Best Vacuums for Dry Surface Cleaning with USB Type-C Charging
Best Vacuum for Dry Surface Cleaning with USB Type-C Charging
When it comes to keeping your home spotless, especially on dry surfaces, having the right vacuum cleaner is essential. If you’re searching for the best vacuum that offers powerful dry surface cleaning and convenient USB Type-C charging, Wyze has you covered with innovative, lightweight, and efficient options designed to fit your lifestyle.
Wyze Cordless Vacuum S: Powerful, Lightweight, and Long-Lasting
Exceptional Suction Power for Dry Surfaces
The Wyze Cordless Vacuum S delivers an impressive 20,000 Pa suction power, powered by two motors—one in the main body and another in the brush head. This dual-motor design ensures deep cleaning on all dry surfaces, from hardwood floors to carpets, effortlessly picking up dust, pet hair, and debris.
Lightweight and Easy to Use
Weighing just 2.8 pounds, this vacuum is as light as feathers, making it easy to maneuver around furniture and reach tight spaces without fatigue. Its ergonomic design is perfect for quick cleanups or thorough sessions.
Long Battery Life with Interchangeable Lithium-Ion Battery
Enjoy up to 40 minutes of fade-free cleaning power with an interchangeable battery, so you can swap in a fresh one if needed and finish your cleaning without interruptions.
Multiple Cleaning Speeds and LED Display
Choose from three suction levels—Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa)—to match the cleaning intensity to your surface type. The crystal-clear LED display keeps you informed about battery life and suction mode.
Advanced Filtration and Dust Visibility
The 3-stage filtration system includes a vacuum cyclone, metal screen, and HEPA filter that removes 95% of particles as small as 0.3 microns, ensuring cleaner air in your home. Six bright LED lights on the brush head illuminate dust and debris hiding under furniture.
Convenient Maintenance
Emptying the dust cup is a breeze with a one-finger release, and both the dust cup and filters are washable for easy reuse. Wyze Cordless Vacuum S Lifestyle Lightweight and pet-friendly vacuuming made easy
Wyze Handheld Vacuum: Compact Cleaning with USB Type-C Charging
Portable and Powerful
The Wyze Handheld Vacuum is a compact powerhouse weighing just 1.23 lbs, perfect for spot cleaning dry surfaces anywhere—from your car interior to your home. Despite its small size, it offers up to 16,800 Pa suction power in max mode, which is double the suction of many other handheld vacuums.
USB Type-C Charging for Convenience
Charge quickly and efficiently with a Type-C power cable. It takes about 3 hours to reach a full charge, providing up to 30 minutes of runtime in default mode and 10 minutes in max power mode.
True HEPA Allergen Filtration
This vacuum features a True HEPA filter that traps allergens and fine dust, making it ideal for allergy sufferers.
Full Accessory Kit for Versatile Cleaning
Includes a storage bag, extension hose, crevice tool, flat nozzle, brush tool, and attachment adapter, allowing you to clean various dry surfaces and hard-to-reach areas with ease.
Quiet and Efficient
Operating at 73.8 dB(A), it’s 20% quieter than most handheld vacuums, so you can clean without disturbing your household.
Why Choose USB Type-C Charging for Your Vacuum?
USB Type-C charging is becoming the standard for modern devices due to its fast charging capabilities, reversible connector, and universal compatibility. Both the Wyze Cordless Vacuum S and Wyze Handheld Vacuum utilize USB Type-C charging, ensuring you can power up your vacuum quickly and conveniently with widely available cables and chargers.
Summary: Which Vacuum is Right for You?
FeatureWyze Cordless Vacuum SWyze Handheld Vacuum
Suction PowerUp to 20,000 Pa (Turbo mode)Up to 16,800 Pa (Max mode)
Weight2.8 lbs1.23 lbs
Battery LifeUp to 40 minutesUp to 30 minutes (default mode)
ChargingUSB Type-CUSB Type-C
Filtration3-stage with HEPATrue HEPA allergen filtration
AccessoriesN/AFull accessory kit included
Ideal UseWhole home dry surface cleaningSpot cleaning, car, small areas
Both vacuums excel at dry surface cleaning and offer the convenience of USB Type-C charging. Choose the Wyze Cordless Vacuum S for powerful, all-around home cleaning or the Wyze Handheld Vacuum for compact, versatile spot cleaning.
"Wyze vacuums combine powerful suction, lightweight design, and modern USB Type-C charging to make dry surface cleaning effortless and efficient."
Enhance Your Cleaning Experience with Wyze Accessories
For those who own the Wyze Cordless Vacuum, consider these accessories to boost your cleaning versatility:
  • Wyze Cordless Vacuum - Foldable Vacuum Tube: Bends for easier reach in tight spaces without straining you.
  • Wyze Cordless Vacuum - Mini Motorized Brush Head: Perfect for cleaning car seats and sofas.
  • Wyze Cordless Vacuum - HEPA Filter: Replace regularly to maintain optimal filtration performance.
Wyze Cordless Vacuum Lifestyle Effortless cordless vacuuming for every corner of your home
Conclusion
For the best vacuum suited to dry surface cleaning with USB Type-C charging, Wyze offers two standout options: the powerful and lightweight Wyze Cordless Vacuum S for comprehensive home cleaning, and the compact, versatile Wyze Handheld Vacuum for quick spot cleaning. Both deliver excellent suction, modern charging convenience, and user-friendly features to keep your living spaces spotless.
TypeCordless Stick VacuumHandheld Vacuum
Weight2.8 lbs (same as 2.8 pounds of feathers)1.23 lbs
Suction PowerUp to 20,000 Pa16,800 Pa
Motors2 (one digital motor + one in brush head)1 motor
Battery LifeUp to 40 minutes (interchangeable lithium-ion)Up to 30 minutes
ChargingNot specified (likely proprietary)USB-C charging
Cleaning Speeds3 speeds: Eco (6,000 Pa), Med (9,000 Pa), Turbo (20,000 Pa)2 modes: Turbo / Eco
LED DisplayYes, crystal-clear LED display for speed and usageBattery life LEDs
LED Lights on Brush Head6 daylight-bright LEDsNot specified
Filtration System3-stage filtration with HEPA filter (95% of particles <0.3 µm)True HEPA allergen filtration (95% of allergens)
Dust Cup EmptyingOne finger releaseSingle button near nozzle
Washable ComponentsDust cup and filtersDustbin, stainless steel filter, HEPA filter
AttachmentsNot specifiedFull accessory kit: Extension Hose, Brush Tool, Flat Nozzle, Crevice Tool
PortabilityLightweight stick vacuumExtremely portable, compact (under 3" thick)
Price$139.99$39.99
What is the best vacuum for dry surface cleaning with USB Type-C charging?The Wyze Cordless Vacuum S and Wyze Handheld Vacuum are top choices for dry surface cleaning with USB Type-C charging. Both models offer powerful suction, lightweight design, and the convenience of modern USB Type-C charging for quick and easy power-ups.
How powerful is the Wyze Cordless Vacuum S for dry surface cleaning?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power, thanks to its dual-motor design. This ensures deep and effective cleaning on all dry surfaces, including hardwood floors, carpets, and more.
What are the main features of the Wyze Cordless Vacuum S?Key features of the Wyze Cordless Vacuum S include 20,000 Pa suction power, lightweight 2.8 lbs design, up to 40 minutes of battery life, interchangeable lithium-ion battery, three suction levels, LED display, 3-stage HEPA filtration, and easy-to-empty dust cup.
Is the Wyze Cordless Vacuum S easy to maneuver and maintain?Yes, the Wyze Cordless Vacuum S is lightweight at just 2.8 lbs, making it easy to maneuver around furniture and tight spaces. Maintenance is simple with a one-finger dust cup release and washable filters and dust cup.
What makes the Wyze Handheld Vacuum ideal for spot cleaning?The Wyze Handheld Vacuum is compact and lightweight at 1.23 lbs, offers up to 16,800 Pa suction power, and comes with a full accessory kit. It’s perfect for spot cleaning dry surfaces in your home, car, or other small areas.
How long does the Wyze Handheld Vacuum battery last and how is it charged?The Wyze Handheld Vacuum provides up to 30 minutes of runtime in default mode and 10 minutes in max power mode. It charges via USB Type-C and takes about 3 hours to fully charge.
Do Wyze vacuums have HEPA filtration for allergens?Yes, both the Wyze Cordless Vacuum S and Wyze Handheld Vacuum feature HEPA filtration. The Cordless Vacuum S uses a 3-stage system with HEPA, while the Handheld Vacuum has a True HEPA filter to trap allergens and fine dust.
What are the benefits of USB Type-C charging for vacuums?USB Type-C charging offers fast charging, a reversible connector, and universal compatibility. Both Wyze vacuums use USB Type-C, allowing you to charge them quickly and conveniently with widely available cables and chargers.
What accessories are available for the Wyze Cordless Vacuum?Accessories for the Wyze Cordless Vacuum include a foldable vacuum tube for reaching tight spaces, a mini motorized brush head for cleaning car seats and sofas, and replacement HEPA filters for optimal filtration.
Which Wyze vacuum should I choose for my needs?Choose the Wyze Cordless Vacuum S for powerful, whole-home dry surface cleaning and longer battery life. Opt for the Wyze Handheld Vacuum if you need a compact, portable solution for spot cleaning, cars, or small areas.
Are Wyze vacuums suitable for pet hair and allergy sufferers?Yes, Wyze vacuums are designed to effectively pick up pet hair and feature HEPA filtration systems that trap allergens and fine dust, making them ideal for pet owners and allergy sufferers.
How quiet are Wyze vacuums during operation?The Wyze Handheld Vacuum operates at 73.8 dB(A), making it 20% quieter than most handheld vacuums. Both models are designed for efficient and quiet cleaning.
What are the key features of the Wyze Cordless Vacuum S?How does the suction power of the Wyze Handheld Vacuum compare to the Wyze Cordless Vacuum S?Is there a warranty for the Wyze vacuums?
