Wyze Duo Cam: Split Screen Doorbell Camera for Upper & Lower Angles
Discover the Wyze Duo Cam Doorbell with Split Screen Function
If you're searching for a doorbell camera with split screen function for upper and lower angles, the Wyze Duo Cam Battery Doorbell is the ultimate solution. Designed to provide comprehensive porch coverage, this advanced battery-powered video doorbell features dual cameras that deliver two distinct views simultaneously — perfect for monitoring both people and packages from different angles. Alongside the Duo Cam, the Wyze Video Doorbell v2 offers a wired alternative with crystal-clear 2K video and essential smart features. Both models bring unique strengths to your home security setup.
Wyze Duo Cam Battery Doorbell: Dual-Camera Innovation for Full Porch Coverage
Wyze Duo Cam Doorbell Lifestyle Experience full porch protection with Wyze Duo Cam Doorbell
Dual Cameras, Dual Views
  • Two cameras provide split-screen views: the top camera captures visitors at eye level, while the bottom camera focuses on packages and the doorstep.
  • Field of View: Top camera offers 132° x 100°, bottom camera 121° x 60°, ensuring no blind spots.
  • 2K resolution on the top camera and 1080p on the bottom deliver sharp, detailed video day and night.
Smart Features for Enhanced Security
  • Real-time AI detections: Person, package, pet, and vehicle detection with instant alerts.
  • Motion-activated voice deterrence: Warn unwanted visitors automatically.
  • Two-way audio: Communicate with visitors or delivery personnel from anywhere.
  • Wi-Fi Chime included: Hear doorbell alerts anywhere in your home without wiring hassles.
Flexible Power and Installation
  • Battery-powered with a removable battery pack for easy charging.
  • Option to hardwire for continuous 24/7 local recording with a microSD card (sold separately).
  • Easy installation with adhesive strips or screws.
Weatherproof and Reliable
  • Rated IP65 weather resistant, built to withstand rain, snow, and heat.
  • Dual-band Wi-Fi support (2.4 GHz and 5 GHz) for stable connectivity.
Wyze Video Doorbell v2: Wired 2K Video with Local Storage
Wyze Video Doorbell v2 Lifestyle Wired smart doorbell with crystal-clear 2K video
Crisp 2K Video and Head-to-Toe View
  • 2K resolution with a 135° x 103° field of view captures every detail on your porch.
  • Includes a 30° corner wedge kit for perfect angled mounting to reduce blind spots.
Local and Cloud Storage Options
  • First smart doorbell with an onboard microSD card slot for continuous local recording.
  • Supports Cam Plus subscription for AI person and package detection, plus unlimited cloud storage.
Essential Smart Doorbell Features
  • Two-way audio for seamless communication.
  • Motion-activated voice deterrence to warn off suspicious visitors.
  • Works with your existing mechanical chime via included chime controller.
  • Compatible with Alexa and Google Home for voice commands and live feed viewing.
Durable and Weatherproof
  • IP65 rating ensures protection against harsh weather conditions.
  • Award-winning color night vision with a starlight sensor for clear nighttime video.
Why Choose Wyze Duo Cam Doorbell for Split Screen Functionality?
The Wyze Duo Cam Doorbell stands out as the only Wyze doorbell offering true split screen functionality with two cameras covering upper and lower angles simultaneously. This feature is ideal for:
  • Monitoring visitors’ faces and packages at the doorstep without missing any detail.
  • Reducing blind spots with wide and overlapping fields of view.
  • Receiving AI-powered alerts tailored to people, packages, pets, and vehicles.
If split screen viewing and dual-angle coverage are your priorities, the Duo Cam is the perfect choice.
Enhance Your Setup with the Wyze Video Doorbell v2 Wedge Kit
For those using the Wyze Video Doorbell v2, the Wedge Kit accessory allows you to adjust the doorbell’s angle for better coverage, especially useful for angled door frames or porches with stairs.
  • Includes horizontal and vertical brackets for flexible mounting.
  • Weather-resistant and easy to install.
  • Helps eliminate blind spots and maximize your doorbell’s field of view.
Summary: Best Doorbell Cameras with Split Screen and Dual Views
FeatureWyze Duo Cam Battery DoorbellWyze Video Doorbell v2
Camera SetupDual cameras (split screen)Single camera
Video Resolution2K (top), 1080p (bottom)2K
PowerBattery or hardwiredWired only
Local StoragemicroSD support (with hardwire)microSD slot for continuous recording
AI DetectionPerson, package, pet, vehiclePerson, package (with Cam Plus)
Voice DeterrenceMotion-activatedMotion-activated
InstallationAdhesive or screwsScrews only
Weather ResistanceIP65IP65
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Protect your home with the most advanced doorbell cameras featuring split screen views and smart AI detection. Whether you prefer the wireless flexibility of the Wyze Duo Cam Battery Doorbell or the wired power and local storage of the Wyze Video Doorbell v2, Wyze has you covered.
Product Highlights
By choosing Wyze doorbell cameras, you invest in reliable, feature-rich smart home security that keeps your porch safe and your mind at ease.
FeatureWyze Duo Cam Battery DoorbellWyze Video Doorbell v2Wyze Video Doorbell v2 Wedge Kit
TypeBattery-powered video doorbell with dual camerasWired video doorbell with 2K videoAccessory for Doorbell v2
Video ResolutionTop: 2K, Bottom: 1080p2K (2048 x 1536)N/A
CamerasDual cameras (people and package views)Single cameraN/A
Field of ViewTop: 132° x 100°, Bottom: 121° x 60°135° horizontal x 103° verticalN/A
Power SourceWyze Removable Battery Pack or Hardwired (AC 16-24V)Wired (AC 16-24V)N/A
Local StoragemicroSD card support (up to 256GB), 24/7 recording with hardwiremicroSD card support, 24/7 continuous recordingN/A
Two-Way AudioYesYesN/A
Motion-Activated Voice DeterrenceYesYes (requires Cam Plus subscription)N/A
Included ChimeWyze Wi-Fi ChimeChime Controller includedN/A
InstallationAdhesive strips or screwsScrew mountingQuick installation
Weather ResistanceIP65IP65Weather resistant
Smart FeaturesReal-time AI detections (person, package, pet, vehicle), facial recognition (with Cam Plus)Person and package detection (with Cam Plus)N/A
CompatibilityWorks with Alexa, Google Assistant, IFTTTWorks with Alexa, Google Assistant, IFTTTCompatible with Doorbell v2 only
Mounting Accessories30° Corner Kit included30° Corner Kit includedIncludes 1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, screws
Price (approximate)$89.98 - $109.99 (sold out)$44.98$8.99 (Wedge Kit Only) / $51.97 (Doorbell v2 + Wedge Kit)
Color OptionsBlack, SilverBlackBlack
What is the Wyze Duo Cam Doorbell and how does its split screen function work?The Wyze Duo Cam Battery Doorbell is a smart video doorbell featuring dual cameras that provide a split screen view of your porch. The top camera captures visitors at eye level, while the bottom camera focuses on packages and the doorstep. This allows you to monitor both people and packages simultaneously, reducing blind spots and enhancing security.
What are the main differences between the Wyze Duo Cam Battery Doorbell and the Wyze Video Doorbell v2?The Wyze Duo Cam Battery Doorbell features dual cameras with split screen views, is battery-powered (with optional hardwiring), and offers AI detection for people, packages, pets, and vehicles. The Wyze Video Doorbell v2 is a wired doorbell with a single 2K camera, local microSD storage, and supports AI detection for people and packages with a Cam Plus subscription. Both models are IP65 weather resistant and support smart home integration.
Does the Wyze Duo Cam Doorbell support local storage?Yes, the Wyze Duo Cam Battery Doorbell supports local storage via a microSD card when hardwired. This allows for continuous 24/7 local recording, providing extra security and peace of mind.
Can I use the Wyze Duo Cam Doorbell wirelessly?Yes, the Wyze Duo Cam Battery Doorbell is battery-powered and can be installed wirelessly using adhesive strips or screws. It also includes a removable battery pack for easy charging. For continuous recording, you can choose to hardwire the doorbell.
What smart features are included with Wyze doorbell cameras?Wyze doorbell cameras offer real-time AI detections (person, package, pet, and vehicle), motion-activated voice deterrence, two-way audio for communication, instant alerts, and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.
Is the Wyze Duo Cam Doorbell weatherproof?Yes, the Wyze Duo Cam Battery Doorbell is rated IP65 weather resistant, making it suitable for use in rain, snow, and heat.
What is the field of view and video resolution of the Wyze Duo Cam Doorbell?The Wyze Duo Cam Doorbell's top camera offers a 132° x 100° field of view with 2K resolution, while the bottom camera provides a 121° x 60° field of view with 1080p resolution. This ensures comprehensive coverage of your porch area.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 is the first Wyze doorbell to feature an onboard microSD card slot for continuous local recording, in addition to supporting cloud storage with a Cam Plus subscription.
What is the Wyze Video Doorbell v2 Wedge Kit and how does it improve coverage?The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to adjust the angle of your doorbell for better coverage, especially on angled door frames or porches with stairs. It includes horizontal and vertical brackets, is weather-resistant, and helps eliminate blind spots.
Which Wyze doorbell camera is best for split screen and dual-angle coverage?The Wyze Duo Cam Battery Doorbell is the best choice for split screen and dual-angle coverage, as it is the only Wyze doorbell with two cameras providing simultaneous upper and lower views. This makes it ideal for monitoring both visitors and packages at your doorstep.
Are Wyze doorbell cameras compatible with smart home systems?Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 are compatible with Alexa and Google Assistant, allowing for voice commands and live feed viewing. The Duo Cam also supports IFTTT integration.
What installation options are available for Wyze doorbell cameras?The Wyze Duo Cam Battery Doorbell can be installed using adhesive strips or screws and can be powered by battery or hardwired. The Wyze Video Doorbell v2 is a wired-only device and is installed using screws.
What are the key differences between the Wyze Duo Cam Doorbell and the Wyze Video Doorbell v2?Can you explain the installation process for the Wyze Duo Cam Doorbell?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Duo Cam Doorbell?
