WiFi Enabled Outdoor Smart Plug with Energy Monitoring and Long Range Connectivity
Looking to power your outdoor devices smartly and efficiently? Discover the
Wyze Plug Outdoor, the perfect WiFi-enabled outdoor smart plug designed to bring convenience, control, and energy savings to your outdoor spaces. Whether you're lighting up your garden, powering holiday inflatables, or managing pond pumps, this smart plug offers robust features including energy monitoring and long-range WiFi connectivity.
Wyze Plug Outdoor: Smart Power for Your Outdoors
Reliable Outdoor Performance
The Wyze Plug Outdoor is built to withstand the elements with an
IP64 weather-resistant rating, making it safe to use in rain, dust, dirt, and snow. This durability ensures your outdoor devices stay powered no matter the weather.
Long-Range WiFi Connectivity
With an impressive
up to 300 feet WiFi range in open spaces, the Wyze Plug Outdoor lets you control devices far from your home’s router. This extended range means you can confidently place your smart plug in hard-to-reach outdoor areas without losing connection.
Energy Monitoring & Usage Alerts
Keep track of your energy consumption with built-in
energy monitoring. The Wyze app provides detailed historical usage data and lets you set energy consumption alerts, helping you save on electricity bills while optimizing your outdoor device usage.
Dual Outlets with Independent Control
Featuring
two outlets with separate controls, you can manage multiple devices independently. For example, turn off your garden lights while keeping your holiday inflatables plugged in and running.
Voice and App Control
Control your outdoor devices hands-free with
Alexa voice commands or through the Wyze app on your smartphone. Whether you're cozy inside or away from home, managing your outdoor power is effortless.
High Power Output with Safety
The plug supports a
15 AMP output with overload protection, allowing you to power high-demand devices like roof de-icers and pond pumps safely.
Power your outdoor space rain or shine with the Wyze Plug Outdoor — smart, durable, and energy-conscious.
Enjoy smart outdoor lighting and control with Wyze Plug Outdoor.
Wyze Plug: Indoor Smart Plug for Everyday Convenience
Compact and Easy to Use
The
Wyze Plug is a compact indoor smart plug designed to make your everyday devices smarter. Perfect for lamps, fans, coffee makers, and more, it fits discreetly into any outlet.
Seamless App and Voice Integration
Control your devices remotely via the Wyze app or with voice assistants like
Alexa, Google Assistant, and IFTTT. Schedule your appliances, set timers, or turn devices on/off with simple voice commands.
Reliable Connectivity
Operating on
2.4GHz WiFi, the Wyze Plug ensures stable connections for your indoor smart home setup.
Safety and Certification
ETL certified and designed for indoor use, the Wyze Plug supports up to
15A max output and operates safely within a temperature range of -4°F to 104°F (-20°C to 40°C).
Smart control for your indoor devices with Wyze Plug.
Why Choose Wyze Smart Plugs for Your Home?
- Energy Efficiency: Monitor and reduce your power consumption with real-time data.
- Extended WiFi Range: Control devices even in distant outdoor locations.
- Weather Resistance: Outdoor plugs built to last through all seasons.
- Dual Outlet Control: Manage multiple devices independently with one plug.
- Voice Assistant Compatibility: Hands-free control with Alexa and Google Assistant.
- Easy Setup: Simple installation with no electrician needed.
Summary
For a
WiFi-enabled outdoor smart plug with energy monitoring and long-range connectivity, the
Wyze Plug Outdoor stands out as the ideal choice. Its weather resistance, dual outlets, and extended WiFi range make it perfect for managing your outdoor devices smartly and safely. Complement your smart home with the
Wyze Plug for indoor convenience, ensuring all your devices are connected and controllable from anywhere.
Upgrade your home automation today with Wyze smart plugs — smart power, smart savings, smart living.
What is the Wyze Plug Outdoor and what are its main features?
The Wyze Plug Outdoor is a WiFi-enabled outdoor smart plug designed for powering and controlling outdoor devices. Its main features include IP64 weather resistance, up to 300 feet long-range WiFi connectivity, built-in energy monitoring, dual outlets with independent control, Alexa voice and app control, and a 15 AMP output with overload protection.Is the Wyze Plug Outdoor weatherproof?
Yes, the Wyze Plug Outdoor is IP64 weather-resistant, making it safe to use in rain, dust, dirt, and snow. This ensures reliable performance in various outdoor conditions.How far is the WiFi range for the Wyze Plug Outdoor?
The Wyze Plug Outdoor offers an impressive WiFi range of up to 300 feet in open spaces, allowing you to control devices located far from your home’s router.Does the Wyze Plug Outdoor support energy monitoring?
Yes, the Wyze Plug Outdoor features built-in energy monitoring. You can track your energy consumption, view historical usage data, and set energy consumption alerts through the Wyze app.Can I control each outlet on the Wyze Plug Outdoor separately?
Yes, the Wyze Plug Outdoor has two outlets with independent controls, allowing you to manage multiple devices separately from the Wyze app or with voice commands.Is the Wyze Plug Outdoor compatible with voice assistants?
Yes, you can control the Wyze Plug Outdoor hands-free using Alexa voice commands, as well as through the Wyze app on your smartphone.What is the maximum power output of the Wyze Plug Outdoor?
The Wyze Plug Outdoor supports up to 15 AMP output and includes overload protection, making it suitable for high-demand outdoor devices like pond pumps and roof de-icers.What is the Wyze Plug and how is it different from the Wyze Plug Outdoor?
The Wyze Plug is a compact indoor smart plug designed for everyday devices like lamps, fans, and coffee makers. It operates on 2.4GHz WiFi, supports up to 15A max output, and is ETL certified for indoor use. Unlike the Wyze Plug Outdoor, it is not weather-resistant and is intended for indoor environments.Can I control the Wyze Plug with voice assistants?
Yes, the Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT, allowing you to control your indoor devices with simple voice commands.How do I set up Wyze smart plugs?
Wyze smart plugs are easy to set up. Simply plug them into an outlet, connect them to your 2.4GHz WiFi network using the Wyze app, and follow the on-screen instructions. No electrician is needed.Are Wyze smart plugs energy efficient?
Yes, Wyze smart plugs help you monitor and reduce your power consumption with real-time energy data and usage alerts, promoting energy efficiency in your home.
