Affordable Indoor Keypad for Wyze Sense Home Monitoring Kit
When it comes to securing your home with an affordable and reliable indoor keypad, the Wyze Sense Keypad stands out as the perfect companion for your Wyze Sense Home Monitoring Kit. Designed to seamlessly integrate with Wyze’s home security ecosystem, this keypad offers quick and easy control over your home’s security system, making it an essential addition for anyone looking to enhance their indoor monitoring setup without breaking the bank.
Wyze Sense Keypad: Your Affordable Indoor Security Control
Key Features and Benefits
  • Price: $27.98 — an affordable solution for home security control.
  • Functionality: Arm and disarm your Wyze Home Monitoring system remotely with ease.
  • Emergency Button: Quickly send alerts to first responders directly from the keypad.
  • Placement Flexibility: Place it anywhere indoors for convenient access.
  • Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring subscription.
  • Non-Standalone: Note that it does not function independently or with Wyze Sense v1.
This keypad is designed to simplify your home security experience by providing a tactile, easy-to-use interface for managing your system without needing to open an app every time. Wyze Sense Keypad Lifestyle
"Disarm your home security remotely with the Wyze Sense Keypad — affordable, accessible, and essential for your Wyze Sense system."
Complete Your Setup with Wyze Home Monitoring Core Starter Kit
What’s Included?
  • Entry Sensors: Detect when doors or windows open.
  • Motion Sensors: Monitor movement inside your home without video.
  • Professional Monitoring: Optional 24/7 monitoring with emergency dispatch.
  • Easy Installation: No tools required for setup.
  • Price: $111.98 (includes 3 months of professional monitoring).
The Core Starter Kit is the foundation of your Wyze Sense Home Monitoring system. It works perfectly with the Wyze Sense Keypad to provide comprehensive security coverage. The sensors notify you instantly on your phone and through the Sense Hub, ensuring you’re always aware of what’s happening at home. Wyze Home Monitoring Sensors
Enhance Detection with Wyze Sense Sensors
Wyze Sense Motion Sensor
  • Detection Range: Up to 25 feet.
  • Field of View: 120° wide-angle detection.
  • Adjustable Sensitivity: Customize detection to avoid false alarms.
  • Battery Life: Up to 18 months on a single battery.
  • Installation: Adhesive back or screws for secure mounting.
  • Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring.
Wyze Sense Entry Sensor
  • Function: Detects when doors or windows open or close.
  • Pack Size: Available in 3-packs for multiple entry points.
  • Compatibility: Requires Wyze Sense Hub and works with Wyze Sense v2 or Wyze Home Monitoring.
  • Installation: Easy to mount with adhesive or screws.
These sensors complement the keypad by providing real-time alerts and monitoring, making your home security system smarter and more responsive. Wyze Sense Motion Sensor Lifestyle
Why Choose Wyze Sense Keypad and Home Monitoring Kit?
  • Affordable Pricing: Get premium home security features without a premium price tag.
  • Seamless Integration: Designed to work together for a cohesive security experience.
  • User-Friendly: Easy to install and operate, perfect for all household members.
  • Remote Control: Manage your home security from anywhere using the keypad or app.
  • Expandable System: Add more sensors and devices as needed to cover your entire home.
Protect your home with confidence and convenience using the Wyze Sense Keypad paired with the Wyze Home Monitoring Core Starter Kit and sensors.
Summary of Products for Your Wyze Sense Home Monitoring Kit
Product NamePriceKey Features
Wyze Sense Keypad$27.98Indoor keypad, emergency button, remote disarm
Wyze Home Monitoring Core Starter Kit$111.98Entry & motion sensors, 3 months professional monitoring
Wyze Sense Motion Sensor$20.9825 ft range, adjustable sensitivity, long battery life
Wyze Sense Entry Sensor (3-pack)$41.98Door/window open detection, easy installation
Secure your home affordably and efficiently with the Wyze Sense Keypad and the complete Wyze Sense Home Monitoring Kit. Whether you want quick keypad access or comprehensive sensor coverage, Wyze offers the perfect balance of price, performance, and peace of mind.
FeatureWyze Sense KeypadWyze Home Monitoring Core Starter KitWyze Sense Motion SensorWyze Sense Entry Sensor
TypeHome MonitoringHome MonitoringHome MonitoringHome Monitoring
Price$27.98$111.98 (Core Starter Kit + 3 months monitoring)$20.98 (1 Pack)$41.98 (3 Pack)
RequiresWyze Sense Hub, Wyze Home MonitoringWyze Home MonitoringWyze Sense Hub, Wyze Home MonitoringWyze Sense Hub, Wyze Home Monitoring
FunctionalityArm/disarm system remotely, emergency buttonEntry sensor, motion sensor, 24/7 monitoring optionDetects motion (25 ft range, 120° FOV)Detects open/close events
CompatibilityNot standalone, not compatible with Wyze Sense v1Works as a complete starter kitWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home Monitoring
InstallationPlace anywhere in homeIncludes sensors (entry, motion) for installationAdhesive back or screwsRequires Wyze Sense Hub, adhesive or screws
Battery LifeNot specifiedNot specifiedUp to 18 monthsNot specified
Emergency FeatureOn-device emergency button24/7 professional monitoring (with subscription)NoNo
Quantity OptionsSingle unitKit includes multiple sensors1 Pack3 Pack
What is the Wyze Sense Keypad and how does it work with the Wyze Sense Home Monitoring Kit?The Wyze Sense Keypad is an affordable indoor keypad designed to seamlessly integrate with the Wyze Sense Home Monitoring Kit. It allows you to easily arm and disarm your home security system without needing to use the app, providing quick and convenient control over your home’s security.
How much does the Wyze Sense Keypad cost?The Wyze Sense Keypad is priced at $27.98, making it an affordable solution for enhancing your home security system.
Does the Wyze Sense Keypad work as a standalone device?No, the Wyze Sense Keypad does not function as a standalone device. It requires the Wyze Sense Hub and a Wyze Home Monitoring subscription to operate. It is also not compatible with Wyze Sense v1.
What are the key features of the Wyze Sense Keypad?Key features of the Wyze Sense Keypad include easy arming and disarming of your security system, an emergency button for quick alerts to first responders, flexible indoor placement, and seamless integration with the Wyze Sense Home Monitoring Kit.
What is included in the Wyze Home Monitoring Core Starter Kit?The Wyze Home Monitoring Core Starter Kit includes entry sensors to detect when doors or windows open, motion sensors to monitor movement inside your home, and three months of professional monitoring. The kit is easy to install and is priced at $111.98.
Are Wyze Sense sensors easy to install?Yes, Wyze Sense sensors are designed for easy installation. They can be mounted using adhesive backing or screws, and no tools are required for setup.
What is the detection range and battery life of the Wyze Sense Motion Sensor?The Wyze Sense Motion Sensor has a detection range of up to 25 feet and a 120° wide-angle field of view. It features adjustable sensitivity to reduce false alarms and offers up to 18 months of battery life on a single battery.
How do Wyze Sense Entry Sensors work?Wyze Sense Entry Sensors detect when doors or windows are opened or closed. They are available in 3-packs for monitoring multiple entry points and are easy to install with adhesive or screws. They require the Wyze Sense Hub and are compatible with Wyze Sense v2 and Wyze Home Monitoring.
Can I expand my Wyze Sense Home Monitoring system with additional sensors?Yes, the Wyze Sense Home Monitoring system is expandable. You can add more motion sensors, entry sensors, and other compatible devices to cover your entire home as needed.
What are the benefits of choosing Wyze Sense Keypad and Home Monitoring Kit?The Wyze Sense Keypad and Home Monitoring Kit offer affordable pricing, seamless integration, user-friendly installation and operation, remote control capabilities, and the flexibility to expand your system for comprehensive home security.
What are the key features of the Wyze Sense Keypad?Can the Wyze Sense Keypad be used with Wyze Sense v1?Do you have any deals, ongoing sales, discounts, or promotions?
