20ft Wyze Cam USB Extension Cable—Keep Cameras Safe from Pets
Extend Your Wyze Cam Placement with the 20ft USB Extension Cable
If you want to position your Wyze Cam away from curious pets or simply need more flexibility in camera placement, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable extends your camera’s reach by 20 feet, allowing you to mount your Wyze Cam in the ideal spot without worrying about limited cable length.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Length: A generous 20-foot cable length gives you freedom to place your camera far from power outlets or out of reach of pets.
  • Easy Setup: Simply plug the extension cable between your Wyze Cam and its power source—no complicated installation required.
  • Durability: Designed to maintain stable power and data transfer over the extended length.
Say goodbye to short cables and enjoy the freedom to position your Wyze Cam exactly where you need it, whether high on a wall, across a room, or outside within range.
Enhance Your Wyze Cam Setup with Additional Accessories
Wyze L-Shaped Micro USB Adapter
For users with Wyze Cam Pan v3 or Cam v3 Pro, the Wyze L-Shaped Micro USB Adapter is a handy accessory that helps you connect your camera to power sources more conveniently. This adapter works with the Wyze Outdoor Power Adapter v1 or other Micro USB cables, allowing for flexible cable routing and better placement options.
  • Compact L-shape design reduces cable strain and fits into tight spaces.
  • Compatible with Wyze Cam Pan v3 and Cam v3 Pro for seamless power connection.
  • Affordable and easy to use, priced at $5.99.
Why Use a USB Extension Cable for Your Wyze Cam?
Positioning your Wyze Cam away from pets or other obstacles is crucial for optimal surveillance and camera longevity. Pets can accidentally knock over or damage cameras placed within their reach. Using a 20ft USB extension cable allows you to:
  • Mount your camera out of reach of pets and children.
  • Place the camera in the best vantage point for wider coverage.
  • Avoid unsightly cable runs by routing cables discreetly along walls or ceilings.
  • Extend outdoor camera placement options when paired with weather-resistant Wyze Cams.
Recommended Wyze Cameras Compatible with the USB Extension Cable
Wyze Cam v4
The Wyze Cam v4 is a versatile, high-quality security camera that pairs perfectly with the 20ft USB extension cable for flexible placement.
  • Video Quality: 2.5K QHD resolution with 8x digital zoom.
  • Night Vision: Color night vision with 4 IR LEDs and 2 white spotlight LEDs.
  • Field of View: Wide 115.8° diagonal field of view.
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic wall mount with adhesive.
  • Weather Resistance: Rated IP65 for outdoor use.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6.
  • Additional Features: Built-in siren, two-way talk, noise echo cancellation, and Alexa/Google Assistant integration.
Using the 20ft USB extension cable with the Wyze Cam v4 lets you place this advanced camera exactly where you need it, even in hard-to-reach or pet-proof locations. Wyze Cam v4 mounted outdoors Alt text: Wyze Cam v4 mounted outdoors on a wall, positioned high away from pets
Summary
For anyone looking to extend the reach of their Wyze Cam and keep it safely out of reach from curious pets, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. It offers the freedom to position your camera optimally without compromising power or connectivity. Pair it with the Wyze L-Shaped Micro USB Adapter for even more flexible setups, especially with Pan v3 and v3 Pro models. Whether you own the latest Wyze Cam v4 or earlier models, this extension cable enhances your home security setup by enabling better camera placement and protection.
FeatureWyze Cam USB Extension Cable - 20ftWyze L-Shaped Micro USB AdapterWyze Cam v4
TypeAccessoriesReplacement PartsCamera
Compatible ModelsWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam Pan v3, Cam v3 Pro (with Outdoor Power Adapter v1 or Micro USB cable)N/A
Cable Length20 ftN/A6-Foot Flat micro USB to USB-A
Price$7.99$5.99$100.00
DescriptionUSB extension cable to extend reachL-shaped Micro USB adapter for better cable management2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, Wi-Fi 6, Alexa & Google Assistant compatible
Power Adapter InputN/AN/A110-240 V (AC/DC)
Power Adapter OutputN/AN/AIndoor 5V/1A
Video ResolutionN/AN/A2.5K QHD (2560x1440)
Field of ViewN/AN/ADFOV 115.8°, HFOV 98.5°, VFOV 53.1°
SensorN/AN/ACMOS Starlight Sensor
Night VisionN/AN/A4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
Weather ResistanceN/AN/AIP65
Mounting OptionsN/AN/AStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
Warranty30-day hassle-free returns30-day hassle-free returns1-Year
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam by 20 feet, allowing you to position your camera in the ideal location, away from pets, children, or limited power outlets. This accessory provides greater flexibility in camera placement for optimal surveillance coverage.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models, ensuring seamless integration with a wide range of Wyze cameras.
How do I install the Wyze Cam USB Extension Cable?Installation is simple—just plug the extension cable between your Wyze Cam and its power source. No complicated setup or tools are required, making it easy to extend your camera’s reach in minutes.
Can I use the Wyze Cam USB Extension Cable outdoors?Yes, you can use the Wyze Cam USB Extension Cable outdoors when paired with weather-resistant Wyze Cams, such as the Wyze Cam v4, which is rated IP65 for outdoor use. Ensure all connections are protected from direct exposure to the elements for optimal performance.
What are the benefits of using a USB extension cable with my Wyze Cam?Using a USB extension cable allows you to mount your Wyze Cam out of reach of pets and children, place it in the best vantage point for wider coverage, avoid unsightly cable runs, and extend outdoor placement options for enhanced home security.
What is the Wyze L-Shaped Micro USB Adapter and when should I use it?The Wyze L-Shaped Micro USB Adapter is a compact accessory designed for Wyze Cam Pan v3 and Cam v3 Pro. It helps connect your camera to power sources in tight spaces, reduces cable strain, and allows for flexible cable routing. It is especially useful when paired with the Wyze Outdoor Power Adapter v1 or other Micro USB cables.
Is the Wyze Cam USB Extension Cable durable and reliable?Yes, the Wyze Cam USB Extension Cable is built for durability and is designed to maintain stable power and data transfer over its extended 20-foot length, ensuring reliable performance for your Wyze Cam.
How does the Wyze Cam v4 benefit from the 20ft USB Extension Cable?The Wyze Cam v4, with its advanced features like 2.5K QHD resolution, color night vision, and IP65 weather resistance, can be optimally placed using the 20ft USB Extension Cable. This allows you to mount the camera in hard-to-reach or pet-proof locations for enhanced security and coverage.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze L-Shaped Micro USB Adapter with my Wyze Cam?Do you have any deals, ongoing sales, discounts, or promotions available for the Wyze Cam accessories?
