacement4.99Wyze Cordless Vacuum SReplacement charger30-day hassle-free returns
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Wyze Cordless VacuumFlexible vacuum tube attachmentBends for easier cleaning
Wyze Cordless Vacuum - HEPA FilterAccessories15.99 (2 Pack)Wyze Cordless Vacuum3-stage HEPA filter replacementReplace regularly
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99Wyze Cordless VacuumMotorized brush head for car seats and sofasDimensions: 6 x 5.5 x 5 inches
What is the suction power of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers up to 20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on carpets, hardwood floors, and pet hair. It also features Medium Mode (9,000 Pa) and ECO Mode (6,000 Pa) to balance power and battery life.
How long does the Wyze Cordless Vacuum S battery last?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime on ECO mode, 23 minutes on Medium mode, and 10 minutes on Turbo mode, thanks to its 6-cell lithium-ion battery.
How long does it take to fully charge the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S fully recharges in just 4-6 hours using its ultra-compact AC charging dock.
How much does the Wyze Cordless Vacuum S weigh?The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and the fully assembled vacuum weighs 4.9 lbs, making it lightweight and easy to maneuver.
What are the dimensions of the Wyze Cordless Vacuum S?The main unit measures 12.4 x 4.5 x 8.7 inches, and the fully assembled vacuum extends to 41.1 inches in length.
Does the Wyze Cordless Vacuum S have a HEPA filter?Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter, to effectively trap dust and allergens.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories include the Wyze Cordless Vacuum S Battery Pack, Charger, Foldable Vacuum Tube, HEPA Filter (2 Pack), and Mini Motorized Brush Head for cleaning cars and upholstery.
Can I extend the cleaning time of my Wyze Cordless Vacuum S?Yes, you can extend your cleaning time by using the Wyze Cordless Vacuum S Battery Pack, which allows you to swap batteries for longer vacuuming sessions.
Is the Wyze Cordless Vacuum S suitable for pet owners?Absolutely. The Wyze Cordless Vacuum S is designed to handle pet hair efficiently with its powerful suction and specialized accessories, making it ideal for homes with pets.
What smart features does the Wyze Cordless Vacuum S offer?The vacuum includes an LED screen displaying suction mode and battery status, two motors for consistent power, a 3-stage filtration system, and six LED lights on the brush head to illuminate dark areas.
How loud is the Wyze Cordless Vacuum S during operation?The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet for a powerful cordless vacuum.
What is the dust cup capacity of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for efficient cleaning without frequent emptying.
What color options are available for the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S comes in a stylish steel grey finish with Wyze green accents, blending seamlessly with modern home décor.
Is the Wyze Cordless Vacuum S easy to store?Yes, the ultra-compact charging dock and lightweight design make the Wyze Cordless Vacuum S easy to store and keep ready for use.
Can the Wyze Cordless Vacuum S clean under furniture and in tight spaces?Yes, its lightweight, ergonomic design and optional Foldable Vacuum Tube make it easy to reach under furniture and into tight spaces.
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does it take to fully charge the Wyze Cordless Vacuum S?Are there any ongoing sales or discounts for the Wyze Cordless Vacuum S?
