Dual Lens Cameras for Vertical and Horizontal Entryway Coverage
When it comes to securing your entryway with comprehensive vertical and horizontal views, dual lens cameras provide an unbeatable advantage. Wyze offers innovative dual lens video doorbells and cameras designed to capture every angle of your doorstep, ensuring you never miss a visitor or package.
Wyze Duo Cam Battery Doorbell: Advanced Dual Lens Security
Experience full entryway coverage with Wyze Duo Cam Doorbell
The
Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered video doorbell, featuring two cameras that provide both vertical and horizontal coverage of your entryway:
- Dual Camera Views: Front camera delivers crisp 2K (2048 x 1536) resolution with a 132° horizontal and 100° vertical field of view, while the bottom camera captures packages and ground-level activity in 1080p with a 121° horizontal and 60° vertical field of view.
- Battery Powered & Wired Compatible: Comes with a removable 6200 mAh lithium-ion battery pack for wire-free installation, or can be hardwired for continuous power.
- AI-Powered Alerts: Real-time AI detections for people, packages, and vehicles with motion-activated voice deterrence that warns intruders with a clear message: "Hi, you’re currently being recorded."
- Two-Way Audio & Siren: Communicate with visitors or deter unwanted guests using two-way talk and a 90 dB siren.
- Local & Cloud Storage: Supports up to 256 GB microSD card for 24/7 local recording and cloud storage via Wyze Security Plan.
- Weather Resistant: IP65 rating ensures reliable performance in all weather conditions.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
This doorbell is perfect for homeowners seeking a versatile, dual-lens solution that covers both the door and the area below it, ideal for monitoring packages and visitors alike.
Wyze Video Doorbell v2: Wired 2K Clarity with Wide Field of View
Clear 2K wired video doorbell with wide-angle coverage
The
Wyze Video Doorbell v2 offers a wired solution with impressive video quality and essential smart features:
- 2K Video Resolution: Crystal-clear 2048 x 1536 video with a 135° horizontal and 103° vertical field of view, providing broad coverage of your entryway.
- Wide Diagonal View: A 166.8° diagonal field of view captures more of your porch area, reducing blind spots.
- Local MicroSD Storage: Supports up to 256 GB microSD cards for continuous local recording.
- Motion-Activated Voice Deterrence: Automatically warns visitors or intruders with a customizable voice message.
- Two-Way Audio: Built-in microphone and speaker allow real-time communication.
- Robust Build & Weatherproof: Polycarbonate body with resin lens and IP65 weather resistance for durability.
- Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT.
- Easy Installation: Includes wall plate, wedge mount, and all necessary hardware for a smooth wired setup.
Ideal for users who prefer a wired doorbell with a wide field of view and high-resolution video, the Wyze Video Doorbell v2 ensures you never miss a moment at your front door.
Wyze Duo Cam Pan: Dual 2K Cameras with Pan & Tilt for Full Coverage
The
Wyze Duo Cam Pan is a unique dual-camera system designed for indoor or outdoor use (with optional outdoor power adapter), delivering comprehensive coverage with pan and tilt capabilities:
- Two 2K Cameras in One: One camera remains fixed on your priority area while the second pans 360° and tilts 180° to track motion automatically.
- Color Night Vision: Enhanced night vision with integrated spotlights for clear color video even in low light.
- Auto Motion Tracking: The pan-tilt camera follows movement to keep subjects in frame.
- Integrated Siren & Spotlights: Built-in siren and spotlights enhance security and deterrence.
- Weather Resistant: IP65 rating for outdoor durability (with power adapter).
- Continuous Local Recording: Supports microSD cards up to 512 GB for 24/7 recording.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
- Multiple Mounting Options: Four unique mounting styles for versatile placement.
While not a doorbell, the Duo Cam Pan’s dual-camera design with pan and tilt offers exceptional horizontal and vertical coverage, making it a great complement to your entryway security setup.
Why Choose Wyze Dual Lens Cameras for Your Entryway?
"Dual lens cameras provide unmatched coverage by capturing both vertical and horizontal views, ensuring no activity goes unnoticed at your doorstep."
Wyze’s dual lens cameras and doorbells combine high-resolution video, smart AI detection, and flexible power options to deliver comprehensive security solutions. Whether you want a battery-powered doorbell with dual cameras or a wired doorbell with wide-angle views, Wyze has you covered.
Summary of Dual Lens Camera Options
Product | Dual Lens | Video Resolution | Power Source | Key Features | Weather Resistance |
Wyze Duo Cam Battery Doorbell | Yes | Front 2K + Bottom 1080p | Battery or Wired | AI alerts, voice deterrence, 2-way audio | IP65 |
Wyze Video Doorbell v2 | Single lens but wide FOV | 2K | Wired | Voice deterrence, local storage | IP65 |
Wyze Duo Cam Pan | Yes | Dual 2K | Wired (outdoor adapter optional) | Pan & tilt, motion tracking, siren | IP65 |
Enhance Your Home Security with Wyze Dual Lens Cameras
Investing in a Wyze dual lens camera or doorbell means securing your home with advanced technology that covers every angle. From vertical package detection to horizontal visitor monitoring, these devices provide peace of mind with smart features and crystal-clear video.
Additional Images
Smart doorbell installation for enhanced home security
# Product Tags Recap
What are dual lens cameras and how do they improve entryway security?
Dual lens cameras feature two separate lenses to capture both vertical and horizontal views of your entryway. This ensures comprehensive coverage, allowing you to monitor visitors at your door as well as packages or activity at ground level, reducing blind spots and enhancing overall security.What is the Wyze Duo Cam Battery Doorbell and what features does it offer?
The Wyze Duo Cam Battery Doorbell is an advanced, battery-powered video doorbell with two cameras: a front-facing 2K camera for wide entryway coverage and a bottom 1080p camera for monitoring packages and ground-level activity. It offers AI-powered alerts, motion-activated voice deterrence, two-way audio, a 90 dB siren, local and cloud storage, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.Can the Wyze Duo Cam Battery Doorbell be installed without wiring?
Yes, the Wyze Duo Cam Battery Doorbell comes with a removable 6200 mAh lithium-ion battery pack for wire-free installation. It can also be hardwired for continuous power if desired.Does the Wyze Duo Cam Battery Doorbell support local and cloud storage?
Yes, the Wyze Duo Cam Battery Doorbell supports up to a 256 GB microSD card for 24/7 local recording and also offers cloud storage through the Wyze Security Plan.Is the Wyze Duo Cam Battery Doorbell weather resistant?
Yes, the Wyze Duo Cam Battery Doorbell has an IP65 weather resistance rating, ensuring reliable performance in various weather conditions.What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 is a wired doorbell offering 2K video resolution, a 135° horizontal and 103° vertical field of view, a wide 166.8° diagonal view, support for up to 256 GB microSD cards for local recording, motion-activated voice deterrence, two-way audio, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.How does the Wyze Video Doorbell v2 differ from the Duo Cam Battery Doorbell?
The Wyze Video Doorbell v2 is a single-lens, wired doorbell with a wide field of view and 2K resolution, while the Duo Cam Battery Doorbell features dual lenses for both vertical and horizontal coverage and can be installed wire-free or hardwired. Both offer smart features like voice deterrence and two-way audio.What is the Wyze Duo Cam Pan and how does it enhance security?
The Wyze Duo Cam Pan is a dual 2K camera system designed for indoor or outdoor use (with an optional outdoor power adapter). One camera remains fixed while the other pans 360° and tilts 180° to track motion. It features color night vision, auto motion tracking, integrated siren and spotlights, IP65 weather resistance, continuous local recording, and smart home integration.Can the Wyze Duo Cam Pan be used outdoors?
Yes, the Wyze Duo Cam Pan can be used outdoors when paired with the optional outdoor power adapter. It has an IP65 weather resistance rating for durability in various conditions.Are Wyze dual lens cameras compatible with smart home systems?
Yes, Wyze dual lens cameras and doorbells are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and control.What storage options are available for Wyze dual lens cameras?
Wyze dual lens cameras support local storage via microSD cards (up to 256 GB or 512 GB depending on the model) for continuous 24/7 recording, as well as cloud storage through the Wyze Security Plan.Why should I choose a Wyze dual lens camera for my entryway?
Wyze dual lens cameras provide unmatched entryway coverage by capturing both vertical and horizontal views, ensuring you never miss a visitor or package. They combine high-resolution video, smart AI detection, flexible power options, and robust weather resistance for comprehensive home security.
