Compact Smart Plugs That Fit Two in One Outlet Without Blocking
Looking for a smart plug that is compact enough to fit two units side-by-side in a single outlet without blocking the other socket? Whether you want to automate your home devices or control outdoor lighting, Wyze offers smart plugs designed with space-saving and functionality in mind. Below, we highlight the best Wyze smart plugs that meet your need for compactness and convenience.
Wyze Plug: The Ultimate Compact Indoor Smart Plug
Space-Saving Design for Dual Outlet Use
The Wyze Plug is engineered to be small and unobtrusive, measuring just 2.7" x 2.0" x 1.5". This compact size allows you to plug two Wyze Plugs into one standard outlet without blocking the second socket, making it perfect for tight spaces.
Smart Features and Compatibility
- Connectivity: 2.4GHz WiFi for reliable control.
- Voice Control: Works seamlessly with Alexa, Google Assistant, and IFTTT.
- App Control: Schedule, monitor, and automate your devices from anywhere.
- Output: Supports up to 15A max load.
- Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 104°F.
- Warranty: 1-year coverage for peace of mind.
Ideal For
- Lamps, fans, coffee makers, and other household devices.
- Users who want to maximize outlet usage without bulky plugs.
"Start living in the future. Make your normal ol' devices smart!" — Wyze Plug
Compact Wyze Plug controlling home devices with app
Wyze Plug Outdoor: Dual Outlet Smart Plug for Outdoor Use
Dual Outlets Without Blocking
The Wyze Plug Outdoor features two independent outlets in a compact form factor (4.0” x 2.8” x 1.4”), designed to fit side-by-side in one outdoor outlet without blocking access. This is perfect for controlling multiple outdoor devices simultaneously.
Rugged and Weather-Resistant
- Weather Rating: IP64, suitable for rain or shine.
- Operating Temperature: -4°F to 120°F.
- Durability: Built to withstand outdoor conditions.
- Connectivity: 2.4GHz WiFi and Bluetooth V4.2.
- Energy Monitoring: Track power usage for each outlet.
- Voice Commands: Compatible with Alexa.
- Max Load: 15A with overload protection.
Perfect For
- Garden lights, holiday inflatables, backyard parties.
- RVs, campers, and outdoor setups needing smart control.
"Power up the outdoors, rain or shine, with an outdoor smart plug – because even your garden lights deserve a tech-savvy friend."
Enhance Your Outdoor Security Setup with Wyze Cam Floodlight Plug-In Mount
Easy Plug-and-Play Floodlight Mount
If you want to add smart lighting without complicated wiring, the Wyze Cam Floodlight Plug-In Mount is a perfect companion. It plugs directly into an outlet and supports Wyze Cam Floodlight models, providing bright, smart illumination with no junction box needed.
Key Features
- Outdoor Safe: Rated for outdoor use.
- Power Cord: 20 ft length for flexible placement.
- Operating Temperature: -22°F to 122°F.
- Colors: Available in Black and White to match your home exterior.
- Included Items: Mounting kit, foam tape, quick start guide.
Why Choose This?
- Simplifies installation of smart floodlights.
- Works well with Wyze Cam Floodlight Pro and v2 models.
- Ideal for enhancing home security with smart lighting.
Wyze Cam Floodlight illuminating a backyard deck in the evening
Summary: Best Compact Smart Plugs for Dual Outlet Use
Product | Outlet Count | Size (LxWxH) | Indoor/Outdoor | Key Features |
Wyze Plug | 1 per unit | 2.7" x 2.0" x 1.5" | Indoor only | Compact, Alexa/Google/IFTTT, 15A |
Wyze Plug Outdoor | 2 | 4.0" x 2.8" x 1.4" | Indoor/Outdoor | Dual outlets, IP64, energy monitor |
Wyze Cam Floodlight Plug-In Mount | N/A (mount) | N/A | Outdoor | Plug-n-play floodlight mount |
For those who want to maximize outlet space without blocking sockets, the Wyze Plug and Wyze Plug Outdoor are excellent choices. The Wyze Plug is perfect for indoor use with a sleek, compact design, while the Wyze Plug Outdoor offers dual outlets and weather resistance for outdoor smart control.
Embrace smart living with compact, efficient plugs that fit your lifestyle and your outlets.
What are the best compact smart plugs that fit two in one outlet without blocking?
The Wyze Plug is designed to be compact, measuring just 2.7" x 2.0" x 1.5", allowing you to fit two plugs side-by-side in a single outlet without blocking the other socket. For outdoor use, the Wyze Plug Outdoor features two independent outlets in a compact form factor, making it easy to control multiple devices without blocking access.Can I use Wyze smart plugs with Alexa or Google Assistant?
Yes, Wyze smart plugs are compatible with Alexa, Google Assistant, and IFTTT, allowing you to control your devices with voice commands or through smart home routines.Are Wyze smart plugs suitable for outdoor use?
The Wyze Plug Outdoor is specifically designed for outdoor use, featuring an IP64 weather-resistant rating and a durable build to withstand rain, snow, and sun. It also operates in temperatures from -4°F to 120°F.How much power can Wyze smart plugs handle?
Both the Wyze Plug and Wyze Plug Outdoor support up to a 15A maximum load, making them suitable for most household and outdoor devices.Do Wyze smart plugs block the second outlet when plugged in?
No, the Wyze Plug is engineered to be compact so that two units can fit side-by-side in a standard outlet without blocking the other socket. The Wyze Plug Outdoor also features a compact design for dual outlet use.Can I monitor energy usage with Wyze smart plugs?
The Wyze Plug Outdoor includes energy monitoring features, allowing you to track power usage for each outlet through the Wyze app.What devices are Wyze smart plugs ideal for?
Wyze smart plugs are perfect for automating lamps, fans, coffee makers, garden lights, holiday inflatables, and other household or outdoor devices. They are also great for maximizing outlet usage in tight spaces.Is there a smart plug solution for installing Wyze Cam Floodlights without hardwiring?
Yes, the Wyze Cam Floodlight Plug-In Mount allows you to easily install Wyze Cam Floodlight models by plugging them directly into an outlet, eliminating the need for complicated wiring or a junction box.What is included with the Wyze Cam Floodlight Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount comes with a 20 ft power cord, mounting kit, foam tape, and a quick start guide. It is available in both Black and White to match your home exterior.What warranty do Wyze smart plugs come with?
Wyze smart plugs come with a 1-year warranty, providing peace of mind for your purchase.
