Dual Outlet Outdoor Smart Plug with Independent Control
Dual Outlet Outdoor Smart Plug with Independent Control for Seasonal Decorations
When it comes to managing your outdoor seasonal decorations, having a reliable, weather-resistant smart plug with dual outlets and independent control is essential. Whether you're lighting up your garden for the holidays or powering outdoor inflatables, these smart plugs give you the convenience and control you need right from your smartphone or voice assistant. Below, we highlight the best Wyze products designed specifically for outdoor use with dual outlet capabilities and smart control features, perfect for your seasonal decoration needs.
Wyze Plug Outdoor: The Ultimate Dual Outlet Smart Plug for Outdoors
Outdoor Lifestyle with Wyze Plug Outdoor Power your outdoor decorations with ease and style.
Key Features:
  • Two Outlets with Independent Control: Manage two separate devices independently, allowing you to turn off your holiday lights while keeping your inflatable snowman powered on.
  • Weather Resistant (IP64 Rated): Designed to withstand rain, dust, dirt, and snow, making it perfect for year-round outdoor use.
  • Extended WiFi Range: Up to 300 feet in open space, so you can place your plug almost anywhere in your yard or garden.
  • Energy Monitoring: Track energy consumption and set alerts to optimize power usage and save on your electricity bill.
  • Voice and App Control: Compatible with Alexa and Google Assistant, plus full control via the Wyze app for scheduling and remote operation.
  • High Power Output: 15 AMP output with overload protection, suitable for powering a variety of outdoor devices including roof de-icers and pond pumps.
Why Choose Wyze Plug Outdoor?
This smart plug is tailored for outdoor enthusiasts who want hassle-free control over their decorations and devices. Its durable build and smart features make it a must-have for managing your outdoor lighting and seasonal setups efficiently.
Additional Outdoor Smart Plug Options
Wyze Plug (Indoor Use)
While primarily designed for indoor use, the Wyze Plug offers smart control features that can complement your outdoor setup if you have covered or protected areas. It supports voice commands, scheduling, and integrates seamlessly with Alexa, Google Assistant, and IFTTT. Available in 2 or 4 Packs Compact Design for Easy Use 15A Max Output Indoor Use Only
Enhance Your Outdoor Setup with Wyze Cam Floodlight Plug-In Mount
Wyze Cam Floodlight Outdoor Setup Secure and illuminate your outdoor decorations with smart floodlight solutions. For those looking to add security and lighting to their outdoor decorations, the Wyze Cam Floodlight Plug-In Mount is an excellent accessory. It offers:
  • Plug-and-Play Installation: No need for complex junction box wiring.
  • 20 ft Power Cord: Flexible placement options.
  • Outdoor Safe: Operates in temperatures from -22°F to 122°F.
Compatible with Wyze Cam Floodlight v1, v2, and Pro models. This mount allows you to easily power your floodlight cameras, adding both illumination and security to your outdoor decorations.
Why Independent Control Matters for Seasonal Decorations
Managing multiple outdoor decorations can be tricky without the right tools. Dual outlet smart plugs with independent control let you customize your lighting and power usage, saving energy and enhancing convenience.
Imagine turning on your string lights and inflatables separately, or scheduling them to operate at different times without needing multiple plugs or manual intervention. This flexibility is especially useful during holidays when you want to create the perfect ambiance effortlessly.
Summary of Recommended Products for Outdoor Dual Outlet Smart Plug Needs
Product NameDual OutletsWeather ResistantApp & Voice ControlEnergy MonitoringPrice Range
Wyze Plug OutdoorYesIP64YesYes$15.99 - $34.98
Wyze Plug (Indoor)NoIndoor OnlyYesNo$24.98 - $39.98
Wyze Cam Floodlight Plug-In MountN/AYesN/AN/A$19.98
Conclusion
For your outdoor seasonal decorations, the Wyze Plug Outdoor stands out as the best dual outlet smart plug with independent control, robust weather resistance, and smart features like energy monitoring and voice control. Pair it with Wyze’s floodlight mounts and cameras for a complete smart outdoor setup that’s easy to manage and secure. Make your outdoor space smarter and more festive with Wyze’s reliable and affordable smart plugs designed for all seasons.
FeatureWyze Plug OutdoorWyze PlugWyze Cam Floodlight Plug-In Mount
TypeConnected Home - Outdoor Smart PlugConnected Home - Smart PlugCamera Accessory - Plug-In Mount
Price1 Pack: $15.99
2 Pack: $34.98
2 Pack: $24.98
4 Pack: $39.98
$19.98
Weather ResistanceIP64 (Rain, dust, dirt, snow resistant)Indoor use (no weather rating)Outdoor safe
Outlets2 Outlets with independent control1 Outlet per plugN/A (mount accessory)
Energy MonitoringYesNoN/A
WiFi RangeUp to 300 ft (open space)Standard WiFi rangeN/A
Voice ControlAlexa compatibleAlexa and Google Assistant compatibleN/A
App ControlYesYesN/A
Overload Protection15 AMP output with overload protectionNot specifiedN/A
Use CaseOutdoor devices, garden lights, inflatablesIndoor devices like lamps, fansMount for Wyze Cam Floodlight models
Included ItemsSmart plug(s)Smart plug(s)1x Plug-In Mount, mounting kit, screws, foam tape, quick start guide
Dimensions / WeightNot specifiedNot specified153mm x 155mm x 79mm, 1.39 lbs
Power InputNot specifiedNot specified110 - 120V AC
Additional FeaturesSet schedules, monitor usage, app & voice controlScheduling, vacation mode, group controlCompatible with Wyze Cam Floodlight v1, v2, Pro
Suitable ForOutdoor automationIndoor smart controlEasy plug-n-play floodlight installation
What is the Wyze Plug Outdoor and how does it benefit outdoor seasonal decorations?The Wyze Plug Outdoor is a weather-resistant dual outlet smart plug designed for outdoor use. It allows you to independently control two devices, such as holiday lights and inflatables, directly from your smartphone or voice assistant. This makes managing and scheduling your outdoor seasonal decorations convenient and energy-efficient.
Can I control each outlet on the Wyze Plug Outdoor independently?Yes, the Wyze Plug Outdoor features two outlets with independent control. This means you can turn each connected device on or off separately, allowing for customized scheduling and operation of your outdoor decorations.
Is the Wyze Plug Outdoor weather resistant?Absolutely. The Wyze Plug Outdoor is IP64 rated, making it resistant to rain, dust, dirt, and snow. It is built to withstand year-round outdoor conditions, ensuring reliable performance for your seasonal decorations.
How far can the Wyze Plug Outdoor connect to WiFi?The Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet in open space, giving you flexibility to place it almost anywhere in your yard or garden.
Does the Wyze Plug Outdoor support energy monitoring?Yes, the Wyze Plug Outdoor includes energy monitoring features. You can track energy consumption and set alerts to optimize power usage, helping you save on your electricity bill.
Is the Wyze Plug Outdoor compatible with voice assistants?Yes, the Wyze Plug Outdoor works with Alexa and Google Assistant, allowing you to control your outdoor devices using voice commands. It also offers full control via the Wyze app.
What devices can I power with the Wyze Plug Outdoor?With a 15 AMP output and overload protection, the Wyze Plug Outdoor can power a variety of outdoor devices, including holiday lights, inflatables, roof de-icers, and pond pumps.
Can I use the Wyze Plug (Indoor) for outdoor decorations?The Wyze Plug (Indoor) is designed for indoor use only. However, it can be used in covered or protected outdoor areas. It offers smart control features, voice command compatibility, and scheduling, but lacks weather resistance.
What is the Wyze Cam Floodlight Plug-In Mount and how does it enhance outdoor setups?The Wyze Cam Floodlight Plug-In Mount is an accessory that allows for easy, plug-and-play installation of Wyze Cam Floodlight cameras. It features a 20 ft power cord for flexible placement, operates in extreme temperatures, and adds both illumination and security to your outdoor decorations.
Why is independent control important for outdoor seasonal decorations?Independent control allows you to manage multiple outdoor decorations separately, such as turning on string lights while keeping inflatables off. This flexibility helps you customize your outdoor ambiance, save energy, and simplify scheduling during the holiday season.
What are the main differences between Wyze Plug Outdoor and Wyze Plug (Indoor)?The Wyze Plug Outdoor features dual outlets with independent control, weather resistance (IP64), energy monitoring, and is designed for outdoor use. The Wyze Plug (Indoor) is for indoor use only, has a compact design, and does not offer weather resistance or energy monitoring.
Can you tell me more about the energy monitoring feature of the Wyze Plug Outdoor?How does the independent control work for the dual outlets on the Wyze Plug Outdoor?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Plug Outdoor?
