20ft Wyze Cam USB Extension Cable: The Best Cord Solution for Rearranging Furniture in Large Spaces
The Ultimate Cord Solution for Wyze Cam: Rearranging Furniture in Large Spaces
When rearranging furniture in a large space, ensuring your Wyze Cam remains powered and optimally placed can be a challenge. Short cables can limit your camera’s placement, but with the right extension solution, you can enjoy flexibility and uninterrupted security coverage. Discover the best products for extending your Wyze Cam’s reach and maintaining seamless surveillance, even in the largest rooms.
1. Wyze Cam USB Extension Cable - 20ft: Extend Your Reach
Say goodbye to the limitations of short cables! The Wyze Cam USB Extension Cable - 20ft is designed specifically for users who need extra length to power their Wyze Cams across large spaces or when rearranging furniture.
Key Features:
  • 20ft Length: Perfect for large rooms, open-plan spaces, or when your power outlet is far from your ideal camera location.
  • Wide Compatibility: Works with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Easy Installation: Plug-and-play design makes setup a breeze.
  • Weather Resistant: IP67 rating ensures durability for both indoor and outdoor use.
  • Robust Build: 18 AWG wire for reliable power delivery, supporting up to 5V/2A.
"Say goodbye to short cables and enjoy the freedom of a 20ft cable. This 20ft USB extension cable works with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto."
2. Wyze Cam OG: Flexible Security for Any Space
The Wyze Cam OG is the next generation of Wyze Cam, offering advanced features and flexible installation options—perfect for large spaces where you may need to move your camera as you rearrange furniture.
Standout Specs:
  • 120° Field of View: Capture the big picture, even in expansive rooms.
  • Built-In Spotlight & Siren: Deter intruders with a 40-lumen spotlight and 90-decibel siren.
  • Indoor/Outdoor Ready: IP65 weather resistance for versatile placement.
  • Enhanced Audio: Upgraded two-way audio for clear communication.
  • Quick Notifications: 3X faster motion alerts keep you informed in real time.
  • Local Storage: Supports up to 256GB microSD for continuous recording.
"Independently amazing. Upside down or right side up, each camera operates on its own to cover every angle of any space."
3. Wyze Cam v4: High-Resolution Coverage for Large Areas
For those seeking the latest in camera technology, the Wyze Cam v4 delivers unmatched security and flexibility, making it ideal for large spaces and dynamic room layouts.
Why Choose Wyze Cam v4?
  • 2.5K QHD Resolution: Crystal-clear video for detailed monitoring.
  • Enhanced Color Night Vision: See vivid details even in low light.
  • Motion-Activated Spotlight: 72-lumen spotlight for added security.
  • Wi-Fi 6 Support: Faster, more reliable connectivity.
  • Flexible Mounting: Stand, wall, ceiling, or magnetic adhesive options.
  • Weatherproof: IP65 rating for both indoor and outdoor use.
  • Expandable Storage: Supports microSD cards up to 512GB.
"Get unmatched security with Wyze Cam v4. Crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and motion-activated spotlight keep your home safe day or night."
Choosing the Right Cord Solution for Your Wyze Cam
When rearranging furniture in a large space, the Wyze Cam USB Extension Cable - 20ft is the essential accessory to ensure your Wyze Cam OG or Wyze Cam v4 stays powered and optimally placed. Its robust build and weather resistance make it suitable for any environment, while its compatibility with multiple Wyze Cam models ensures you have the flexibility you need.
Quick Tips:
  • Plan Your Layout: Before moving furniture, map out your camera’s new location and measure the distance to the nearest power outlet.
  • Use the 20ft Extension: Easily bridge the gap between your camera and power source, even in the largest rooms.
  • Enjoy Seamless Security: With extended reach, your Wyze Cam can continue to monitor your space without interruption.
Conclusion
Maximize your Wyze Cam’s potential in any large space with the 20ft USB extension cable. Whether you’re using the feature-rich Wyze Cam OG or the high-resolution Wyze Cam v4, you’ll enjoy flexible placement, reliable power, and peace of mind—no matter how you rearrange your furniture.
Products Featured:
  • Wyze Cam USB Extension Cable - 20ft
  • Wyze Cam OG
  • Wyze Cam v4
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OGWyze Cam v4
Product TypeAccessory (USB Extension Cable)CameraCamera
Main FunctionExtends power reach for Wyze CamsSmart security cameraSmart security camera
Cable Length20ft (6m)N/A6ft (1.8m)
CompatibilityWyze Cam v2/v3/v3 Pro/v4, Pan v2/v3, OGNot specified in provided inventoryWyze Cam v2/v3/v3 Pro/v4, Pan v2/v3, OG
Weather ResistanceIP67IP65 (OG Telephoto)IP65
Operating Temperature-30°C to 50°C / -22°F to 122°FNot specified-4°F to 122°F (-20°C to 50°C)
Power Output5V 2A (charge only)Not specified5V/1A (indoor adapter), Outdoor adapter sold separately
Video ResolutionN/A1080p HD (OG Telephoto)2.5K QHD (2560x1440)
Night VisionN/AColor Night Vision (OG Telephoto)Enhanced Color Night Vision
Local StorageN/ASupports microSD card (OG Telephoto)microSD card up to 512GB
Smart Assistant CompatibilityN/ANot specifiedAlexa, Google Assistant, IFTTT
Included in Box1x 20ft USB Type A Male to Female CableNot specifiedWyze Cam v4, Quick Start Guide, Wall Mount Plate, Tape, Screw Kit, Indoor USB Power Adapter, 6ft USB Cable
Price$7.99Not specified$100.00
What is the best way to extend the power reach of my Wyze Cam in a large room?The Wyze Cam USB Extension Cable - 20ft is the ideal solution for extending your Wyze Cam’s power reach in large rooms. Its 20ft length allows you to place your camera wherever you need, even if the nearest power outlet is far away.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable - 20ft is weather resistant with an IP67 rating, making it suitable for both indoor and outdoor use.
How easy is it to install the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable features a plug-and-play design, making installation quick and easy without the need for special tools.
What are the key features of the Wyze Cam OG for large spaces?The Wyze Cam OG offers a 120° field of view, built-in 40-lumen spotlight, 90-decibel siren, IP65 weather resistance, upgraded two-way audio, fast motion alerts, and supports up to 256GB microSD for local storage—making it perfect for large spaces.
What makes the Wyze Cam v4 ideal for monitoring large areas?The Wyze Cam v4 features 2.5K QHD resolution, enhanced color night vision, a 72-lumen motion-activated spotlight, Wi-Fi 6 support, flexible mounting options, IP65 weatherproofing, and expandable storage up to 512GB, making it perfect for large and dynamic spaces.
How do I choose the right cord solution for my Wyze Cam when rearranging furniture?When rearranging furniture in a large space, use the Wyze Cam USB Extension Cable - 20ft to ensure your camera remains powered and optimally placed. Its robust build and wide compatibility make it suitable for various Wyze Cam models and environments.
Can I use the Wyze Cam OG and Wyze Cam v4 both indoors and outdoors?Yes, both the Wyze Cam OG and Wyze Cam v4 are designed for indoor and outdoor use, featuring weather resistance (IP65 rating) for versatile placement.
What storage options are available for Wyze Cam OG and Wyze Cam v4?The Wyze Cam OG supports up to 256GB microSD cards for continuous local recording, while the Wyze Cam v4 supports microSD cards up to 512GB for expanded storage.
What tips can help me maintain seamless security coverage when moving furniture in large spaces?Plan your camera layout before moving furniture, measure the distance to the nearest power outlet, use the 20ft USB extension cable to bridge gaps, and ensure your Wyze Cam is positioned for optimal coverage and uninterrupted power.
What are the key features of the Wyze Cam OG?Can the Wyze Cam v4 be used outdoors?Do you have any ongoing sales or discounts for Wyze products?
