Wyze Cordless Vacuum S: The Ultimate Fast-Charging Vacuum for Busy Lifestyles
For those with hectic schedules, a vacuum that charges quickly and cleans efficiently is a must-have. The
Wyze Cordless Vacuum S is designed to meet the demands of busy homes, combining powerful suction, lightweight design, and a fast charging time to keep your living space spotless without slowing you down.
Powerful Suction and Lightweight Design
The Wyze Cordless Vacuum S packs an impressive punch with its
20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on all surfaces. Whether you’re tackling pet hair, dust, or debris, this vacuum’s dual motors deliver consistent and strong suction.
Suction Power:
- Turbo Mode: 20,000 Pa
- Medium Mode: 9,000 Pa
- ECO Mode: 6,000 Pa
- Weight: Only 2.8 lbs for the main unit, making it as light as 2.8 pounds of feathers
- Dust Cup Volume: 0.7 liters, allowing for longer cleaning sessions without frequent emptying
This lightweight design makes it easy to maneuver around furniture and carry between rooms, perfect for quick cleanups or deep cleaning sessions.
Effortless cleaning around pets and furniture
Fast Charging and Long Battery Life
Busy lifestyles demand appliances that keep up. The Wyze Cordless Vacuum S features a
6-cell lithium-ion battery with a capacity of 12,000mAh (2,000mAh*6), providing up to
40 minutes of runtime in ECO mode. When you need a quick recharge, the vacuum fully charges in just
4-6 hours via AC charging, so it’s ready when you are.
Battery Runtime:
- ECO Mode: 40 minutes
- Medium Mode: 23 minutes
- Turbo Mode: 10 minutes
- Charging Time: 4-6 hours to 100%
- Rated Power Output: 300 W
This balance of runtime and fast charging means less downtime and more cleaning efficiency, ideal for busy households.
Advanced Features for a Superior Cleaning Experience
The Wyze Cordless Vacuum S is packed with smart features that enhance usability and cleaning performance:
- LED Screen: Displays battery life and suction mode for easy monitoring
- 3-Stage Filtration System: Captures fine dust and allergens, improving air quality
- 6 Daylight-Bright LED Lights: Illuminate dark corners and under furniture for thorough cleaning
- Attachments Included: Crevice tool, floor brush, HEPA filter, dust cap, and more for versatile cleaning needs
Bright LED lights reveal hidden dust on hardwood floors
Accessories to Extend and Enhance Your Vacuum
To keep your Wyze Cordless Vacuum S performing at its best, consider these compatible accessories designed specifically for it:
- Wyze Cordless Vacuum S - Battery Pack: Need extra juice? Swap in a fresh battery for extended cleaning sessions.
- Wyze Cordless Vacuum S - Charger: Replacement charger to ensure your vacuum is always ready.
- Wyze Cordless Vacuum - Foldable Vacuum Tube: Bends for hard-to-reach areas, reducing strain.
- Wyze Cordless Vacuum - HEPA Filter (2 Pack): Replace regularly to maintain optimal filtration.
- Wyze Cordless Vacuum - Mini Motorized Brush Head: Perfect for cleaning car seats and sofas.
These accessories help customize your cleaning experience and maintain peak vacuum performance.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
— Wyze Cordless Vacuum S
Why Choose Wyze Cordless Vacuum S?
- Fast charging with up to 40 minutes runtime fits perfectly into busy schedules.
- Powerful suction with dual motors tackles all types of messes.
- Lightweight and ergonomic for easy handling and quick cleanups.
- Smart features like LED display and bright brush lights improve usability.
- Versatile attachments and accessories for every cleaning need.
Make your cleaning routine faster, easier, and more effective with the Wyze Cordless Vacuum S — the smart choice for busy lifestyles.
What is the suction power of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers powerful suction with three modes: 20,000 Pa in Turbo Mode, 9,000 Pa in Medium Mode, and 6,000 Pa in ECO Mode. This ensures deep cleaning on all surfaces, including pet hair, dust, and debris.How long does the Wyze Cordless Vacuum S battery last?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode, making it ideal for both quick cleanups and longer cleaning sessions.How fast does the Wyze Cordless Vacuum S charge?
The Wyze Cordless Vacuum S fully charges in just 4-6 hours using its AC charger, so it’s ready for your next cleaning session with minimal downtime.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, making it lightweight and easy to maneuver around your home.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a 0.7-liter dust cup, allowing for longer cleaning sessions without frequent emptying.What advanced features does the Wyze Cordless Vacuum S offer?
The Wyze Cordless Vacuum S includes an LED screen for battery and mode monitoring, a 3-stage filtration system to capture fine dust and allergens, and 6 daylight-bright LED lights to illuminate dark corners and under furniture.What attachments and accessories are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a crevice tool, floor brush, HEPA filter, dust cap, and more. Additional compatible accessories include a battery pack, replacement charger, foldable vacuum tube, HEPA filter (2 pack), and a mini motorized brush head.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is ideal for pet owners. Its powerful suction and dual motors effectively pick up pet hair, while the 3-stage filtration system helps capture allergens.How does the 3-stage filtration system in the Wyze Cordless Vacuum S work?
The 3-stage filtration system in the Wyze Cordless Vacuum S captures fine dust and allergens, improving air quality in your home and ensuring a thorough clean.Why should I choose the Wyze Cordless Vacuum S for my home?
The Wyze Cordless Vacuum S is designed for busy lifestyles, offering fast charging, long battery life, powerful suction, lightweight design, smart features, and versatile attachments to make cleaning faster, easier, and more effective.
