Compact Smart Plugs That Fit Two Devices in One Outlet
Looking for a smart plug solution that maximizes your outlet space by fitting two devices in one? Whether you want to automate your home appliances, control lighting, or manage outdoor devices, Wyze offers compact, efficient smart plugs designed to fit seamlessly into your lifestyle. Below, we highlight the best Wyze smart plugs that provide dual outlets or compact designs perfect for doubling up on your power needs without blocking adjacent sockets.
Wyze Plug Outdoor: Dual Outlet Smart Plug for Indoor & Outdoor Use
The
Wyze Plug Outdoor is a versatile smart plug designed to power two devices simultaneously from a single outlet, indoors or outdoors. Its compact size and dual outlets make it ideal for managing multiple outdoor devices like garden lights, holiday inflatables, or backyard speakers — all controlled easily via the Wyze app.
Key Features:
- Two Outlets in One Plug: Control two devices independently from a single outlet.
- Weather-Resistant (IP64 Rated): Perfect for outdoor use rain or shine.
- Energy Monitoring: Track power usage to optimize energy consumption.
- Voice Control: Compatible with Alexa for hands-free operation.
- Connectivity: Reliable 2.4GHz WiFi and Bluetooth V4.2.
- Operating Temperature: Works in a wide range from -4°F to 120°F.
- Compact Dimensions: 4.0” x 2.8” x 1.4” — fits easily without blocking other outlets.
- Overload Protection: Safeguards your devices with a 15A max output.
This plug is perfect for anyone wanting to smartly control two outdoor devices without sacrificing outlet space.
Enjoy smart control of your outdoor devices with ease.
Wyze Plug: Compact Indoor Smart Plug with Dual Pack Options
For indoor use, the
Wyze Plug offers a compact design that fits snugly into your outlets without blocking adjacent sockets, allowing you to plug in two devices side-by-side. Available in 2-pack or 4-pack bundles, this smart plug is perfect for automating lamps, fans, coffee makers, and more.
Key Features:
- Compact Size: 2.7” x 2.0” x 1.5” — designed to avoid blocking neighboring outlets.
- Single Outlet per Plug: Use two plugs side-by-side to control two devices in one outlet space.
- WiFi Connectivity: Connects via 2.4GHz WiFi for seamless app control.
- Voice Assistant Integration: Works with Alexa, Google Assistant, and IFTTT.
- Indoor Use Only: Optimized for indoor environments with operating temps from -4°F to 104°F.
- Energy Efficient: Supports scheduling and remote control to save power.
- Certified Safe: ETL certified with a 1-year warranty.
With the Wyze Plug, you can easily create a smart home setup that fits your space and lifestyle without bulky adapters.
Control your home devices smartly and compactly.
Why Choose Wyze Smart Plugs for Dual Device Control?
"Maximize your outlet space with smart plugs that fit two devices in one spot — no more blocked outlets or bulky adapters."
Wyze smart plugs stand out for their compact design, dual outlet options (outdoor), and seamless integration with popular voice assistants. Whether you need a rugged outdoor plug with two outlets or a sleek indoor plug that fits side-by-side, Wyze has you covered.
- Easy App Control: Schedule, monitor, and control devices from anywhere.
- Energy Monitoring: Keep track of your power usage to reduce bills.
- Voice Commands: Hands-free control with Alexa and Google Assistant.
- Reliable Connectivity: Strong WiFi range and Bluetooth support.
- Durability: Weatherproof options for outdoor use and safe indoor plugs.
Summary
If your goal is to fit two devices into one outlet space with smart control, the
Wyze Plug Outdoor is the best all-in-one dual outlet solution for both indoor and outdoor use. For strictly indoor needs, the
Wyze Plug offers a compact design that allows two plugs to fit side-by-side, effectively controlling two devices in one outlet space.
Choose Wyze smart plugs for a compact, efficient, and smart home power solution that fits your lifestyle perfectly.
Product Highlights
Wyze Plug Outdoor
Dual outlets, weather-resistant, energy monitoring, Alexa compatible.
Wyze Plug
Compact indoor plug, 2-pack or 4-pack, voice assistant integration.
What is the best smart plug for controlling two devices from one outlet?
The Wyze Plug Outdoor is the best smart plug for controlling two devices from a single outlet. It features dual independently controlled outlets, making it ideal for both indoor and outdoor use.Can Wyze smart plugs fit two devices in one outlet without blocking adjacent sockets?
Yes, Wyze smart plugs are designed with compact dimensions. The Wyze Plug Outdoor has two outlets in one plug, while the Wyze Plug indoor model is compact enough to allow two plugs to be used side-by-side in a standard outlet without blocking adjacent sockets.Are Wyze smart plugs suitable for outdoor use?
The Wyze Plug Outdoor is specifically designed for outdoor use. It is weather-resistant with an IP64 rating, making it perfect for powering garden lights, holiday inflatables, or backyard speakers in any weather conditions.Do Wyze smart plugs support voice control?
Yes, Wyze smart plugs support voice control. The Wyze Plug Outdoor is compatible with Alexa, while the Wyze Plug indoor model works with Alexa, Google Assistant, and IFTTT for hands-free operation.Can I monitor energy usage with Wyze smart plugs?
The Wyze Plug Outdoor features built-in energy monitoring, allowing you to track power usage and optimize energy consumption. The Wyze Plug indoor model supports scheduling and remote control to help save power.What are the size dimensions of Wyze smart plugs?
The Wyze Plug Outdoor measures 4.0” x 2.8” x 1.4”, while the Wyze Plug indoor model is 2.7” x 2.0” x 1.5”. Both are designed to maximize outlet space and avoid blocking other sockets.Are Wyze smart plugs safe to use?
Yes, Wyze smart plugs are certified safe. The Wyze Plug indoor model is ETL certified and comes with a 1-year warranty. The Wyze Plug Outdoor also features overload protection for added safety.How do I control Wyze smart plugs remotely?
You can control Wyze smart plugs remotely using the Wyze app. The app allows you to schedule, monitor, and control your devices from anywhere with a reliable 2.4GHz WiFi connection.What is the difference between Wyze Plug Outdoor and Wyze Plug indoor models?
The Wyze Plug Outdoor offers two independently controlled outlets, weather resistance, and energy monitoring, making it suitable for both indoor and outdoor use. The Wyze Plug indoor model is compact, designed for indoor use only, and allows two plugs to fit side-by-side in one outlet.What devices can I control with Wyze smart plugs?
Wyze smart plugs can control a variety of devices, including lamps, fans, coffee makers, garden lights, holiday inflatables, and backyard speakers, providing smart automation for both indoor and outdoor appliances.
