Wyze Duo Cam Doorbell: Dual Camera Security for Multiple Angles
Discover the Wyze Duo Cam Doorbell: Dual Camera Security for Multiple Angles
When it comes to securing your home’s front porch, having a doorbell that captures every angle is essential. The Wyze Duo Cam Battery Doorbell stands out as the ultimate dual camera doorbell, designed to keep track of multiple views simultaneously. Whether you want to monitor visitors at your door or keep an eye on packages below, this advanced video doorbell offers comprehensive coverage with crystal-clear 2K video quality. Wyze Duo Cam Doorbell lifestyle Wyze Duo Cam Doorbell capturing multiple angles for enhanced security
Dual Camera Views for Complete Coverage
  • Front Camera: 2K resolution (2048 x 1536) with a wide 132° horizontal and 100° vertical field of view
  • Bottom Camera: 1080p resolution (1920 x 1080) with a 121° horizontal and 60° vertical field of view
  • Simultaneous monitoring of people and packages ensures no blind spots at your doorstep
Advanced Features for Smart Security
  • Battery-powered with a removable 6200 mAh lithium-ion battery pack for flexible installation
  • Supports hardwired power for continuous 24/7 local recording with a microSD card (up to 256GB)
  • Real-time AI detections and alerts for people, packages, and motion events
  • Two-way audio with motion-activated voice deterrence and a loud 90 dB siren
  • Dual-band Wi-Fi (2.4 GHz & 5 GHz) and Bluetooth 5.0 for reliable connectivity
  • Weather-resistant IP65 rating ensures durability in all seasons
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Essential Features
If you prefer a wired doorbell solution with high-resolution video, the Wyze Video Doorbell v2 is a powerful choice. It delivers sharp 2K video and local microSD storage, making it easy to capture every detail at your front door. Wyze Video Doorbell v2 lifestyle Wyze Video Doorbell v2 installed on a modern porch
Key Specifications
  • 2K video resolution (2048 x 1536) with a wide 135° horizontal and 103° vertical field of view
  • CMOS Starlight Sensor and F2.0 aperture for clear day and night vision
  • Motion-activated voice deterrence and two-way audio for real-time communication
  • Local storage support up to 256GB microSD card and optional cloud storage with Wyze Security Plan
  • Powered by 16V-24V AC wiring, suitable for most existing doorbell systems
  • IP65 weather resistance and operating temperature range from -4°F to 122°F
  • Integrates with Alexa, Google Assistant, and IFTTT for smart home compatibility
Optional Wedge Kit for Perfect Angles
For homes with angled door frames or stairs, the Wyze Video Doorbell v2 Wedge Kit accessory allows you to adjust the viewing angle easily, eliminating blind spots and enhancing your security coverage.
Wyze Video Doorbell Pro: Wireless or Wired HD Doorbell with Ultra-Wide View
For those seeking a versatile doorbell with quick installation and a wider field of view, the Wyze Video Doorbell Pro offers both wired and battery-powered options. It combines high-definition video with smart detection features at an affordable price. Wyze Video Doorbell Pro lifestyle Wyze Video Doorbell Pro installed on a stylish home entrance
Highlights
  • Crystal-clear HD video with an ultra-wide viewing angle for broader coverage
  • Easy 30-second installation with screw or adhesive plate options
  • Smart detection alerts including person, package, vehicle, and pet detection with Cam Plus subscription
  • Motion-activated security light and two-way audio for instant communication
  • Includes a dual-band Wi-Fi extender chime for faster notifications
  • Compatible with Alexa and Google Assistant for voice control
  • Multiple chime tunes and sound levels to customize your alerts
Why Choose Wyze Duo Cam Doorbell for Multi-Angle Security?
The Wyze Duo Cam Doorbell is uniquely designed to provide simultaneous dual camera views, making it perfect for monitoring both visitors and packages without missing a beat. Its battery-powered flexibility combined with advanced AI detection and local storage options makes it a top choice for modern home security.
Whether you want the convenience of wireless installation or the reliability of wired power, Wyze offers a range of video doorbells tailored to your needs. The Duo Cam Doorbell’s dual lenses and smart features ensure you never miss a moment at your doorstep.
Summary of Wyze Dual Camera Doorbell Options
ProductPower TypeVideo ResolutionDual CamerasKey FeaturesWeather Resistance
Wyze Duo Cam Battery DoorbellBattery / WiredFront: 2K, Bottom: 1080pYesAI alerts, two-way audio, sirenIP65
Wyze Video Doorbell v2Wired2K (2048 x 1536)NoLocal storage, voice deterrenceIP65
Wyze Video Doorbell ProBattery / WiredHD with ultra-wide angleNoSmart detection, security lightIP65
Enhance Your Home Security with Wyze
Wyze’s video doorbells combine cutting-edge technology with user-friendly features to keep your home safe and connected. From the dual camera views of the Duo Cam Doorbell to the wired clarity of the Video Doorbell v2 and the versatile Pro model, Wyze has a smart doorbell solution for every home. Experience peace of mind knowing you can monitor multiple angles simultaneously, communicate instantly, and receive real-time alerts — all from your smartphone.
FeatureWyze Duo Cam Battery DoorbellWyze Video Doorbell v2Wyze Video Doorbell Pro
PowerBattery (Removable Battery Pack) or HardwiredWired (16V-24V AC)Battery or Hardwired
Video ResolutionTop: 2K, Bottom: 1080p2K (2048 x 1536)HD (exact resolution not specified, crystal-clear HD)
Field of View (FOV)Top: 132° x 100°, Bottom: 121° x 60°135° horizontal x 103° verticalUltra-wide viewing angle (wider than others)
CamerasDual cameras (people and package views)Single cameraSingle camera
Local StoragemicroSD support (up to 256GB), 24/7 recording with hardwired powermicroSD support, 24/7 local recordingNot specified
Two-Way AudioYesYesYes
AI Detections & AlertsPerson, Package, Pet, Vehicle detectionPerson, Package detection (with Cam Plus)Person, Package, Vehicle, Pet detection
Motion-Activated Voice DeterrenceYesYes (requires Cam Plus or Cam Protect)Yes
Included ChimeWyze Wi-Fi Chime includedChime Controller includedChime included
InstallationAdhesive strips or wiredScrew mountingScrews or screw-free adhesive plate
Weather ResistanceIP65IP65Not explicitly stated (assumed weather resistant)
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Additional FeaturesMotion-activated voice deterrence, 2 cameras for full porch coverage, removable battery pack, 30° corner kit includedPre-roll motion recording (3-6 seconds), custom detection zones, quick responses, 30° corner kit includedMotion-activated security light, 20 chime tunes with 8 sound levels, quick responses, dual-band Wi-Fi extender chime
Price (approximate)$89.98 - $109.99 (variants)$44.98$99.98
What is the Wyze Duo Cam Battery Doorbell and how does it enhance home security?The Wyze Duo Cam Battery Doorbell is a dual camera video doorbell designed to provide comprehensive security coverage for your front porch. It features a 2K front camera and a 1080p bottom camera, allowing you to monitor both visitors and packages simultaneously. With advanced AI detection, two-way audio, and a loud siren, it ensures you never miss any activity at your doorstep.
What are the key features of the Wyze Duo Cam Battery Doorbell?Key features of the Wyze Duo Cam Battery Doorbell include dual cameras for multiple viewing angles, 2K and 1080p video resolution, battery-powered or wired installation, real-time AI detections for people and packages, two-way audio, a 90 dB siren, dual-band Wi-Fi, Bluetooth 5.0, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
Can the Wyze Duo Cam Doorbell be installed wirelessly?Yes, the Wyze Duo Cam Doorbell can be installed wirelessly using its removable 6200 mAh lithium-ion battery pack. It also supports hardwired installation for continuous 24/7 local recording with a microSD card.
Does the Wyze Duo Cam Doorbell support local storage?Yes, the Wyze Duo Cam Doorbell supports local storage with a microSD card of up to 256GB, allowing for continuous 24/7 recording when hardwired.
What smart home systems are compatible with Wyze video doorbells?Wyze video doorbells, including the Duo Cam, Video Doorbell v2, and Video Doorbell Pro, are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
What is the difference between Wyze Duo Cam Doorbell, Wyze Video Doorbell v2, and Wyze Video Doorbell Pro?The Wyze Duo Cam Doorbell features dual cameras for multi-angle coverage and can be battery-powered or wired. The Wyze Video Doorbell v2 is a wired-only model with 2K resolution and local storage. The Wyze Video Doorbell Pro offers both wired and battery-powered options, an ultra-wide HD view, and quick installation, but does not have dual cameras.
Is the Wyze Duo Cam Doorbell weather-resistant?Yes, the Wyze Duo Cam Doorbell has an IP65 weather resistance rating, making it durable and suitable for use in all seasons.
What are the video resolutions and viewing angles of the Wyze Duo Cam Doorbell cameras?The Wyze Duo Cam Doorbell features a front camera with 2K resolution (2048 x 1536) and a 132° horizontal and 100° vertical field of view. The bottom camera has 1080p resolution (1920 x 1080) with a 121° horizontal and 60° vertical field of view.
Does the Wyze Video Doorbell v2 support night vision?Yes, the Wyze Video Doorbell v2 is equipped with a CMOS Starlight Sensor and F2.0 aperture, providing clear day and night vision.
Can I adjust the viewing angle of the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 offers an optional Wedge Kit accessory that allows you to adjust the viewing angle, making it ideal for homes with angled door frames or stairs.
What power options are available for Wyze video doorbells?Wyze video doorbells offer both battery-powered and wired options. The Wyze Duo Cam and Video Doorbell Pro can be installed with a battery or hardwired, while the Wyze Video Doorbell v2 is wired only.
What types of alerts and detections do Wyze video doorbells provide?Wyze video doorbells provide real-time AI detections and alerts for people, packages, motion events, and, with Cam Plus subscription, vehicle and pet detection. They also feature motion-activated voice deterrence and security lights for enhanced protection.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the installation process for the Wyze Duo Cam Doorbell?Are there any ongoing promotions or discounts for the Wyze Duo Cam Doorbell?
