Wyze Cam v4: Indoor/Outdoor Security Camera with Person Detection
Wyze Cam v4 Indoor Outdoor Camera with Person Detection
Looking for a versatile, high-quality security camera that works seamlessly both indoors and outdoors? The Wyze Cam v4 series offers cutting-edge features like person detection, enhanced color night vision, and 2.5K QHD resolution to keep your home safe and monitored around the clock. Whether you want a standalone camera or a complete security bundle, Wyze has you covered with multiple options tailored to your needs.
Wyze Cam v4: The Ultimate Indoor & Outdoor Security Camera
Crystal-Clear 2.5K QHD Video Quality
Wyze Cam v4 delivers stunning 2.5K QHD (2560x1440) resolution, providing sharp and detailed video footage. With an 8x digital zoom and wide dynamic range (WDR), you can clearly see every corner of your home or yard, even in challenging lighting conditions.
Advanced Person Detection & Motion Alerts
Equipped with intelligent person detection, the camera distinguishes people from other moving objects, reducing false alarms and ensuring you only get notified when it matters. Motion detection zones allow you to customize which areas to monitor closely.
Enhanced Color Night Vision & Spotlight
Unlike traditional infrared night vision, Wyze Cam v4 features enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens). This means you get vibrant, full-color video even in low-light or nighttime environments.
Weather-Resistant & Durable Design
Rated IP65 for weather resistance, the Wyze Cam v4 is built to withstand outdoor elements such as rain, snow, and dust. Its polycarbonate body and glass/plastic lens materials ensure durability without compromising on style.
Flexible Mounting & Easy Setup
Mount your Wyze Cam v4 on a stand, wall, ceiling, or use the magnetic wall mount with adhesive for quick installation. The camera weighs just 0.49 lb (222 g) and comes with a 6-foot flat micro USB to USB-A cable for convenient power options.
Smart Home Integration & Connectivity
Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for reliable connectivity. Compatible with Alexa, Google Assistant, and IFTTT, allowing you to control your camera hands-free and integrate it into your smart home ecosystem.
Local & Cloud Storage Options
Record continuously with 24/7 local storage on a microSD card (up to 512 GB supported) or opt for cloud storage with a subscription plan for added convenience and backup.
Outdoor Security Camera Lifestyle Wyze Cam v4 providing reliable outdoor security with enhanced night vision
Wyze Cam v4 Outdoor Bundle: Complete Outdoor Security Solution
What’s Included?
  • Wyze Cam v4 camera
  • Wyze Outdoor Power Adapter (wired for continuous power)
  • Wyze MicroSD Card 128GB for local 24/7 recording
Key Features
  • Enhanced Color Night Vision for vivid nighttime footage
  • Motion-activated spotlight to deter intruders and illuminate dark areas
  • Motion and sound detection with customizable detection zones
  • Smoke and CO alerts integration for comprehensive home safety
  • Wi-Fi 6 support for faster, more stable connections
  • Compatible with Alexa and Google Assistant for voice control
This bundle is perfect for those who want a ready-to-go outdoor security system with everything needed for installation and continuous monitoring.
Wyze Cam v4 Home Security Bundle: Indoor & Outdoor Protection
All-in-One Security Package
The Home Security Bundle includes multiple Wyze Cam v4 cameras with person detection and motion-activated spotlights, designed for both indoor and outdoor use. This bundle is ideal for comprehensive home coverage.
Enhanced Audio & Video
  • Improved 2-way audio with noise and echo cancellation
  • 2.5K QHD video with wide field of view (DFOV 115.8°, HFOV 98.5°, VFOV 53.1°)
  • Built-in siren for immediate alerts and deterrence
Storage & Performance
  • Includes a 128GB microSD card (Class 10, UHS-3) for extensive local storage
  • Supports up to 192 hours of HD video or 672 hours of SD video
  • Weather-resistant IP65 rating ensures durability outdoors
Wyze Cam v4 + FREE 32GB MicroSD Card: Best Value Offer
Features at a Glance
  • 2.5K QHD resolution with enhanced color night vision
  • Person detection and motion-activated spotlight
  • Supports Wi-Fi 6 and wired power (outdoor power adapter sold separately)
  • Motion and sound detection with customizable zones
  • Smoke and CO alerts for added safety
  • Includes a free 32GB microSD card for local storage
This option is perfect for budget-conscious buyers who want the core features of Wyze Cam v4 with added storage included.
Why Choose Wyze Cam v4 for Indoor and Outdoor Security?
Wyze Cam v4 stands out with its combination of high-resolution video, intelligent person detection, and enhanced color night vision, making it a top choice for both indoor and outdoor surveillance. Its weather-resistant design and flexible mounting options ensure it fits perfectly in any environment, while smart home compatibility and local/cloud storage options provide convenience and peace of mind.
Wyze Cam v4 Indoor Lifestyle Wyze Cam v4 monitoring an indoor playroom with crystal-clear video
Technical Specifications Summary
FeatureWyze Cam v4 Series
Video Resolution2.5K QHD (2560x1440)
Field of View (DFOV/HFOV/VFOV)115.8° / 98.5° / 53.1°
SensorCMOS Starlight Sensor
Night Vision4 IR LEDs + 2 white spotlight LEDs (72 lumens)
Color Night VisionYes
Person DetectionYes
Motion Detection ZonesYes
Audio2-way talk, 99dB waterproof speaker, built-in siren
ConnectivityWi-Fi 6, 2.4 GHz Wi-Fi, Bluetooth 5.2
Smart Home IntegrationAlexa, Google Assistant, IFTTT
StoragemicroSD card up to 512GB, cloud subscription option
Weather ResistanceIP65
Operating Temperature-4°F to 122°F (-20°C to 50°C)
Dimensions2in x 2in x 2 3/8in
Weight0.49 lb (222 g)
Conclusion
The Wyze Cam v4 lineup offers a powerful, affordable, and versatile security solution for anyone seeking reliable indoor and outdoor surveillance with advanced person detection. Whether you choose the standalone camera, the outdoor bundle, or the comprehensive home security bundle, you get crystal-clear video, smart alerts, and robust weather resistance to protect your home day and night. Secure your home with Wyze Cam v4 — the smart choice for modern home security.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$100.00$69.99$169.99$35.98
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYesYesYesYes
Night Vision Type4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)Same as Wyze Cam v4Same as Wyze Cam v4Same as Wyze Cam v4
Weather ResistanceIP65IP65IP65IP65
Motion-Activated SpotlightYesYesYesYes
AudioEnhanced Two-Way Talk, 99dB speaker, noise & echo cancellationSame as Wyze Cam v4Improved 2-way audioSame as Wyze Cam v4
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local Storage SupportmicroSD card up to 512 GB128GB microSD Card included128GB microSD Card included32GB MicroSD Card included
Continuous RecordingYesYesYesYes
Smart Detection (Subscription)Yes (with subscription)Yes (with subscription)Yes (with subscription)Yes (with subscription)
Motion & Sound DetectionYesYesYesYes
Motion Detection ZonesYesYesYesYes
Smoke & CO AlertsYesYesYesYes
AI Auto-Zoom & Smart FocusYesYesYesYes
Mounting OptionsStand, Wall, Ceiling, MagneticSame as Wyze Cam v4Same as Wyze Cam v4Same as Wyze Cam v4
PowerWired (Indoor 5V/1A)Includes Wyze Outdoor Power AdapterIncludes Wyze Outdoor Power AdapterWired (requires outdoor power adapter)
Included AccessoriesNoneWyze Outdoor Power Adapter, 128GB microSD Card128GB microSD Card32GB MicroSD Card
Dimensions2in x 2in x 2 3/8inSame as Wyze Cam v4Same as Wyze Cam v4Same as Wyze Cam v4
Weight0.49 lb (222 g)Same as Wyze Cam v4Same as Wyze Cam v4Same as Wyze Cam v4
Warranty1 Year1 Year1 YearNot specified
Compatibility with Smart AssistantsAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
What is the video resolution of the Wyze Cam v4?The Wyze Cam v4 features a crystal-clear 2.5K QHD (2560x1440) video resolution, providing sharp and detailed footage for both indoor and outdoor monitoring.
Does Wyze Cam v4 support person detection?Yes, Wyze Cam v4 is equipped with advanced person detection technology, which distinguishes people from other moving objects to reduce false alarms and ensure relevant notifications.
Can Wyze Cam v4 be used outdoors?Absolutely. Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use in rain, snow, and dust, as well as indoor environments.
What night vision features does Wyze Cam v4 offer?Wyze Cam v4 provides enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens), allowing for vibrant, full-color video even in low-light or nighttime conditions.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage via microSD cards up to 512GB for 24/7 continuous recording, and also offers cloud storage through a subscription plan for added convenience and backup.
Is Wyze Cam v4 compatible with smart home systems?Yes, Wyze Cam v4 integrates seamlessly with Alexa, Google Assistant, and IFTTT, enabling hands-free control and easy integration into your smart home ecosystem.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera, a Wyze Outdoor Power Adapter for continuous power, and a 128GB Wyze MicroSD Card for local 24/7 recording.
What features are included in the Wyze Cam v4 Home Security Bundle?The Home Security Bundle includes multiple Wyze Cam v4 cameras with person detection, motion-activated spotlights, improved 2-way audio, built-in siren, and a 128GB microSD card for extensive local storage. It is designed for both indoor and outdoor use.
Does Wyze Cam v4 support Wi-Fi 6?Yes, Wyze Cam v4 supports Wi-Fi 6 as well as 2.4 GHz Wi-Fi, ensuring faster and more stable wireless connections.
How easy is it to install Wyze Cam v4?Wyze Cam v4 offers flexible mounting options, including stand, wall, ceiling, or magnetic wall mount with adhesive. It comes with a 6-foot flat micro USB to USB-A cable for convenient power setup.
What is the operating temperature range for Wyze Cam v4?Wyze Cam v4 operates reliably in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it suitable for various climates.
Does Wyze Cam v4 have two-way audio?Yes, Wyze Cam v4 features improved two-way audio with noise and echo cancellation, allowing you to communicate clearly through the camera.
What is the field of view for Wyze Cam v4?Wyze Cam v4 offers a wide field of view: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical, ensuring comprehensive coverage of your monitored area.
Are there any special offers with Wyze Cam v4?Yes, there is a Wyze Cam v4 offer that includes a free 32GB microSD card, providing added value and local storage for your recordings.
Does Wyze Cam v4 support smoke and CO alerts?Yes, Wyze Cam v4 can integrate with smoke and CO alerts, enhancing your home’s safety by providing comprehensive monitoring.
What are the key features of the Wyze Cam v4?Can you tell me more about the enhanced color night vision of the Wyze Cam v4?Do you have any ongoing sales or promotions for the Wyze Cam v4?
