Wyze Cordless Vacuum S: Powerful, Easy-to-Read Battery Display
Discover the Wyze Cordless Vacuum S: Powerful Cleaning with Easy Battery Monitoring
If you're searching for a cordless vacuum with easy-to-read battery indicators, the Wyze Cordless Vacuum S stands out as a top choice. Designed for effortless cleaning, this vacuum combines industrial-level suction power with smart features that make your cleaning routine smoother and more efficient. Whether you have pets, hardwood floors, or tricky corners, the Wyze Cordless Vacuum S delivers performance and convenience in a lightweight package.
Wyze Cordless Vacuum S: Specs That Impress
Industrial-Grade Suction Power
Experience the power of 20,000 Pa suction, driven by not one but two high-efficiency motors—one in the main body and another in the brush head. This dual-motor design ensures deep cleaning on all surfaces, from carpets to hardwood floors, capturing everything from fine dust to pet hair.
Lightweight and Ergonomic
Weighing just 2.8 pounds, the Wyze Cordless Vacuum S is as light as a fluffy corgi puppy, making it easy to maneuver around furniture and up stairs without fatigue.
Easy-to-Read Battery Indicator with Long Runtime
The vacuum features a crystal-clear LED display that shows battery life and cleaning speed at a glance. Choose from three suction modes—Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa)—and monitor your usage in real-time. The interchangeable lithium-ion battery offers up to 40 minutes of fade-free power, so you can finish your cleaning without interruptions.
Advanced Cleaning Features
  • 6 daylight-bright LED lights on the brush head illuminate hidden dust under furniture and in dark corners.
  • A 3-stage filtration system with a HEPA filter traps 95% of particles as small as 0.3 microns, ensuring cleaner air in your home.
  • The dust cup is easy to empty with one finger and fully washable for hassle-free maintenance.
Wyze Cordless Vacuum S in action with pet-friendly cleaning Alt text: Woman vacuuming sofa with Wyze Cordless Vacuum S while a corgi watches nearby
Enhance Your Cleaning Experience with Wyze Accessories
Wyze Cordless Vacuum S - Battery Pack
Never run out of power mid-cleaning. The extra battery pack is designed specifically for the Wyze Cordless Vacuum S, allowing you to swap batteries and extend your cleaning sessions effortlessly.
Wyze Cordless Vacuum S - Charger
Keep your vacuum ready to go with the replacement charger made for the Wyze Cordless Vacuum S. Compact and reliable, it ensures your vacuum is always powered up.
Clean hard-to-reach areas with ease using the foldable vacuum tube accessory. It bends so you don’t have to, perfect for under furniture or tight spaces.
Wyze Cordless Vacuum - HEPA Filter
Maintain peak filtration performance by replacing your vacuum’s filter regularly with the HEPA filter pack designed for the Wyze Cordless Vacuum.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for car seats, sofas, and upholstery, this mini motorized brush head accessory tackles pet hair and dirt in small spaces with precision. Lifestyle image showing cordless vacuuming in a modern home Alt text: Person vacuuming hardwood floor with Wyze Cordless Vacuum S in bright living room
Why Choose Wyze Cordless Vacuum S?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
With its powerful suction, lightweight design, and smart battery monitoring, the Wyze Cordless Vacuum S is built to make your cleaning effortless and effective. Its advanced features and accessories ensure you have the right tools for every cleaning challenge.
Wyze Cordless Vacuum S cleaning hardwood floor with LED lights Alt text: Close-up of Wyze Cordless Vacuum S cleaning hardwood floor with LED lights on brush head
Summary of Wyze Cordless Vacuum S Features
20,000 Pa suction power with dual motors
  • Lightweight at 2.8 lbs for easy handling
  • 40-minute runtime with interchangeable battery
Clear LED battery and speed display
  • 6 LED lights for visibility under furniture
3-stage HEPA filtration system Easy-to-empty and washable dust cup
  • Compatible accessories: battery pack, charger, foldable tube, HEPA filters, mini brush head
Upgrade your cleaning routine with the Wyze Cordless Vacuum S and its range of accessories designed to keep your home spotless with ease and style.
ProductTypePrice (USD)Key FeaturesCompatibilityWeight / DimensionsNotes
Wyze Cordless Vacuum SConnected Home139.9920,000 Pa suction, 2 motors, 40-min interchangeable battery, 2.8 lbs, 3-speed settings, LED display, 3-stage HEPA filtration, 6 LED lights in brush headN/A2.8 lbsEasy to empty dust cup, washable filters
Wyze Cordless Vacuum S - Battery PackAccessories59.99Extra interchangeable battery for extended useWyze Cordless Vacuum SN/ALow stock (36 left)
Wyze Cordless Vacuum S - ChargerReplacement Part4.99Replacement chargerWyze Cordless Vacuum SN/A30-day hassle-free returns
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Foldable tube for easier cleaningWyze Cordless VacuumN/APrice discounted from 29.99
Wyze Cordless Vacuum - HEPA Filter (2 Pack)Accessories15.99Replaceable HEPA filters, removes 95% of particles <0.3 µmWyze Cordless VacuumN/APack of 2
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99Motorized brush for car seats and sofasWyze Cordless Vacuum6 x 5.5 x 5 inchesFor detailed cleaning
What makes the Wyze Cordless Vacuum S a top choice for cordless vacuums?The Wyze Cordless Vacuum S stands out for its powerful 20,000 Pa suction, lightweight 2.8 lb design, easy-to-read LED battery indicator, and a range of smart features that make cleaning efficient and convenient. It is ideal for homes with pets, hardwood floors, and hard-to-reach areas.
How powerful is the suction on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers industrial-grade suction power of up to 20,000 Pa, thanks to its dual high-efficiency motors—one in the main body and another in the brush head. This ensures deep cleaning on carpets, hardwood floors, and more.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features an interchangeable lithium-ion battery that provides up to 40 minutes of fade-free power, allowing you to clean your home without interruptions.
Does the Wyze Cordless Vacuum S have a battery indicator?Yes, the Wyze Cordless Vacuum S is equipped with a crystal-clear LED display that shows real-time battery life and cleaning speed, making it easy to monitor your usage.
What cleaning modes are available on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers three suction modes: Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa), allowing you to adjust the power based on your cleaning needs.
Is the Wyze Cordless Vacuum S easy to maneuver?Yes, weighing just 2.8 pounds, the Wyze Cordless Vacuum S is lightweight and ergonomically designed for easy handling, making it simple to clean around furniture and up stairs.
What filtration system does the Wyze Cordless Vacuum S use?The vacuum features a 3-stage filtration system with a HEPA filter that traps 95% of particles as small as 0.3 microns, ensuring cleaner air in your home.
How do I empty and clean the dust cup on the Wyze Cordless Vacuum S?The dust cup on the Wyze Cordless Vacuum S is designed for easy, one-finger emptying and is fully washable for hassle-free maintenance.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories include an extra battery pack, replacement charger, foldable vacuum tube for hard-to-reach areas, HEPA filter pack, and a mini motorized brush head for cleaning upholstery and car interiors.
How do the LED lights on the Wyze Cordless Vacuum S help with cleaning?The vacuum’s brush head features 6 daylight-bright LED lights that illuminate hidden dust under furniture and in dark corners, ensuring thorough cleaning.
Can I extend the cleaning time of the Wyze Cordless Vacuum S?Yes, you can extend your cleaning sessions by using the extra interchangeable battery pack designed specifically for the Wyze Cordless Vacuum S.
Is the Wyze Cordless Vacuum S suitable for pet owners?Absolutely. The powerful suction, HEPA filtration, and specialized accessories like the mini motorized brush head make the Wyze Cordless Vacuum S ideal for homes with pets.
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does the battery last on the Wyze Cordless Vacuum S?Is there a warranty for the Wyze Cordless Vacuum S?
