Wyze Cam Pan v3: Motion & Sound Detection Security Camera
Discover the Wyze Cam Pan v3: Motion and Sound Detection Alerts Combined
When it comes to home security, having a camera that not only detects motion but also sound alerts is essential for comprehensive monitoring. The Wyze Cam Pan v3 series offers exactly that — a smart, versatile security camera designed for both indoor and outdoor use, equipped with advanced motion detection and sound detection alerts to keep you informed in real-time.
Wyze Cam Pan v3: Features and Specifications
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 boasts a 360° horizontal and 180° vertical range, allowing it to cover every corner of your space without blind spots. This wide view is complemented by a 120° field of view (FOV) and an 8x digital zoom, ensuring you can zoom in on important details with clarity.
High-Definition Video Quality
Capture every moment in crisp 1080p Full HD resolution with smooth video encoding via H.264. The camera records at 20 fps during the day and 15 fps at night, delivering clear footage regardless of lighting conditions.
Advanced Motion and Sound Detection Alerts
Stay instantly notified with push notifications triggered by both motion and sound detection. Whether it’s a person moving in your yard or an unusual noise inside your home, the Wyze Cam Pan v3 keeps you connected and aware.
Color Night Vision and IR LEDs
Equipped with 4 IR LEDs (850 nm), the camera provides excellent night vision. Unlike traditional black-and-white night vision, the Wyze Cam Pan v3 offers color night vision, enhancing visibility and detail in low-light environments.
Two-Way Audio with Noise & Echo Cancellation
Communicate directly through the camera using its built-in speaker and microphone. The 2-way audio feature includes noise and echo cancellation, making conversations clear whether you’re talking to family members, pets, or even deterring intruders.
Durable and Weather Resistant
Designed with a polycarbonate body and rated IP65 for weather resistance, the Wyze Cam Pan v3 is suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). It withstands temperatures from -20°C to 50°C (-4°F to 122°F), making it reliable in various climates.
Easy Installation and Compatibility
Mount the camera easily with a 1/4" - 20 screw mount and connect via 2.4 GHz Wi-Fi (note: 5 GHz not supported). Compatible with Android 9.0+ and iOS 15.0+, it integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Wyze Cam Pan v3 Outdoor Lifestyle Wyze Cam Pan v3 in snowy outdoor setting, showcasing weather resistance and versatile placement.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
For users seeking an all-in-one package, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera features with the added benefit of a 30-day Cam Plus subscription. This subscription unlocks advanced cloud storage options, person detection, and extended event video history, providing peace of mind with enhanced monitoring capabilities.
What’s Included in the Bundle?
  • Wyze Cam Pan v3 (Black or White)
  • 6' Micro USB Cable
  • Power Adapter
  • Mounting Kit
  • Quick Start Guide
  • 30-Day Cam Plus Service
This bundle is perfect for those who want to maximize their security setup with continuous cloud recording and smarter alerts.
Pan v3 Security Bundle: Double the Protection
For larger homes or multiple entry points, the Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras along with accessories such as micro USB cables, power adapters, mounting kits, and 32GB microSD cards for local storage. This bundle offers excellent value and comprehensive coverage for both indoor and outdoor environments.
Wyze Cam Pan v3 Two-Way Audio Two-way audio feature in action — communicate clearly with family or pets through the Wyze Cam Pan v3.
Why Choose Wyze Cam Pan v3 for Motion and Sound Detection?
The Wyze Cam Pan v3 stands out as a top choice for users who want reliable, smart security with both motion detection and sound detection alerts. Its combination of 360° coverage, color night vision, and two-way audio makes it a versatile camera for any home or business.
  • Real-time push notifications keep you instantly informed.
  • Color night vision ensures clear images even in darkness.
  • Weather-resistant design allows flexible indoor/outdoor placement.
  • Smart home integration enhances convenience and control.
Summary of Wyze Cam Pan v3 Key Specs
FeatureSpecification
Video Resolution1920 x 1080 (1080p)
Frame Rate20 fps (day), 15 fps (night)
Pan & Tilt Range360° horizontal, 180° vertical
Field of View120° FOV
Night Vision4 IR LEDs, Color Night Vision
AudioBuilt-in speaker & mic, 2-way audio
Connectivity802.11 b/g/n 2.4 GHz Wi-Fi
Weather ResistanceIP65 rated
StorageUp to 256 GB microSD, Cloud options
CompatibilityAndroid 9.0+, iOS 15.0+, Alexa, Google Assistant, IFTTT
Operating Temperature-20°C to 50°C (-4°F to 122°F)
Conclusion
For a security camera that provides both motion detection and sound detection alerts, the Wyze Cam Pan v3 and its bundles offer unbeatable value, advanced features, and reliable performance. Whether you want to monitor your home, pets, or business, this camera delivers comprehensive coverage with smart notifications and easy integration into your connected lifestyle.
FeatureWyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3Pan v3 Security Bundle
Price$39.98$39.98 (1 Pack), $77.96 (2 Pack), $114.94 (3 Pack)$82.99
Includes Cam Plus SubscriptionYes, 30 days free, then $2.99/month auto-renewOptional, 30 days free trial availableNot specified
Camera Color VariantsBlack, WhiteBlack, WhiteBlack, White
Weather ResistanceIP65IP65IP65
Indoor/Outdoor UseYes (Outdoor requires Wyze Outdoor Power Adapter sold separately)Yes (Outdoor requires Wyze Outdoor Power Adapter sold separately)Yes (Outdoor requires Wyze Outdoor Power Adapter sold separately)
Pan & Tilt Coverage360° pan, 180° tilt360° pan, 180° tilt360° pan, 180° tilt
Motion TrackingAutomatic motion trackingAutomatic motion trackingAutomatic motion tracking
Night VisionColor Night Vision with Starlight SensorColor Night Vision with Starlight SensorColor Night Vision with Starlight Sensor
Two-Way AudioYesYesYes
Privacy ModeYesYesYes
Storage SupportCloud storage with Cam Plus; local storage supportedLocal storage supported; cloud storage optionalLocal storage supported; cloud storage optional
Included ItemsWyze Cam Pan v3, 30-Day Cam PlusWyze Cam Pan v3 (1, 2, or 3 pack)2x Wyze Cam Pan v3, 2x 6' micro USB cables, 2x Power Adapters, 2x Mounting Kits, 2x Wyze 32GB MicroSD Cards, Quick Start Guide
Warranty1 Year1 Year1 Year
Additional FeaturesCam Plus subscription with advanced notificationsPan Scan™ waypoints, custom detection zones, smoke & CO alertsSame as Wyze Cam Pan v3 plus bundled accessories and local storage cards
Connectivity802.11 b/g/n 2.4 GHz Wi-Fi802.11 b/g/n 2.4 GHz Wi-Fi802.11 b/g/n 2.4 GHz Wi-Fi
DimensionsNot specified separately124mm (H) x 60mm (W) x 63mm (D)124mm (H) x 60mm (W) x 63mm (D)
WeightNot specified separately11.29 oz (320 g)11.29 oz (320 g)
What is the Wyze Cam Pan v3 and what makes it unique?The Wyze Cam Pan v3 is a smart security camera designed for both indoor and outdoor use. It features advanced motion and sound detection alerts, 360° pan and 180° tilt for full coverage, color night vision, two-way audio, and weather resistance. Its versatility and real-time notifications make it a top choice for comprehensive home or business security.
Does the Wyze Cam Pan v3 support both motion and sound detection alerts?Yes, the Wyze Cam Pan v3 provides real-time push notifications for both motion and sound detection, ensuring you are instantly informed of any unusual activity or noise in your monitored area.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is IP65 weather-resistant and can be used outdoors when paired with the Wyze Outdoor Power Adapter (sold separately). It is designed to withstand temperatures from -20°C to 50°C (-4°F to 122°F).
What video quality does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 records in 1080p Full HD resolution, with a frame rate of 20 fps during the day and 15 fps at night, ensuring clear and detailed footage in all lighting conditions.
Does the Wyze Cam Pan v3 have night vision?Yes, the Wyze Cam Pan v3 is equipped with 4 IR LEDs (850 nm) and offers color night vision, providing enhanced visibility and detail in low-light or nighttime environments.
How does the two-way audio feature work on the Wyze Cam Pan v3?The Wyze Cam Pan v3 includes a built-in speaker and microphone, allowing for two-way audio communication. It also features noise and echo cancellation for clear conversations, making it easy to talk to family, pets, or deter intruders remotely.
What are the storage options for the Wyze Cam Pan v3?The Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB and offers cloud storage options, including advanced features with the Cam Plus subscription.
Is the Wyze Cam Pan v3 compatible with smart home systems?Yes, the Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home setup.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the Wyze Cam Pan v3 (in black or white), a 6' micro USB cable, power adapter, mounting kit, quick start guide, and a 30-day Cam Plus subscription for enhanced cloud storage and smart alerts.
What is the Pan v3 Security Bundle?The Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, micro USB cables, power adapters, mounting kits, and 32GB microSD cards for local storage, providing comprehensive security coverage for larger homes or multiple entry points.
What devices and operating systems are compatible with the Wyze Cam Pan v3?The Wyze Cam Pan v3 is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.
How is the Wyze Cam Pan v3 installed?The Wyze Cam Pan v3 can be easily mounted using a 1/4" - 20 screw mount and connects to your home network via 2.4 GHz Wi-Fi (5 GHz is not supported).
What are the key features of the Wyze Cam Pan v3?How does the color night vision work on the Wyze Cam Pan v3?Do you have any deals, ongoing sales, discounts, or promotions?
