Wireless Smart Doorbells: 30-Second, Screw-Free Installation
Wireless Smart Doorbells Installed in 30 Seconds Without Screws
Upgrade your home security effortlessly with the latest wireless smart doorbells that can be installed in just 30 seconds—no screws required. These innovative devices combine advanced video technology, two-way audio, and smart alerts to keep your front porch safe and connected. Whether you want a battery-powered option or a wired solution, these smart doorbells offer quick, screw-free installation with adhesive plates or mounting kits, making setup a breeze for any homeowner.
Wyze Video Doorbell Pro: Quick, Wireless, and Feature-Packed
Wyze Video Doorbell Pro Lifestyle Alt text: Modern home with Wyze Video Doorbell Pro installed on front door The Wyze Video Doorbell Pro is designed for those who want a wider view and crystal-clear HD video with the convenience of wireless or hardwired power options. Its standout feature is the ultra-fast installation process—mount it in 30 seconds using the included screw-free adhesive plate, eliminating the need for drilling or screws.
Key Features:
  • Wireless or Hardwired Power: Flexibility to choose battery power or connect to existing wiring.
  • Ultra-Wide Viewing Angle: Capture more of your porch with a wider field of view.
  • Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus integration.
  • Two-Way Audio: Communicate instantly with visitors or delivery personnel.
  • Motion-Activated Security Light: Enhances visibility and deters unwanted guests.
  • Customizable Chime: 20 unique tunes with 8 sound levels for personalized alerts.
  • Voice Assistant Integration: Works seamlessly with Alexa and Google Assistant.
This doorbell is perfect for homeowners seeking a fast, no-fuss installation combined with advanced smart home features.
Wyze Duo Cam Battery Doorbell: Dual Cameras, Battery-Powered Freedom
Wyze Duo Cam Doorbell Lifestyle Alt text: Family greeting visitor at front porch with Wyze Duo Cam Doorbell For those who prefer a battery-powered doorbell with enhanced coverage, the Wyze Duo Cam Battery Doorbell offers dual camera views—one for people and one for packages—ensuring nothing goes unnoticed. Its wireless design means you can install it quickly without screws, using the included adhesive tape and mounting accessories.
Highlights:
  • Dual Cameras: Front camera with 2K resolution and bottom camera in 1080p for comprehensive monitoring.
  • Battery-Powered: Includes a removable battery pack with USB-C charging for easy power management.
  • Local and Cloud Storage: Supports up to 256GB microSD card for 24/7 local recording plus cloud backup.
  • Two-Way Audio & Siren: Communicate with visitors and deter intruders with a 90 dB siren.
  • Weather Resistant: IP65 rating ensures reliable performance in all weather conditions.
  • Smart AI Alerts: Real-time detection and notifications for people, packages, and motion.
This doorbell is ideal for renters or anyone wanting a flexible, screw-free installation with powerful security features.
The Front Porch Security Bundle: Complete Smart Home Access
If you want an all-in-one solution, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime for a comprehensive smart home entry system. This bundle offers easy installation without screws for the doorbell, plus remote locking capabilities.
Bundle Benefits:
  • 1080p HD Video Doorbell: View your porch clearly with two-way audio.
  • Remote Lock/Unlock: Control your door lock from anywhere via the Wyze app.
  • Motion and Lock History: Stay informed with detailed event logs.
  • Voice Assistant Compatible: Works with Alexa and Google Assistant.
  • Screw-Free Doorbell Installation: Use adhesive strips for quick setup without drilling.
This bundle is perfect for homeowners looking to upgrade both security and convenience with minimal installation effort.
Optional Accessory: Wyze Video Doorbell v2 Wedge Kit
For angled door frames or porches with stairs, the Wyze Video Doorbell v2 Wedge Kit is a must-have accessory. It allows you to adjust the viewing angle for maximum coverage and eliminates blind spots.
Features:
  • Includes horizontal and vertical brackets for flexible mounting.
  • Quick installation with included screws or adhesive.
  • Weather-resistant and durable plastic construction.
  • Compatible exclusively with Wyze Video Doorbell v2.
Why Choose Screw-Free Wireless Smart Doorbells?
Installing a smart doorbell has never been easier. With screw-free adhesive mounting options, you can have your doorbell up and running in just 30 seconds—no tools, no hassle. These wireless smart doorbells provide high-definition video, two-way communication, and smart alerts to keep your home safe and connected, all while preserving your doorframe and walls.
Summary of Featured Wireless Smart Doorbells
ProductPower TypeVideo ResolutionInstallation TimeSpecial Features
Wyze Video Doorbell ProBattery or HardwiredHD (1080p+)30 secondsUltra-wide view, motion light, Alexa/Google
Wyze Duo Cam Battery DoorbellBatteryDual 2K + 1080pScrew-free mountDual cameras, siren, removable battery
Front Porch Security BundleWired + Wireless1080pAdhesive mountLock integration, two-way audio
Enhance Your Home Security Today
Choose a wireless smart doorbell that fits your lifestyle and enjoy the convenience of quick, screw-free installation. Whether you want the advanced features of the Wyze Video Doorbell Pro or the dual-camera coverage of the Wyze Duo Cam Battery Doorbell, these products deliver reliable security with minimal setup time.
FeatureWyze Video Doorbell ProWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
TypeWired/Wireless Video DoorbellWired Video DoorbellBundle (Wyze Lock + Video Doorbell and/or Cam)Accessory (Wedge Kit for Doorbell v2)
Video ResolutionHD (1080p)2K (2048 x 1536)1080p HD (Video Doorbell and Chime)N/A (Accessory)
Field of ViewUltra-wide angle (wider view)135° horizontal, 103° vertical, 166.8° diagonal1080p HD camera view (Video Doorbell and Chime)Adjusts viewing angle for Doorbell v2
PowerHardwired or BatteryHardwiredDepends on included devicesN/A
Two-Way AudioYesYesYesN/A
Local StorageNot specified (Cloud with Cam Plus)microSD local storage (up to 256GB)Depends on included devicesN/A
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableN/A
Motion-Activated Voice DeterrenceYes (with Cam Plus)Yes (with Cam Plus)Included via Video DoorbellN/A
Night VisionColor Night VisionColor Night Vision (Starlight sensor)1080p HD with night vision (Video Doorbell and Chime)N/A
Weather ResistanceIP65IP65IP65Weather resistant
Chime IncludedYesYes (Chime Controller included)Yes (Wyze Video Doorbell and Chime included)N/A
Smart Home IntegrationAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantN/A
Special Features- Motion-activated security light- Pre-roll motion recording (3-6 seconds)- Remote lock/unlock with Wyze Lock- 15° horizontal and 7.5° vertical angle brackets
- 20 unique chime tunes and 8 sound levels- Works with existing chime- Lock history view in app- Quick installation
- Dual-band Wi-Fi Extender chime- Two-way talk- Includes Wyze Lock- 1 year warranty
Price$99.98$44.98From $123.99 (varies by variant)$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge)
Included ItemsDoorbell Pro, ChimeDoorbell v2, Chime ControllerWyze Lock + Video Doorbell and Chime (or other combos)1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, screws, guide
How do wireless smart doorbells install without screws?Wireless smart doorbells use adhesive plates or mounting kits that allow for quick, screw-free installation. Simply attach the adhesive plate to your doorframe or wall, and mount the doorbell in as little as 30 seconds—no drilling or tools required.
What are the main features of the Wyze Video Doorbell Pro?The Wyze Video Doorbell Pro offers wireless or hardwired power options, an ultra-wide viewing angle, HD video, smart detection alerts for people, packages, vehicles, and pets, two-way audio, a motion-activated security light, customizable chimes, and voice assistant integration with Alexa and Google Assistant.
Can I install the Wyze Duo Cam Battery Doorbell without screws?Yes, the Wyze Duo Cam Battery Doorbell is designed for screw-free installation using the included adhesive tape and mounting accessories, making it ideal for renters or anyone who wants to avoid drilling.
What makes the Wyze Duo Cam Battery Doorbell unique?The Wyze Duo Cam Battery Doorbell features dual cameras—one with 2K resolution for people and another with 1080p for packages—providing comprehensive front porch coverage. It also includes a removable battery pack, local and cloud storage, two-way audio, a 90 dB siren, weather resistance, and smart AI alerts.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes a Wyze Video Doorbell, Wyze Lock, and Chime. It offers 1080p HD video, two-way audio, remote lock/unlock via the Wyze app, motion and lock history, voice assistant compatibility, and screw-free doorbell installation with adhesive strips.
Is there an accessory to adjust the viewing angle of my Wyze Video Doorbell?Yes, the Wyze Video Doorbell v2 Wedge Kit is an optional accessory that allows you to adjust the viewing angle for better coverage, especially for angled door frames or porches with stairs. It includes horizontal and vertical brackets and can be installed with screws or adhesive.
Are wireless smart doorbells weather resistant?Yes, models like the Wyze Duo Cam Battery Doorbell are IP65 weather resistant, ensuring reliable performance in various weather conditions.
Do these smart doorbells work with Alexa or Google Assistant?Yes, both the Wyze Video Doorbell Pro and the Front Porch Security Bundle are compatible with Alexa and Google Assistant for seamless smart home integration.
Can I use local storage with Wyze smart doorbells?Yes, the Wyze Duo Cam Battery Doorbell supports up to a 256GB microSD card for 24/7 local recording, in addition to offering cloud backup options.
How long does it take to install a wireless smart doorbell?Most wireless smart doorbells, such as the Wyze Video Doorbell Pro, can be installed in just 30 seconds using the included screw-free adhesive plate.
What are the key features of the Wyze Video Doorbell Pro?Can you tell me more about the Wyze Duo Cam Battery Doorbell?Do you have any deals, ongoing sales, discounts, or promotions available?
