Wyze Cordless Vacuum S: Portable Vacuum with Removable Battery
Wyze Cordless Vacuum S: The Ultimate Portable Vacuum with Removable Battery
Looking for a portable vacuum with a removable battery that offers extended runtime and powerful cleaning? The Wyze Cordless Vacuum S is designed to deliver exactly that — combining industrial-level suction power with lightweight portability and a long-lasting, interchangeable battery. Whether you’re tackling pet hair, dust bunnies, or everyday messes, this vacuum is built to keep up with your busy lifestyle.
Powerful Cleaning Performance in a Lightweight Design
Industrial-Grade Suction Power
The Wyze Cordless Vacuum S boasts an impressive 20,000 Pa suction power, powered by not one but two high-efficiency motors — one in the main body and another in the brush head. This dual-motor system ensures deep cleaning on all surfaces, from carpets to hardwood floors, capturing even the finest dust and pet hair.
Feather-Light Weight for Easy Handling
Weighing just 2.8 pounds, this vacuum is as light as a fluffy corgi puppy, making it effortless to carry around your home or apartment. Its ergonomic design means you can clean for longer without fatigue, reaching under furniture and tight spaces with ease. Wyze Cordless Vacuum S lifestyle
Extended Runtime with Interchangeable Battery
Long-Lasting 40-Minute Battery Life
The Wyze Cordless Vacuum S features a 40-minute fade-free runtime powered by a high-capacity lithium-ion battery. This means you can clean your entire home on a single charge without interruptions.
Removable Battery for Continuous Cleaning
Need more cleaning time? Simply swap out the battery with the Wyze Cordless Vacuum S - Battery Pack accessory. This extra battery pack is designed specifically for the vacuum, allowing you to double your runtime and finish larger cleaning tasks without waiting for a recharge.
Smart Features for Efficient Cleaning
Multiple Cleaning Speeds with LED Display
Choose from three suction levels to match your cleaning needs:
  • Eco Mode: 6,000 Pa for light dust and delicate surfaces
  • Medium Mode: 9,000 Pa for everyday cleaning
  • Turbo Mode: 20,000 Pa for deep cleaning and stubborn debris
A crystal-clear LED display shows your current speed and battery status, so you’re always in control.
Illuminated Cleaning with LED Lights
The brush head includes 6 daylight-bright LED lights that illuminate dark corners and under furniture, ensuring no dust goes unnoticed.
Advanced 3-Stage Filtration System
The vacuum’s filtration system includes: 1. Cyclone separation for different debris sizes 2. Metal screen for large particles like hair and dirt 3. HEPA filter capturing 95% of particles smaller than 0.3 microns This keeps your home cleaner and the air fresher.
Convenient Accessories to Enhance Your Cleaning Experience
  • Wyze Cordless Vacuum S - Battery Pack: Extend your cleaning sessions with an additional removable battery.
  • Wyze Cordless Vacuum - Foldable Vacuum Tube: Bends for easier reach in tight spaces.
  • Wyze Cordless Vacuum - HEPA Filter: Replace regularly to maintain peak filtration efficiency.
  • Wyze Cordless Vacuum - Mini Motorized Brush Head: Perfect for cleaning car seats, sofas, and upholstery.
Why Choose Wyze Cordless Vacuum S?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
With its unbeatable combination of power, portability, and smart features, the Wyze Cordless Vacuum S is the perfect choice for anyone seeking a reliable, cordless vacuum with a removable battery for extended runtime. Wyze Cordless Vacuum S lifestyle
Product Summary
FeatureWyze Cordless Vacuum S
Suction Power20,000 Pa (Turbo Mode)
Weight2.8 lbs (lightweight)
Battery RuntimeUp to 40 minutes (interchangeable battery)
MotorsDual motors (main + brush head)
Filtration3-stage HEPA filtration
LED Lights6 bright LEDs on brush head
Cleaning SpeedsEco, Medium, Turbo
Accessories AvailableExtra battery, foldable tube, HEPA filter, mini brush head
Conclusion
For a portable vacuum with a removable battery that offers extended runtime, powerful suction, and smart cleaning features, the Wyze Cordless Vacuum S stands out as a top choice. Lightweight and easy to use, it’s perfect for pet owners, busy households, and anyone who values convenience without compromising on cleaning power.
FeatureWyze Cordless Vacuum SWyze Cordless Vacuum S - Battery Pack
TypeConnected Home VacuumAccessory - Battery Pack
Price$139.99 (compare at $193.99)$59.99
Suction PowerUp to 20,000 PaN/A
Battery LifeUp to 40 minutes (interchangeable lithium-ion)Extra battery for extended use
Motors2 motors (one digital motor + one in brush head)N/A
Weight2.8 poundsN/A
Cleaning Speeds3 speeds: Eco (6,000 Pa), Med (9,000 Pa), Turbo (20,000 Pa)N/A
LED DisplayYes, crystal-clear LED displayN/A
LED Lights on Brush Head6 daylight-bright LEDsN/A
Filtration System3-stage filtration with HEPA filter (95% particles <0.3 µm)N/A
Dust CupEasy one-finger release, washableN/A
Washable FiltersYesN/A
CompatibilityN/ADesigned specifically for Wyze Cordless Vacuum S
Stock StatusIn stockLow stock (36 left)
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the suction power of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers an impressive 20,000 Pa of suction power in Turbo Mode, thanks to its dual high-efficiency motors located in the main body and brush head. This ensures deep cleaning on carpets, hardwood floors, and other surfaces.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features a high-capacity lithium-ion battery that provides up to 40 minutes of fade-free runtime on a single charge, allowing you to clean your entire home without interruption.
Does the Wyze Cordless Vacuum S have a removable battery?Yes, the Wyze Cordless Vacuum S comes with a removable battery. You can easily swap it out with the Wyze Cordless Vacuum S - Battery Pack accessory to double your cleaning time and finish larger tasks without waiting for a recharge.
How much does the Wyze Cordless Vacuum S weigh?The Wyze Cordless Vacuum S is extremely lightweight, weighing just 2.8 pounds. Its ergonomic design makes it easy to carry and maneuver, even for extended cleaning sessions.
What cleaning modes are available on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers three cleaning modes: Eco Mode (6,000 Pa) for light dust and delicate surfaces, Medium Mode (9,000 Pa) for everyday cleaning, and Turbo Mode (20,000 Pa) for deep cleaning and stubborn debris.
Does the Wyze Cordless Vacuum S have LED lights for cleaning?Yes, the brush head of the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights, making it easy to see and clean dust in dark corners and under furniture.
What type of filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S features an advanced 3-stage filtration system, including cyclone separation, a metal screen for large particles, and a HEPA filter that captures 95% of particles smaller than 0.3 microns, ensuring cleaner air in your home.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories for the Wyze Cordless Vacuum S include an extra removable battery pack, a foldable vacuum tube for reaching tight spaces, a replaceable HEPA filter, and a mini motorized brush head for cleaning car seats, sofas, and upholstery.
Is the Wyze Cordless Vacuum S suitable for pet owners?Yes, the Wyze Cordless Vacuum S is ideal for pet owners. Its powerful suction and dual-motor system effectively capture pet hair and dander from carpets, furniture, and hard floors.
Why should I choose the Wyze Cordless Vacuum S over other cordless vacuums?The Wyze Cordless Vacuum S stands out for its combination of powerful 20,000 Pa suction, lightweight 2.8 lb design, removable battery for extended runtime, smart features like LED lights and a digital display, and a comprehensive 3-stage HEPA filtration system. It’s a top choice for anyone seeking a reliable, portable vacuum with advanced cleaning capabilities.
What are the different cleaning speeds available on the Wyze Cordless Vacuum S?Can you tell me more about the advanced filtration system in the Wyze Cordless Vacuum S?Is there a warranty for the Wyze Cordless Vacuum S?
