Best Outdoor Smart Plugs for Remote Voice-Controlled Lighting
Best Outdoor Smart Plug for Remote Voice Controlled Lighting
When it comes to enhancing your outdoor lighting with smart technology, choosing the right outdoor smart plug is essential. Whether you want to control garden lights, festive decorations, or backyard lighting remotely via voice commands, the perfect smart plug can make your outdoor space smarter and more convenient. Below, we explore the top Wyze products designed for outdoor smart lighting control, focusing on their features, specs, and benefits.
Wyze Plug Outdoor: The Ultimate Outdoor Smart Plug
Weatherproof and Durable for All Seasons
The Wyze Plug Outdoor is built to withstand the elements with an IP64 weather rating, making it rain or shine ready. It operates efficiently in temperatures ranging from -4°F to 120°F, ensuring reliable performance year-round.
Dual Outlets with Overload Protection
This smart plug offers two outlets with a maximum output of 15A each, protected against overloads. Perfect for powering multiple outdoor lighting setups or devices simultaneously.
Remote Control and Scheduling via App
Control your outdoor lights from anywhere using the Wyze app compatible with Android 5.0+ and iOS 9.0+. Set schedules, monitor energy usage, and automate your lighting effortlessly.
Voice Control Compatibility
Seamlessly integrate with Alexa for hands-free voice commands, making it easy to turn your outdoor lights on or off without lifting a finger.
Connectivity and Range
Connects via 2.4GHz WiFi and Bluetooth V4.2, with a WiFi range of up to 300 feet, providing flexible placement options around your home.
Power up your outdoor space with smart convenience and weatherproof reliability.
Outdoor evening deck with smart lighting Enjoy smart outdoor lighting for your deck and backyard.
Wyze Plug: Smart Indoor Plug with Voice Control
Perfect for Indoor Use
While the Wyze Plug is designed for indoor environments, it offers excellent smart control features for your home lighting and appliances.
Compact and Efficient
With a small footprint (2.7" x 2.0" x 1.5") and lightweight design, it fits easily into any outlet without blocking adjacent sockets.
Voice and App Control
Compatible with Alexa, Google Assistant, and IFTTT, this plug allows you to control your devices via voice commands or the Wyze app.
Scheduling and Energy Monitoring
Set timers and schedules to automate your lighting and monitor energy consumption to save on electricity bills.
Make your everyday devices smart and voice-controlled with ease.
Lifestyle image of smart plug controlling home appliances Control your home lighting and appliances remotely.
Wyze Cam Floodlight Pro + Plug-In Mount: Smart Lighting with Security
Integrated Floodlight and Camera Solution
This bundle combines a powerful 3000-lumen floodlight with a 2.5K QHD camera, providing both bright outdoor lighting and security monitoring.
Easy Plug-and-Play Installation
No need for complex junction box wiring. The included plug-in mount makes installation quick and straightforward.
Advanced Features
  • 180° ultra-wide field of view
  • Color night vision for clear nighttime monitoring
  • Alexa, Google Assistant, and IFTTT integration for voice control
  • 20-foot power cord for flexible placement
  • IP65 water resistance for outdoor durability
Smart Lighting Control
Use voice commands or the Wyze app to control the floodlight, perfect for illuminating your yard or driveway remotely.
Combine smart lighting and security in one powerful outdoor device.
Outdoor lifestyle image showing floodlight illuminating a backyard Brighten and secure your outdoor space with smart floodlight technology.
Why Choose Wyze for Outdoor Smart Lighting?
Wyze offers a comprehensive ecosystem of smart home products designed to work seamlessly together. Their outdoor smart plugs and lighting solutions provide:
  • Reliable weather resistance for outdoor use
  • Voice control compatibility with popular assistants
Easy app-based scheduling and monitoring Energy efficiency and overload protection
  • Affordable pricing with high-end features
Whether you want to automate your garden lights, control holiday decorations, or add smart floodlights with security cameras, Wyze has you covered.
Summary of Top Outdoor Smart Lighting Products
ProductKey FeaturesVoice ControlWeatherproofOutletsPrice Range
Wyze Plug OutdoorIP64 rating, 2 outlets, energy monitoringAlexaYes2$15.99 - $34.98
Wyze PlugCompact indoor plug, Alexa/Google/IFTTTAlexa, GoogleNo1$24.98 - $39.98
Wyze Cam Floodlight Pro + Mount3000 lumens, 2.5K camera, IP65, plug-in mountAlexa, GoogleYesN/A$169.96
Upgrade your outdoor lighting with smart plugs and floodlights that bring convenience, control, and security to your home environment.
# Product Tags and Highlights
FeatureWyze Plug OutdoorWyze PlugWyze Cam Floodlight Pro + Plug-In Mount
TypeConnected Home - Outdoor Smart PlugConnected Home - Smart PlugCameras - Floodlight Security Camera Bundle
Price1 Pack: $15.99
2 Pack: $34.98
2 Pack: $24.98
4 Pack: $39.98
$169.96
Weather ResistanceIP64 (Rain, dust, dirt, snow resistant)Indoor use (no weather rating specified)IP65 (Water resistant)
Outlets2 Outlets with independent control1 Outlet per plugN/A (Camera + Mount)
Energy MonitoringYesNoN/A
WiFi RangeUp to 300 ft (long-range WiFi)Standard WiFi rangeWi-Fi 2.4G b/g/n, 2.4 & 5 GHz dual-band
Voice Assistant CompatibilityAlexaAlexa, Google AssistantAlexa, Google Assistant, IFTTT
App ControlYesYesYes
Scheduling & AutomationYesYesYes (via app integrations)
Output Power15 AMP with overload protectionNot specifiedN/A
LightingN/AN/A3 dimmable light panels, 3000 lumens, 5000K
Camera ResolutionN/AN/A2.5K QHD (2560x1440)
Field of ViewN/AN/A180° Ultra-Wide
Night VisionN/AN/AYes, Color Night Vision
MountingN/AN/APlug-in Mount (easy plug-n-play installation)
Power SupplyStandard outdoor outletStandard indoor outletHardwired 110-120V AC
Dimensions & WeightNot specifiedNot specified153mm x 155mm x 79mm, 1.39 lbs
Operating Temperature RangeNot specifiedNot specified-22°F to 122°F
WarrantyNot specifiedNot specified1 Year
What is the best outdoor smart plug for remote voice-controlled lighting?The Wyze Plug Outdoor is considered one of the best outdoor smart plugs for remote voice-controlled lighting. It features weatherproof durability (IP64 rating), dual outlets with overload protection, remote control and scheduling via the Wyze app, and seamless integration with Alexa for hands-free voice commands.
Is the Wyze Plug Outdoor weatherproof and suitable for all seasons?Yes, the Wyze Plug Outdoor is built with an IP64 weather rating, making it resistant to rain and dust. It operates efficiently in temperatures ranging from -4°F to 120°F, ensuring reliable performance throughout the year.
How many devices can I control with the Wyze Plug Outdoor?The Wyze Plug Outdoor features two independently controlled outlets, each with a maximum output of 15A. This allows you to power and control multiple outdoor lighting setups or devices simultaneously.
Can I control Wyze smart plugs with my voice?Yes, both the Wyze Plug Outdoor and Wyze Plug (indoor) support voice control. The Wyze Plug Outdoor works with Alexa, while the Wyze Plug (indoor) is compatible with Alexa, Google Assistant, and IFTTT for hands-free operation.
Does the Wyze Plug Outdoor support remote control and scheduling?Absolutely. You can control your outdoor lights from anywhere using the Wyze app, available for Android and iOS. The app allows you to set schedules, monitor energy usage, and automate your outdoor lighting with ease.
What is the WiFi range of the Wyze Plug Outdoor?The Wyze Plug Outdoor connects via 2.4GHz WiFi and Bluetooth V4.2, offering a WiFi range of up to 300 feet. This provides flexible placement options around your home and yard.
Is the Wyze Plug suitable for outdoor use?No, the Wyze Plug is designed for indoor use only. For outdoor environments, the Wyze Plug Outdoor is recommended due to its weatherproof construction.
What are the benefits of using Wyze smart plugs for outdoor lighting?Wyze smart plugs offer reliable weather resistance, voice control compatibility, easy app-based scheduling and monitoring, energy efficiency, overload protection, and affordable pricing with high-end features. They make it easy to automate and control your outdoor lighting remotely.
What is the Wyze Cam Floodlight Pro + Plug-In Mount, and how does it enhance outdoor lighting?The Wyze Cam Floodlight Pro + Plug-In Mount is a smart lighting and security solution that combines a powerful 3000-lumen floodlight with a 2.5K QHD camera. It features color night vision, a 180° ultra-wide field of view, voice control compatibility, and easy plug-and-play installation, making it ideal for illuminating and securing your outdoor spaces.
Can I use the Wyze app to monitor energy usage with Wyze smart plugs?Yes, both the Wyze Plug Outdoor and Wyze Plug (indoor) allow you to monitor energy consumption through the Wyze app, helping you save on electricity bills and manage your devices efficiently.
Which voice assistants are compatible with Wyze smart plugs and floodlights?Wyze smart plugs and floodlights are compatible with Alexa, and many also work with Google Assistant and IFTTT, allowing for flexible voice control and smart home integration.
How easy is it to install the Wyze Cam Floodlight Pro + Plug-In Mount?The Wyze Cam Floodlight Pro + Plug-In Mount is designed for easy installation with a plug-in mount, eliminating the need for complex junction box wiring. It also comes with a 20-foot power cord for flexible placement.
What features should I look for in an outdoor smart plug?Can the Wyze Plug Outdoor be used for holiday decorations?Do you have any ongoing sales or discounts for the Wyze Plug Outdoor?
