Buy Affordable Wyze Lock Keypad for Secure Keyless Entry
Looking for a reliable, affordable keypad solution to secure your home with keyless entry? Wyze offers smart lock products designed to enhance your home security with convenience and advanced technology. Whether you want a standalone keypad accessory or a complete smart lock with a built-in keypad, Wyze has options tailored to your needs.
Wyze Lock Bolt: Premium Keypad with Fingerprint Access
Experience the ultimate in keyless entry with the Wyze Lock Bolt, a Bluetooth smart lock that replaces your deadbolt and features a luxurious backlit keypad combined with an ultra-fast fingerprint reader.
Key Features:
  • Fast Fingerprint Unlock: Enter your home in less than a second with a simple fingerprint tap—no keys needed.
  • Backlit Keypad: Solid metal exterior with illuminated buttons for easy nighttime use.
  • Anti-Peep Technology: Add extra digits before or after your code to keep your passcode secure from prying eyes.
  • Auto-Lock Function: Set a timer in the Wyze app to automatically lock your door if you forget.
  • Weatherproof & Pick-Proof: IPX5 rating ensures durability against the elements; no keys means no lock picking.
  • Long Battery Life: Up to 12 months on 4 AA batteries, with USB-C emergency charging if batteries die.
  • App Control: Manage up to 20 access codes and 50 fingerprints, view lock history, and generate emergency one-time codes remotely.
Design & Installation:
  • Crafted to blend beautifully with your home’s exterior.
  • Replaces your existing deadbolt in about 20 minutes.
  • Available in Matte Black and Satin Nickel finishes at an affordable price of $79.98.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt lifestyle Secure your front door with Wyze Lock Bolt’s smart keypad and fingerprint reader.
Wyze Lock Keypad: Affordable Accessory for Wyze Lock
If you already own a Wyze Lock and want to add keypad convenience, the Wyze Lock Keypad is the perfect affordable accessory.
Highlights:
  • Unlock Without Phone or Keys: Enter your home using a secure keypad code.
  • Designed for Wyze Lock: This keypad works exclusively with Wyze Lock (not compatible with Wyze Lock Bolt).
  • Easy Installation: Comes with mounting plate, screws, and batteries for quick setup.
  • Price: At just $23.99, it’s a budget-friendly way to add keyless entry.
Note: The Wyze Lock Keypad requires the Wyze Lock and will not function as a standalone device.
Installation Made Simple:
  • Mount the keypad anywhere near your door using the included adhesive and screws.
  • Insert batteries and connect it to your Wyze Lock following the Wyze Lock Keypad Setup Guide.
  • Arm or disarm your lock quickly without needing your phone.
Wyze Lock Keypad lifestyle Add keypad convenience to your Wyze Lock for secure, keyless entry.
Why Choose Wyze for Your Keyless Entry Needs?
Wyze smart locks and keypads combine affordability with advanced security features, making them ideal for anyone seeking secure, keyless home access without breaking the bank.
  • Affordable Pricing: Wyze Lock Bolt at $79.98 and Wyze Lock Keypad at $23.99 offer budget-friendly options.
  • Secure & Convenient: Fingerprint sensors, backlit keypads, and anti-peep technology keep your home safe.
  • Easy Installation: Most products install in under 20 minutes with simple tools.
  • Smart App Integration: Manage access codes, monitor lock activity, and control your lock remotely (Wyze Lock Bolt).
  • No Cloud Dependency: Local Bluetooth connection ensures your data stays private and secure.
Supplementary Tips: Installing Your Wyze Lock Keypad
Installing the Wyze Lock Keypad is straightforward: 1. Remove the adhesive backing on the mounting plate. 2. Press the plate against the wall near your door and secure it with included screws. 3. Insert the 2 AA batteries into the keypad and attach it to the mounting plate. 4. Follow the Wyze Lock Keypad Setup Guide to connect it to your Wyze Lock.
For detailed instructions and troubleshooting, Wyze provides comprehensive installation and setup guides to ensure a smooth experience.
Summary
For secure, keyless entry with an affordable price tag, Wyze offers two excellent keypad options:
  • Wyze Lock Bolt: A complete smart lock with fingerprint sensor and backlit keypad for $79.98.
  • Wyze Lock Keypad: An accessory keypad for Wyze Lock owners at $23.99.
Upgrade your home security today with Wyze’s smart keypad solutions and enjoy the convenience of keyless entry without compromising safety.
FeatureWyze Lock BoltWyze Lock Keypad
Product TypeConnected HomeAccessories
Price$79.98 (New), $59.98 (Refurbished)$23.99
Keyless EntryYes (Fingerprint sensor + Backlit keypad)Yes (Keypad only)
Fingerprint ReaderUltra-fast fingerprint sensorNo
KeypadBacklit keypad with anti-peep technologyKeypad only
Auto-lock FeatureYesNo
Unlock MethodsFingerprint, keypad, appKeypad only
App IntegrationYes (Bluetooth connection, lock/unlock history, code management)No direct app control (keypad accessory)
Battery LifeUp to 12 months (4x AA batteries)Not specified (2x AA batteries)
Weather ResistanceIPX5 (weatherproof)Not specified
InstallationReplaces existing deadbolt, ~20 minutesAccessory for Wyze Lock
Security FeaturesHardware encryption, two-factor authentication, built-in alarmN/A
CompatibilityCompatible with most exterior doorsFor Wyze Lock only
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a Bluetooth smart lock that replaces your existing deadbolt, offering secure keyless entry with a backlit keypad and ultra-fast fingerprint reader. It features anti-peep technology, auto-lock functionality, weatherproof and pick-proof design, and allows you to manage access codes and fingerprints through the Wyze app, enhancing both security and convenience for your home.
How does the Wyze Lock Keypad work and what is it compatible with?The Wyze Lock Keypad is an affordable accessory designed exclusively for use with the Wyze Lock (not compatible with Wyze Lock Bolt). It allows you to unlock your door using a secure keypad code, providing keyless entry without needing your phone or keys. The keypad is easy to install and connects directly to your Wyze Lock.
What are the main features of the Wyze Lock Bolt?Key features of the Wyze Lock Bolt include fast fingerprint unlock, a backlit keypad for nighttime use, anti-peep technology for added security, auto-lock function, weatherproof and pick-proof construction, long battery life (up to 12 months), USB-C emergency charging, and app control for managing access codes and viewing lock history.
How much do the Wyze Lock Bolt and Wyze Lock Keypad cost?The Wyze Lock Bolt is priced at $79.98 and offers a complete smart lock solution with a fingerprint sensor and keypad. The Wyze Lock Keypad is available for $23.99 and serves as an accessory for existing Wyze Lock owners seeking affordable keyless entry.
Is the Wyze Lock Keypad a standalone device?No, the Wyze Lock Keypad is not a standalone device. It requires the Wyze Lock to function and will not work independently or with the Wyze Lock Bolt.
How easy is it to install Wyze smart locks and keypads?Wyze smart locks and keypads are designed for easy installation, typically taking less than 20 minutes with simple tools. The Wyze Lock Bolt replaces your existing deadbolt, while the Wyze Lock Keypad can be mounted near your door using included adhesive and screws. Comprehensive setup guides are provided for a smooth installation experience.
What security features do Wyze smart locks offer?Wyze smart locks offer advanced security features such as fingerprint sensors, backlit keypads, anti-peep technology, auto-lock functions, weatherproof and pick-proof designs, and local Bluetooth connectivity to keep your data private and secure.
Can I manage access codes and monitor lock activity with Wyze smart locks?Yes, with the Wyze Lock Bolt, you can manage up to 20 access codes and 50 fingerprints, view lock history, and generate emergency one-time codes remotely through the Wyze app, providing full control and monitoring of your home’s access.
What finishes are available for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, allowing you to choose a style that best matches your home’s exterior.
Does the Wyze Lock Bolt require a cloud connection to operate?No, the Wyze Lock Bolt operates via a local Bluetooth connection, ensuring your data remains private and secure without relying on cloud services.
What are the installation steps for the Wyze Lock Keypad?Can the Wyze Lock Keypad be used with any other locks besides the Wyze Lock?Is there a warranty available for the Wyze Lock products?
