Wyze Cordless Vacuum S: Robust, Lightweight & Powerful for Daily Use
Discover the Wyze Cordless Vacuum S: Robust Engineering for Frequent Use
When it comes to a cordless vacuum that combines powerful suction, lightweight design, and smart engineering for frequent use, the Wyze Cordless Vacuum S stands out as a top choice. Designed for those who demand efficiency and convenience in their cleaning routine, this vacuum offers a perfect balance of performance and portability. Wyze Cordless Vacuum S lifestyle Effortless vacuuming with pets around, showcasing the Wyze Cordless Vacuum S in action.
Powerful Suction and Lightweight Design
Exceptional Suction Power
The Wyze Cordless Vacuum S delivers an impressive 20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on all surfaces. It also offers multiple suction modes to suit your cleaning needs:
  • Turbo Mode: 20,000 Pa (10 minutes runtime)
  • Medium Mode: 9,000 Pa (23 minutes runtime)
  • ECO Mode: 6,000 Pa (40 minutes runtime)
This range allows you to optimize battery life while maintaining powerful cleaning performance.
Featherlight Weight for Easy Handling
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as 2.8 pounds of feathers. This makes it incredibly easy to maneuver around furniture, stairs, and tight spaces without fatigue.
Advanced Engineering Features
  • Dual motors for enhanced suction and efficiency
  • 3-stage filtration system including a HEPA filter to trap fine dust and allergens
  • 6 daylight-bright LED lights on the brush head to illuminate hidden dirt
  • A clear LED screen to monitor battery and mode status
Dimensions are compact at 12.4 x 4.5 x 8.7 inches (main unit) and extend to 41.1 inches when assembled, making storage and use convenient.
Long-Lasting Battery and Convenient Accessories
Interchangeable Lithium-Ion Battery
The vacuum is powered by a 6-cell lithium-ion battery (2,000mAh*6), providing up to 40 minutes of runtime in ECO mode. When you need extra cleaning time, the Wyze Cordless Vacuum S - Battery Pack accessory is available to double your runtime and keep you cleaning without interruption.
Quick and Easy Charging
Charging takes 4-6 hours via AC charging with a rated voltage of DC 21.6 V. For added convenience, a replacement charger is also available to ensure your vacuum is always ready to go.
Useful Attachments for Every Cleaning Task
Included with the vacuum are essential tools such as:
  • Crevice Tool for tight corners
  • Floor Brush for hard floors and carpets
  • Dust Cap and HEPA Filter for maintenance
  • Standard Tube for extended reach
Additional accessories like the Foldable Vacuum Tube bend to reach awkward spaces without strain, and the Mini Motorized Brush Head is perfect for cleaning car seats and sofas.
Clean Smarter, Live Better
The Wyze Cordless Vacuum S is designed to fit seamlessly into your lifestyle, especially if you have pets or frequently clean various surfaces. Its quiet operation at 65 dBA in Turbo Mode means you can clean without disturbing your household.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze
With its steel grey body accented by Wyze green, this vacuum not only performs well but looks sleek in your home. Wyze Cordless Vacuum S lifestyle Lightweight and powerful, the Wyze Cordless Vacuum S is perfect for everyday cleaning.
Maintenance and Replacement Parts
To keep your Wyze Cordless Vacuum S operating at peak performance, regular maintenance and replacement parts are essential:
  • HEPA Filter Replacement (2 Pack): Maintain air quality and suction efficiency by replacing filters regularly.
  • Replacement Charger: Ensure your vacuum is always charged and ready.
  • Battery Pack: Extend your cleaning sessions with an additional battery.
  • Foldable Vacuum Tube: Replace or upgrade for flexible cleaning angles.
  • Mini Motorized Brush Head: Ideal for upholstery and car interiors.
Why Choose Wyze Cordless Vacuum S?
  • Robust engineering with dual motors and powerful suction
  • Lightweight and ergonomic for frequent use without fatigue
  • Long battery life with quick recharge and optional extra battery
  • Versatile attachments for all cleaning needs, including pet hair and upholstery
  • Smart features like LED display and bright brush head lights
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — engineered to keep up with your busy lifestyle and deliver spotless results every time. Wyze Cordless Vacuum S lifestyle Effortless cleaning on hardwood floors with the Wyze Cordless Vacuum S.
Summary of Wyze Cordless Vacuum S and Accessories
ProductKey FeaturePrice (USD)
Wyze Cordless Vacuum S20,000 Pa suction, 40 min runtime, 2.8 lbs139.99
Battery PackExtra battery for extended use59.99
Replacement ChargerKeep your vacuum charged4.99
Foldable Vacuum TubeFlexible cleaning angles15.99
HEPA Filter (2 Pack)Maintain filtration efficiency15.99
Mini Motorized Brush HeadUpholstery and car cleaning29.99
Upgrade your cleaning routine with the Wyze Cordless Vacuum S and its range of accessories designed for durability, convenience, and powerful performance.
ProductTypePrice (USD)CompatibilityKey FeaturesWeight / DimensionsNotes
Wyze Cordless Vacuum SConnected Home139.99Wyze Cordless Vacuum S20,000 Pa suction, 40-min battery, 2 motors, 2.8 lbs, 3-speed settings, 6 LED lights, HEPA filter2.8 lbsInterchangeable battery, washable filters
Wyze Cordless Vacuum S - Battery PackAccessories59.99Wyze Cordless Vacuum SExtra interchangeable battery for extended useNot specifiedLow stock (36 left)
Wyze Cordless Vacuum S - ChargerReplacement Part4.99Wyze Cordless Vacuum SReplacement chargerNot specified30-day hassle-free returns
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Wyze Cordless VacuumFlexible tube attachment for easier cleaningNot specifiedBends for convenience
Wyze Cordless Vacuum - HEPA FilterAccessories15.99 (2 Pack)Wyze Cordless Vacuum3-stage filtration replacement filtersNot specifiedReplace regularly
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99Wyze Cordless VacuumMotorized brush for car seats and sofas6 x 5.5 x 5 inchesFor detailed cleaning
What is the suction power of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, ensuring deep cleaning on all surfaces. It also offers Medium Mode (9,000 Pa) and ECO Mode (6,000 Pa) to optimize battery life and cleaning performance.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. You can double your cleaning time by using an additional Wyze Cordless Vacuum S Battery Pack.
How much does the Wyze Cordless Vacuum S weigh?The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and it weighs 4.9 lbs when fully assembled, making it lightweight and easy to maneuver.
What filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter, to trap fine dust and allergens and maintain clean air quality in your home.
What accessories are included with the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S comes with a crevice tool, floor brush, dust cap, HEPA filter, and standard tube. Additional accessories like the Foldable Vacuum Tube and Mini Motorized Brush Head are available for specialized cleaning tasks.
How long does it take to charge the Wyze Cordless Vacuum S?Charging the Wyze Cordless Vacuum S takes approximately 4-6 hours using the included AC charger with a rated voltage of DC 21.6 V.
Is the Wyze Cordless Vacuum S suitable for pet owners?Yes, the Wyze Cordless Vacuum S is ideal for pet owners. Its powerful suction, HEPA filtration, and specialized attachments like the Mini Motorized Brush Head make it effective at removing pet hair and dander from various surfaces.
What are the dimensions of the Wyze Cordless Vacuum S?The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches, and it extends to 41.1 inches when fully assembled, making it compact and easy to store.
How quiet is the Wyze Cordless Vacuum S during operation?The Wyze Cordless Vacuum S operates at a quiet 65 dBA in Turbo Mode, allowing you to clean without disturbing your household.
What replacement parts are available for the Wyze Cordless Vacuum S?Available replacement parts for the Wyze Cordless Vacuum S include HEPA filters (2 pack), replacement charger, battery pack, foldable vacuum tube, and mini motorized brush head to keep your vacuum performing at its best.
What makes the Wyze Cordless Vacuum S different from other cordless vacuums?The Wyze Cordless Vacuum S stands out with its robust engineering, dual motors, powerful suction, lightweight design, long battery life, versatile attachments, smart features like an LED display and bright brush head lights, and affordable price.
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does it take to charge the Wyze Cordless Vacuum S?Is there a warranty for the Wyze Cordless Vacuum S?
