Compact Home Security Camera: Wyze Cam Pan v3
When it comes to a compact home security camera that sends instant phone alerts on movement, the
Wyze Cam Pan v3 stands out as a top choice. This redesigned indoor/outdoor camera offers 360° horizontal pan and 180° vertical tilt, giving you full coverage of your home or property. Its compact size makes it easy to place anywhere without being obtrusive, while its IP65 weather resistance ensures reliable performance rain or shine.
Key Features of Wyze Cam Pan v3
- 360° Pan & 180° Tilt: Complete room or yard coverage with smooth, quiet motorized movement.
- Instant Phone Alerts: Receive real-time notifications on your phone whenever motion or sound is detected.
- Automatic Motion Tracking: The camera automatically follows moving objects, ensuring you never miss important activity.
- Color Night Vision: Equipped with a Starlight Sensor, it delivers vivid color video even in low light.
- Two-Way Audio: Speak and listen through the camera using the Wyze app, perfect for interacting with visitors or pets.
- Privacy Mode: Easily disable the camera’s view by pointing it downward when you want privacy.
- Weather Resistant: Rated IP65, suitable for outdoor use with the addition of the Wyze Outdoor Power Adapter (sold separately).
Technical Specs
- Video Resolution: 1080p Full HD
- Video Encoding: H.264
- Field of View: 120°
- Rotation Speed: Up to 110° per second
- Connectivity: 2.4 GHz Wi-Fi
- Storage: Supports up to 256 GB microSD card for local storage
- Operating Temperature: -20°C to 50°C (-4°F to 122°F)
The Wyze Cam Pan v3 is perfect for those who want a compact, versatile security camera that actively monitors and alerts you instantly on your phone.
Reliable outdoor security with Wyze Cam Pan v3
Power Your Pan v3 Anywhere: Pan v3 + Lamp Socket v2 Bundle
For users looking to install the Wyze Cam Pan v3 outdoors without the hassle of finding a nearby outlet, the
Pan v3 + Lamp Socket v2 Bundle is an ideal solution. This bundle allows you to power your Pan v3 camera directly from an existing outdoor light fixture, eliminating the need for extra wiring or extension cords.
Why Choose the Pan v3 + Lamp Socket v2 Bundle?
- Flexible Power Source: Uses your outdoor lamp socket to power the camera continuously.
- No Wiring Hassle: Simply screw in the lamp socket adapter and mount your camera—no electrician needed.
- Smart Lighting Integration: Control your outdoor lights via the Wyze app, and set them to turn on automatically when motion is detected by the camera.
- Dusk to Dawn Automation: Lights can be scheduled to turn on at sunset and off at sunrise, saving energy and enhancing security.
- Multiple Socket Linking: Connect multiple lamp sockets for broader coverage and synchronized lighting control.
Compatibility & Installation
- Compatible with Wyze Cam Pan v3, Wyze Cam v3/v3 Pro/v4, and other Wyze cameras.
- Installation is as easy as screwing in a lightbulb.
- Recommended to use CFL or LED bulbs under 20W for safety and thermal reasons.
This bundle transforms your existing outdoor lighting into a smart security system powered by the Wyze Cam Pan v3.
Comprehensive Protection: Essential Security Bundle Featuring Wyze Cam Pan v3
For those seeking an all-in-one home security solution, the
Essential Security Bundle includes the Wyze Cam Pan v3 alongside other advanced security devices to cover every angle of your home.
Bundle Components
- Wyze Cam Pan v3: Pan and tilt camera with motion tracking, color night vision, and two-way audio.
- Wyze Video Doorbell v2: 1080p HD video doorbell with two-way audio and person detection.
- Wyze Lock Bolt: Smart lock with fingerprint sensor, backlit keypad, and auto-lock feature.
- Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision for indoor/outdoor use.
Benefits of the Bundle
- Seamless integration of multiple security devices controlled via the Wyze app.
- Real-time alerts and cloud/local recording options.
- Weather-resistant devices rated IP65 for outdoor durability.
- Enhanced peace of mind with comprehensive coverage from door to yard.
The Essential Security Bundle is perfect for homeowners who want a robust, easy-to-manage security system featuring the versatile Wyze Cam Pan v3.
Enhance Your Wyze Cam Pan v3 Experience
Stylish Protection with Wyze Cam Pan v3 Skins
Customize and protect your Wyze Cam Pan v3 with vinyl skins by dBrand. These skins offer scratch protection and a fresh look, available in styles like Green Camo and Triple Black.
Discreet Security with Wyze Cam Vase
For indoor use, the Wyze Cam Vase combines home decor with security. It houses your Wyze Cam v3 or v4 discreetly, blending seamlessly into your living space while keeping an eye on what matters.
Why Choose Wyze Cam Pan v3 for Your Home Security?
Wyze Cam Pan v3 offers a compact, affordable, and feature-rich security camera solution that fits perfectly in any home environment. Its instant phone alerts, automatic motion tracking, and weather resistance make it a reliable choice for both indoor and outdoor security needs.
Stay connected with two-way audio on Wyze Cam Pan v3
Summary of Products Mentioned
What are the key features of the Wyze Cam Pan v3 home security camera?
The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, instant phone alerts for motion and sound, automatic motion tracking, color night vision with a Starlight Sensor, two-way audio, privacy mode, and IP65 weather resistance for reliable indoor and outdoor use.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is rated IP65 weather resistant, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). It can withstand rain, snow, and a wide range of temperatures.How does the Wyze Cam Pan v3 send instant phone alerts?
The Wyze Cam Pan v3 uses motion and sound detection to send real-time notifications directly to your smartphone via the Wyze app, ensuring you are immediately informed of any activity.What is the video quality of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 records in 1080p Full HD resolution, providing clear and detailed video footage for both day and night monitoring.Does the Wyze Cam Pan v3 support local video storage?
Yes, the Wyze Cam Pan v3 supports local storage with a microSD card of up to 256 GB, allowing you to record and review footage without a subscription.How does the Pan v3 + Lamp Socket v2 Bundle work?
The Pan v3 + Lamp Socket v2 Bundle allows you to power your Wyze Cam Pan v3 directly from an existing outdoor light fixture. Simply screw in the lamp socket adapter and mount your camera—no extra wiring or electrician required.Can I control my outdoor lights with the Pan v3 + Lamp Socket v2 Bundle?
Yes, the bundle enables smart lighting integration through the Wyze app. You can control your outdoor lights, set them to turn on automatically when motion is detected, and schedule dusk-to-dawn automation for energy savings and enhanced security.What is included in the Essential Security Bundle featuring Wyze Cam Pan v3?
The Essential Security Bundle includes the Wyze Cam Pan v3, Wyze Video Doorbell v2, Wyze Lock Bolt, and two Wyze Cam OG Cameras. This bundle provides comprehensive home security coverage, all managed through the Wyze app.Are there accessories available to customize the Wyze Cam Pan v3?
Yes, you can customize and protect your Wyze Cam Pan v3 with vinyl skins by dBrand, available in styles like Green Camo and Triple Black. These skins offer scratch protection and a stylish look.How can I discreetly use a Wyze Cam indoors?
For discreet indoor security, the Wyze Cam Vase allows you to house your Wyze Cam v3 or v4 inside a decorative vase, blending seamlessly with your home decor while providing effective surveillance.What are the technical specifications of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 features 1080p Full HD video resolution, H.264 video encoding, a 120° field of view, up to 110° per second rotation speed, 2.4 GHz Wi-Fi connectivity, support for up to 256 GB microSD card, and an operating temperature range of -20°C to 50°C (-4°F to 122°F).Why should I choose the Wyze Cam Pan v3 for my home security needs?
The Wyze Cam Pan v3 is a compact, affordable, and feature-rich security camera that offers instant phone alerts, automatic motion tracking, color night vision, and weather resistance, making it an ideal choice for both indoor and outdoor home security.
