Wyze Cam Pan v3: The Ultimate Indoor Camera with Phone Notifications
When searching for an indoor camera that provides instant phone notifications whenever it detects movement, the
Wyze Cam Pan v3 stands out as a top choice. This smart camera offers a perfect blend of advanced features, reliable performance, and versatile use for both indoor and outdoor environments.
Key Features of Wyze Cam Pan v3
- 360° Pan and 180° Tilt: Complete coverage with smooth, fast rotation up to 110° per second ensures no blind spots.
- 1080p Full HD Video: Crisp and clear video quality with H.264 encoding, delivering 20 fps during the day and 15 fps at night.
- Motion Detection with Push Notifications: Receive real-time alerts on your phone whenever movement is detected, keeping you instantly informed.
- Night Vision: Equipped with 4 IR LEDs (850 nm) for clear black-and-white night vision, plus color night vision in the Cam Plus bundle.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation allow seamless communication through the camera.
- Weather Resistant (IP65 Rated): Suitable for indoor and outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately).
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Expandable Storage: Supports up to 256 GB microSD cards in ExFAT format for local video storage.
- Connectivity: Works on 2.4 GHz Wi-Fi networks (802.11 b/g/n).
Design and Build
The Wyze Cam Pan v3 features a sleek matte polycarbonate body available in black or white, with a compact size of 124mm (H) x 60mm (W) x 63mm (D) and weighing just 11.29 oz (320 g). Its durable design is perfect for various environments, from living rooms to porches.
Experience reliable security indoors and outdoors with Wyze Cam Pan v3’s weather-resistant design.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Features for Smart Security
For users seeking an all-in-one package, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with added benefits:
- Color Night Vision: See more details in low-light conditions with enhanced color night vision.
- Included Accessories: Comes with a power adapter, mounting kit, 6’ micro USB cable, and quick start guide for easy setup.
- Extended Cloud Storage: Enjoy 30 days of Cam Plus cloud video storage, allowing you to review motion events anytime.
- Push Notifications & Motion Tracking: Stay connected with instant alerts and automatic motion tracking to follow detected movement.
This bundle is ideal for those who want a hassle-free, feature-rich security solution with extended cloud capabilities.
Communicate effortlessly with family or pets using Wyze Cam Pan v3’s two-way audio.
Pan v3 Security Bundle: Double the Protection
For enhanced coverage, the
Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras along with essential accessories:
- Two cameras in your choice of black or white.
- Two 6’ micro USB cables and power adapters.
- Two mounting kits and quick start guide.
- Two 32GB microSD cards for local storage.
This bundle is perfect for securing multiple rooms or areas, providing comprehensive monitoring with the same advanced features of the single Wyze Cam Pan v3.
Why Choose Wyze Cam Pan v3 for Indoor Security?
The Wyze Cam Pan v3 is designed to keep you connected and secure with its intelligent motion detection and instant phone notifications. Whether monitoring your home, pets, or office, this camera offers peace of mind with its 360° coverage and smart features.
- Instant Alerts: Never miss a moment with push notifications sent directly to your smartphone.
- Smart Controls: Use voice commands or automate routines with Alexa, Google Assistant, and IFTTT.
- Flexible Installation: Mount it anywhere indoors or outdoors (with the right power adapter) for versatile security.
- Affordable and Reliable: High-end features at a budget-friendly price point.
Summary of Wyze Cam Pan v3 Specs
Feature | Specification |
Video Resolution | 1920 x 1080 (1080p) |
Frame Rate | 20 fps (day), 15 fps (night) |
Pan & Tilt Range | 360° horizontal, 180° vertical |
Digital Zoom | 8x |
Night Vision | 4 IR LEDs (850 nm), Color Night Vision (bundle) |
Audio | 2-way audio with noise & echo cancellation |
Connectivity | 802.11 b/g/n 2.4 GHz Wi-Fi |
Storage | Up to 256 GB microSD (ExFAT) |
Operating Temperature | -20°C to 50°C (-4°F to 122°F) |
IP Rating | IP65 (weather resistant) |
Dimensions (H x W x D) | 124mm x 60mm x 63mm |
Weight | 11.29 oz (320 g) |
Enhance Your Wyze Cam Pan v3 Experience
Consider adding accessories like the
Wyze Cam Pan v3 Skins by dBrand for stylish protection or replacement parts such as the
Wyze Cam Pan v3 USB Cable to keep your camera powered and ready.
With its comprehensive features, reliable notifications, and smart integrations, the Wyze Cam Pan v3 is the perfect indoor camera solution for anyone looking to stay connected and secure at all times.
What are the key features of the Wyze Cam Pan v3 indoor camera?
The Wyze Cam Pan v3 offers 360° pan and 180° tilt for complete coverage, 1080p Full HD video, motion detection with instant phone notifications, night vision, two-way audio, weather resistance (IP65 rated), smart home integration with Alexa, Google Assistant, and IFTTT, expandable storage up to 256 GB microSD, and 2.4 GHz Wi-Fi connectivity.Does the Wyze Cam Pan v3 send phone notifications when it detects motion?
Yes, the Wyze Cam Pan v3 provides real-time push notifications to your smartphone whenever it detects movement, ensuring you are instantly informed of any activity.Can the Wyze Cam Pan v3 be used outdoors?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant and can be used outdoors when paired with the Wyze Outdoor Power Adapter (sold separately), making it suitable for both indoor and outdoor environments.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera, a power adapter, mounting kit, 6’ micro USB cable, quick start guide, 30 days of Cam Plus cloud video storage, color night vision, and enhanced push notifications with motion tracking.How does the night vision work on the Wyze Cam Pan v3?
The Wyze Cam Pan v3 features 4 IR LEDs (850 nm) for clear black-and-white night vision. With the Cam Plus bundle, you also get color night vision for enhanced detail in low-light conditions.Is the Wyze Cam Pan v3 compatible with smart home devices?
Yes, the Wyze Cam Pan v3 integrates with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB (ExFAT format) and offers cloud storage through the Cam Plus subscription, which provides 30 days of video event history.What is included in the Pan v3 Security Bundle?
The Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras (in black or white), two 6’ micro USB cables, two power adapters, two mounting kits, two quick start guides, and two 32GB microSD cards for local storage.What are the technical specifications of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 features 1080p video resolution, 20 fps (day) and 15 fps (night) frame rates, 360° horizontal and 180° vertical pan and tilt, 8x digital zoom, two-way audio with noise and echo cancellation, 802.11 b/g/n 2.4 GHz Wi-Fi, up to 256 GB microSD storage, operating temperature from -20°C to 50°C (-4°F to 122°F), IP65 weather resistance, and dimensions of 124mm x 60mm x 63mm.Can I communicate through the Wyze Cam Pan v3?
Yes, the Wyze Cam Pan v3 has built-in two-way audio with noise and echo cancellation, allowing you to communicate clearly with family members or pets through the camera.Are there accessories available for the Wyze Cam Pan v3?
Yes, you can enhance your Wyze Cam Pan v3 with accessories such as Wyze Cam Pan v3 Skins by dBrand for added protection and style, as well as replacement parts like the Wyze Cam Pan v3 USB Cable.Is the Wyze Cam Pan v3 easy to install?
Yes, the Wyze Cam Pan v3 comes with a mounting kit and quick start guide for easy setup, and its compact design allows for flexible installation indoors or outdoors (with the appropriate power adapter).
