Wyze Cam Pan v3: The Smart Security Camera with Push Notifications for Doors and Windows
If you're searching for a reliable camera that sends push notifications whenever a window or door is opened, the
Wyze Cam Pan v3 is an excellent choice. This versatile security camera offers 360° horizontal and 180° vertical coverage, ensuring no blind spots in your home or office. Whether you want to monitor indoor spaces or keep an eye on your outdoor entrances, the Wyze Cam Pan v3 delivers smart alerts and comprehensive surveillance.
Key Features of Wyze Cam Pan v3
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 boasts a complete 360° horizontal rotation and 180° vertical tilt, allowing you to monitor every corner of a room or outdoor area. With a rotation speed of up to 110° per second and an 8x digital zoom, you can easily track movement and zoom in on suspicious activity.
Push Notifications for Instant Alerts
Stay informed in real-time with push notifications sent directly to your smartphone whenever motion is detected, including when a door or window is opened. This feature is perfect for home security, alerting you immediately to potential intrusions or unexpected activity.
High-Definition Video and Color Night Vision
Capture crisp 1080p HD video with a 120° field of view. The camera is equipped with 4 IR LEDs for color night vision, providing clear images even in low-light conditions. This ensures you never miss a detail, day or night.
Two-Way Audio with Noise Cancellation
Communicate directly through the camera using built-in microphone and speaker with noise and echo cancellation. Whether you want to greet visitors or warn off intruders, the two-way audio feature makes interaction easy and clear.
Weather Resistant for Indoor and Outdoor Use
Rated IP65 for weather resistance, the Wyze Cam Pan v3 is designed to withstand rain, snow, and dust, making it suitable for both indoor and outdoor installation. For outdoor use, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures safe and reliable power.
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 weather resistant for outdoor security
Easy Integration and Compatibility
The camera supports Wi-Fi 802.11 b/g/n on 2.4 GHz networks and integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to control and automate your security system with voice commands or smart routines.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
For those who want to maximize their security, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera features combined with a 30-day trial of Cam Plus. This subscription service provides advanced AI detection, longer event video storage, and person detection alerts, making it easier to distinguish between family members, pets, and strangers.
What’s Included in the Bundle?
- Wyze Cam Pan v3 camera
- 6-foot micro USB cable and power adapter
- Mounting kit and quick start guide
- 30-day Cam Plus trial for enhanced smart alerts and cloud storage
This bundle is perfect for users who want to receive push notifications specifically when doors or windows open, with added AI-powered accuracy to reduce false alarms.
Pan v3 Outdoor Bundle: Complete Outdoor Security Solution
If your priority is outdoor security with push notifications for entry points like windows and doors, the
Pan v3 Outdoor Bundle is tailored for you. It includes the Wyze Cam Pan v3 camera plus an IP67-rated outdoor power adapter and extended cabling for flexible installation.
Outdoor-Ready Features
- IP67 weather resistance for superior protection against harsh elements
- 12.5 ft total cable length for versatile mounting options
- Supports up to 128GB microSD card for local storage of HD video
- Same 1080p HD video, 360° pan, 180° tilt, and color night vision as the standard Pan v3
This bundle ensures your camera stays powered and protected outdoors, while still delivering instant push notifications when windows or doors are opened.
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1_7d89a30d-1292-41d4-b3ef-71d305710824.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 outdoor lifestyle">
Wyze Cam Pan v3 outdoor security in action
Why Choose Wyze Cam Pan v3 for Door and Window Alerts?
- Real-time push notifications keep you instantly informed of any entry point activity.
- 360° pan and 180° tilt cover all angles, eliminating blind spots.
- Color night vision ensures clear monitoring even in darkness.
- Two-way audio lets you communicate through the camera remotely.
- Weather-resistant design allows flexible indoor or outdoor placement.
- Smart home integration with Alexa, Google Assistant, and IFTTT for seamless control.
Whether you want to monitor your home, office, or vacation property, the Wyze Cam Pan v3 series offers a smart, affordable, and reliable solution to keep your doors and windows secure.
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Two-way audio with Wyze Cam Pan v3">
Communicate instantly with two-way audio
Summary of Wyze Cam Pan v3 Variants
Product | Price | Key Features | Ideal For |
Wyze Cam Pan v3 | $39.98 | 360° pan, 1080p HD, push notifications, IP65 | Indoor/outdoor basic security |
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle | $39.98 | Includes Cam Plus AI alerts and cloud storage | Enhanced smart detection |
Pan v3 Outdoor Bundle | $76.96 | IP67 rating, outdoor power adapter, extended cable | Outdoor security with power |
Conclusion
For a camera that sends push notifications whenever a window or door is opened, the
Wyze Cam Pan v3 and its bundles provide an unbeatable combination of smart features, weather resistance, and affordability. With full 360° coverage, color night vision, and two-way audio, you can protect your home or business with confidence and ease.
What is the Wyze Cam Pan v3 and how does it enhance home security?
The Wyze Cam Pan v3 is a smart security camera designed to provide comprehensive surveillance for your home or office. It features 360° horizontal pan and 180° vertical tilt, ensuring no blind spots. The camera sends real-time push notifications to your smartphone whenever motion is detected, including when a door or window is opened, making it an excellent choice for monitoring entry points and enhancing home security.Does the Wyze Cam Pan v3 send push notifications when a door or window is opened?
Yes, the Wyze Cam Pan v3 sends instant push notifications to your smartphone whenever it detects motion, including when a door or window is opened. This feature helps you stay informed about any activity at your entry points in real time.Can the Wyze Cam Pan v3 be used both indoors and outdoors?
Absolutely. The Wyze Cam Pan v3 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. For outdoor installations, it is recommended to use the Wyze Outdoor Power Adapter (sold separately) to ensure safe and reliable power.What video quality does the Wyze Cam Pan v3 offer?
The Wyze Cam Pan v3 captures crisp 1080p HD video with a 120° field of view. It also features color night vision with 4 IR LEDs, ensuring clear images even in low-light conditions.Does the Wyze Cam Pan v3 have two-way audio?
Yes, the Wyze Cam Pan v3 is equipped with two-way audio, including a built-in microphone and speaker with noise and echo cancellation. This allows you to communicate directly through the camera, whether greeting visitors or warning off intruders.What smart home integrations are available with the Wyze Cam Pan v3?
The Wyze Cam Pan v3 integrates seamlessly with Alexa, Google Assistant, and IFTTT. This allows you to control the camera and automate your security system using voice commands or smart routines.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the Wyze Cam Pan v3 camera, a 6-foot micro USB cable and power adapter, a mounting kit, a quick start guide, and a 30-day trial of Cam Plus. The Cam Plus subscription provides advanced AI detection, longer event video storage, and person detection alerts.What are the benefits of the Pan v3 Outdoor Bundle?
The Pan v3 Outdoor Bundle is designed for outdoor security and includes the Wyze Cam Pan v3 camera, an IP67-rated outdoor power adapter, and a 12.5 ft cable for flexible installation. It offers superior weather resistance, supports up to 128GB microSD card for local HD video storage, and delivers instant push notifications for entry point activity.How does the Wyze Cam Pan v3 help reduce false alarms?
With the Cam Plus subscription, the Wyze Cam Pan v3 offers advanced AI-powered detection, including person detection alerts. This helps distinguish between family members, pets, and strangers, reducing false alarms and ensuring you receive relevant notifications.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports local storage with microSD cards up to 128GB, allowing you to record and store HD video footage. Additionally, with the Cam Plus subscription, you can access extended cloud storage for event videos.Is the Wyze Cam Pan v3 easy to install and set up?
Yes, the Wyze Cam Pan v3 comes with a mounting kit and a quick start guide, making installation straightforward. It connects to Wi-Fi 802.11 b/g/n on 2.4 GHz networks and can be set up quickly using the Wyze app.
