Outdoor Smart Plug with Overload Protection for Safe Use
Outdoor Smart Plug with Overload Protection for Safe Appliance Use
When it comes to powering your outdoor appliances safely and smartly, having a reliable outdoor smart plug with overload protection is essential. Whether you're lighting up your garden, running pond pumps, or powering holiday inflatables, the right smart plug ensures convenience, safety, and energy efficiency. Below, we explore the top Wyze smart plugs designed for outdoor use, highlighting their features, specs, and how they keep your appliances safe.
Wyze Plug Outdoor: Robust and Weather-Resistant Smart Plug
Designed for the Outdoors, Rain or Shine
The Wyze Plug Outdoor is built specifically to withstand the elements with an IP64 weather-resistant rating. This means it can handle rain, dust, dirt, and even snow, making it perfect for outdoor lighting, roof de-icers, pond pumps, and more.
Key Features for Safe and Smart Outdoor Use
  • Overload Protection with 15 AMP Output: One of the highest output ratings available in a smart plug, ensuring your appliances are protected from electrical overloads.
  • Dual Outlets with Independent Controls: Control two devices separately from the Wyze app or via voice commands.
  • Extended WiFi Range: Up to 300 feet in open space, so you can place the plug almost anywhere outside your home.
  • Energy Monitoring: Track energy consumption, set alerts, and view historical usage to optimize power efficiency.
  • Voice Assistant Compatibility: Works seamlessly with Alexa for hands-free control.
Power your outdoor space safely and smartly, whether for festive decorations or everyday appliances.
Outdoor Lifestyle with Wyze Plug Outdoor Enjoy smart outdoor lighting and appliance control with Wyze Plug Outdoor.
Wyze Plug: Indoor Smart Plug with High Compatibility
Smart Control for Indoor Appliances
While the Wyze Plug is designed for indoor use only, it offers a powerful 15A max output and smart features that make it a versatile choice for your home automation needs.
Highlights
  • Compact and Lightweight: Measuring 2.7" x 2.0" x 1.5" and weighing just 5.3 oz.
  • Connectivity: 2.4GHz WiFi compatible with Android 5.0+ and iOS 9.0+.
  • Integrations: Supports Alexa, Google Assistant, and IFTTT for seamless smart home integration.
  • Energy Efficient: Monitor and control your devices remotely via the Wyze app.
  • ETL Certified: Ensures safety and quality standards.
  • Warranty: Comes with a 1-year warranty for peace of mind.
Ideal for making your everyday devices smart, from coffee makers to fans.
Indoor Smart Plug Lifestyle Control your indoor appliances effortlessly with Wyze Plug.
Why Choose a Smart Plug with Overload Protection?
Overload protection is a critical safety feature that prevents electrical fires and damage to your appliances by automatically shutting off power when the current exceeds safe levels. The Wyze Plug Outdoor’s 15 AMP output with built-in overload protection ensures that your outdoor devices operate safely, even during heavy use or power surges.
Safety and smart control go hand in hand for worry-free appliance management.
Additional Smart Home Accessories for Outdoor Use
While focusing on smart plugs, consider complementing your setup with Wyze’s outdoor camera accessories like the Wyze Cam Floodlight Plug-In Mount. This accessory offers an easy, plug-and-play floodlight solution without the hassle of installing a junction box, enhancing your outdoor security alongside smart power control.
Summary
For safe and efficient outdoor appliance use, the Wyze Plug Outdoor stands out with its weather resistance, overload protection, dual outlets, and energy monitoring. For indoor smart plug needs, the Wyze Plug offers compact design and broad compatibility. Together, these smart plugs provide a comprehensive solution for managing your home’s power needs safely and intelligently.
Product Specs at a Glance
FeatureWyze Plug OutdoorWyze Plug (Indoor)
Weather ResistanceIP64 (Outdoor Rated)Indoor Use Only
Max Output15 AMP with Overload Protection15 AMP
WiFi RangeUp to 300 ft (Open Space)Standard 2.4 GHz WiFi
Outlets2 Outlets, Independently ControlledSingle Outlet (2-Pack or 4-Pack)
Energy MonitoringYesYes
Voice ControlAlexa CompatibleAlexa, Google Assistant, IFTTT
DimensionsNot specified2.7" x 2.0" x 1.5"
Warranty30-day hassle-free returns1 Year
Enhance Your Outdoor Smart Home Setup
Investing in a smart plug with overload protection like the Wyze Plug Outdoor not only safeguards your appliances but also elevates your outdoor living experience with convenience and control at your fingertips.
TypeOutdoor Smart PlugIndoor Smart Plug
Weather ResistanceIP64 (Rain, dust, dirt, snow resistant)Not weatherproof, suitable for indoor use
WiFi RangeUp to 300 ft (open space)Standard WiFi range (not specified)
Outlets2 outlets with independent control1 outlet per plug
Energy MonitoringYesNo
SchedulingYesYes
Voice ControlAlexa compatibleAlexa and Google Assistant compatible
App ControlYesYes
Power Output15 AMP with overload protectionNot specified
Use CaseOutdoor devices (garden lights, inflatables, pond pumps, roof de-icers)Indoor devices (lamps, fans, etc.)
Size Variants1 Pack ($15.99), 2 Pack ($34.98)2 Pack ($24.98), 4 Pack ($39.98)
Hub RequiredNoNo
Special FeaturesTwo outlets with separate controls, energy usage alerts, long-range WiFiVacation mode, multi-plug grouping, automation with other Wyze devices
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Plug Outdoor and how is it designed for outdoor use?The Wyze Plug Outdoor is a robust smart plug specifically built for outdoor environments. It features an IP64 weather-resistant rating, making it suitable for use in rain, dust, dirt, and snow. This makes it ideal for powering outdoor lighting, pond pumps, roof de-icers, and holiday decorations safely and reliably.
Does the Wyze Plug Outdoor have overload protection?Yes, the Wyze Plug Outdoor is equipped with built-in overload protection and supports up to 15 AMP output. This feature automatically shuts off power if the current exceeds safe levels, protecting your appliances from electrical overloads and reducing the risk of electrical fires.
How many devices can I control with the Wyze Plug Outdoor?The Wyze Plug Outdoor features dual outlets that can be controlled independently. This allows you to manage two separate outdoor devices at the same time using the Wyze app or voice commands.
Can I monitor energy usage with Wyze smart plugs?Yes, both the Wyze Plug Outdoor and Wyze Plug (Indoor) offer energy monitoring. You can track energy consumption, set alerts, and view historical usage data through the Wyze app to optimize your power efficiency.
What is the WiFi range of the Wyze Plug Outdoor?The Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet in open space, allowing you to place the plug almost anywhere outside your home for reliable connectivity.
Is the Wyze Plug Outdoor compatible with voice assistants?Yes, the Wyze Plug Outdoor works seamlessly with Alexa, enabling hands-free control of your outdoor appliances.
What are the main features of the Wyze Plug for indoor use?The Wyze Plug (Indoor) is compact and lightweight, supports up to 15 AMP output, and is compatible with 2.4GHz WiFi. It integrates with Alexa, Google Assistant, and IFTTT, and allows you to monitor and control devices remotely via the Wyze app. It is ETL certified and comes with a 1-year warranty.
Why is overload protection important in a smart plug?Overload protection is a crucial safety feature that prevents electrical fires and damage to your appliances. It works by automatically shutting off power when the current exceeds safe levels, ensuring your devices operate safely even during heavy use or power surges.
Can I use the Wyze Plug (Indoor) outdoors?No, the Wyze Plug (Indoor) is designed for indoor use only. For outdoor applications, it is recommended to use the Wyze Plug Outdoor, which is specifically built to withstand outdoor conditions.
Are there any accessories to enhance my outdoor smart home setup?Yes, Wyze offers outdoor camera accessories such as the Wyze Cam Floodlight Plug-In Mount. This accessory provides an easy, plug-and-play floodlight solution without the need for a junction box, complementing your outdoor smart plug setup for enhanced security and convenience.
What warranty is offered with Wyze smart plugs?The Wyze Plug Outdoor comes with a 30-day hassle-free return policy, while the Wyze Plug (Indoor) includes a 1-year warranty for added peace of mind.
What are the key features of the Wyze Plug Outdoor?How does the overload protection work in the Wyze Plug Outdoor?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Plug Outdoor?
