20ft Sturdy Wyze Cam USB Extension Cable for Overhead Mounting
Sturdy Power Cable Solutions for Wyze Cam with Overhead Mounting
When mounting your Wyze Cam overhead, having a reliable and sturdy power cable is essential to ensure continuous operation and flexibility in placement. Whether you need to extend your cable length or require weather-resistant power options for outdoor setups, Wyze offers accessories tailored to meet these needs.
Wyze Cam USB Extension Cable - 20ft
Extend Your Reach with Confidence
The Wyze Cam USB Extension Cable - 20ft is the perfect solution for overcoming short cable limitations. This 20-foot long USB extension cable allows you to position your Wyze Cam exactly where you need it, including overhead mounting spots that are farther from power outlets.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Pan v2/v3, and OG series cameras.
  • Length: 20 feet (6.1 meters) for maximum flexibility.
  • Durability: Designed to maintain stable power and data transmission over extended distances.
  • Ease of Use: Simple plug-and-play setup with USB connectors.
This cable is ideal for indoor overhead mounting where you want to keep your camera discreet yet fully powered without worrying about cable length restrictions.
Wyze Outdoor Power Adapter
Weather-Resistant Power for Outdoor and Overhead Use
For outdoor or exposed overhead installations, the Wyze Outdoor Power Adapter offers a robust and weatherproof power solution. Rated IP67, this adapter is built to withstand rain, snow, and harsh weather conditions, ensuring your Wyze Cam stays powered no matter the environment.
  • Weather Resistance: IP67 rating for protection against dust and water immersion.
  • Compatibility: Supports Wyze Cam v3, v4, Pan v3, OG series, and Battery Cam Pro (with appropriate adapters).
  • Cable Lengths: 12.5 ft main cable plus additional AC and DC cable lengths for flexible installation.
  • Included Accessories: Comes with wire clips, screws, anchors, and a weatherproof L-shaped Micro USB adapter for neat and secure overhead mounting.
  • Operating Temperature: Works reliably from -30°C to 50°C (-22°F to 122°F).
This adapter is essential for overhead mounting outdoors, providing peace of mind that your camera’s power source is protected from the elements.
Wyze Cam Pan v3 USB Cable - Replacement Option
Reliable Replacement for Pan v3 Cameras
If you own a Wyze Cam Pan v3 and need a sturdy USB cable for overhead mounting or replacement, the Wyze Cam Pan v3 USB Cable is a cost-effective and reliable choice.
  • Designed Specifically for Pan v3: Ensures perfect fit and power delivery.
  • Affordable: Priced economically for easy replacement.
  • Stock Availability: Ready to ship for quick installation.
While shorter than the 20ft extension cable, this cable is
FeatureWyze Cam USB Extension Cable - 20ftWyze Outdoor Power AdapterWyze Cam Pan v3 USB Cable
Product TypeUSB Extension CableOutdoor Power Adapter with L-shaped Micro USB AdapterReplacement USB Cable
Compatible DevicesWyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG, OG TelephotoWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Wyze Cam Pan v3
Cable Length20 ftNot specifiedNot specified (standard USB cable length)
Connector TypeUSB Type A Male to FemaleMicro USB (L-shaped adapter included)Micro USB
Weather ResistanceIP67IP67Not specified
Power Output5V 2A5V/2000mANot specified
Operating Temperature-30°C to 50°C (-22°F to 122°F)Not specifiedNot specified
Price$7.99$14.99 - $19.99 (varies by variant)$1.99
Quantity Available111
Return PolicyNot specified30-day hassle-free returns30-day hassle-free returns
NotesExtends USB cable length for Wyze camerasRequired for outdoor use of Pan v3 and v3 Pro with adapterReplacement cable for Pan v3
What is the best power cable solution for overhead mounting my Wyze Cam?For overhead mounting, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. It provides a long 20-foot reach, allowing you to position your Wyze Cam exactly where you need it, even if the power outlet is far away. This cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, and OG series cameras.
Is there a weather-resistant power adapter for outdoor Wyze Cam installations?Yes, the Wyze Outdoor Power Adapter is designed for outdoor and exposed overhead installations. It has an IP67 rating, making it weatherproof and capable of withstanding rain, snow, and harsh conditions. It supports Wyze Cam v3, v4, Pan v3, OG series, and Battery Cam Pro (with the right adapters).
How long is the Wyze Cam USB Extension Cable, and which cameras is it compatible with?The Wyze Cam USB Extension Cable is 20 feet (6.1 meters) long, providing maximum flexibility for camera placement. It is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Pan v2/v3, and OG series cameras.
What accessories are included with the Wyze Outdoor Power Adapter for overhead mounting?The Wyze Outdoor Power Adapter comes with wire clips, screws, anchors, and a weatherproof L-shaped Micro USB adapter. These accessories help ensure a neat and secure overhead mounting for your Wyze Cam.
What is the operating temperature range for the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter operates reliably in temperatures ranging from -30°C to 50°C (-22°F to 122°F), making it suitable for a wide range of outdoor environments.
Is there a replacement USB cable available for Wyze Cam Pan v3?Yes, the Wyze Cam Pan v3 USB Cable is available as a reliable and affordable replacement option. It is designed specifically for the Pan v3 camera to ensure a perfect fit and stable power delivery.
Can I use the Wyze Cam USB Extension Cable for outdoor installations?The Wyze Cam USB Extension Cable is ideal for indoor use, especially for overhead mounting. For outdoor or exposed installations, it is recommended to use the Wyze Outdoor Power Adapter, which is weather-resistant and designed for harsh environments.
