Wyze Sense Keypad Installation Guide with Permanent Adhesive
Installation Guide for Wyze Sense Keypad with Permanent Adhesive
If you're looking to install the Wyze Sense Keypad using permanent adhesive, this guide will walk you through the process step-by-step. The Wyze Sense Keypad is an essential part of your Wyze Home Monitoring system, allowing you to arm and disarm your security system quickly and conveniently from anywhere in your home.
About the Wyze Sense Keypad
The Wyze Sense Keypad is designed to work seamlessly with the Wyze Sense Hub and requires Wyze Home Monitoring to function. It is not a standalone device and will not work with Wyze Sense v1 sensors.
Key Features:
  • Arm and disarm your home security system remotely.
  • On-device emergency button for quick first responder alerts.
  • Compact and easy to place near your main entrance.
  • Requires Wyze Sense Hub for operation.
Tip: Place the keypad next to your primary entrance, high enough to be out of reach of children and pets for optimal security.
Wyze Sense Keypad Lifestyle Secure your home with the Wyze Sense Keypad placed conveniently by your door.
Step-by-Step Installation Using Permanent Adhesive
What You’ll Need:
  • Wyze Sense Keypad
  • Permanent adhesive strips (3M or similar strong double-sided tape)
  • Clean cloth or alcohol wipes
  • A flat, clean surface near your main entrance
Installation Steps:
1. Choose the Location: Select a spot near your main entrance door where you can easily reach the keypad. Ensure the surface is flat and clean. 2. Clean the Surface: Use a clean cloth or alcohol wipe to remove any dust, dirt, or grease from the wall or surface where you plan to mount the keypad. This ensures strong adhesion. 3. Prepare the Adhesive: Take your permanent adhesive strips and cut them to fit the back of the Wyze Sense Keypad if necessary. Make sure the adhesive covers enough surface area to hold the keypad firmly. 4. Attach the Adhesive to the Keypad: Stick the adhesive strips firmly to the back of the keypad. Press down to ensure good contact. 5. Mount the Keypad: Peel off the protective backing from the adhesive strips and press the keypad firmly against the wall or surface. Hold it in place for about 30 seconds to ensure a strong bond. 6. Test the Placement: After mounting, test the keypad by arming and disarming your system to confirm it is working correctly.
Note: Avoid placing the keypad near heat sources or in direct sunlight to prevent adhesive failure.
Additional Tips for Optimal Use
  • Height Placement: Mount the keypad at a comfortable height, typically around chest level, to make PIN entry easy.
  • Avoid Moisture: Do not install the keypad in areas prone to moisture or extreme temperature changes.
  • Battery Check: Ensure the keypad batteries are fresh for uninterrupted operation.
  • Integration: The keypad works best when paired with the Wyze Sense Hub and other Wyze sensors for a comprehensive home monitoring system.
Why Choose Wyze Sense Keypad?
The Wyze Sense Keypad offers a simple, reliable way to control your home security system without needing to open the Wyze app every time. Its compact design and easy installation make it a perfect addition to your smart home setup.
Related Wyze Security Products
While the Wyze Sense Keypad is a key component of your home security, consider complementing it with other Wyze products for enhanced protection:
Wyze Cam v4 Outdoor Bundle
  • Crystal-clear 2.5K QHD resolution with enhanced color night vision.
  • Motion-activated spotlight and Wi-Fi 6 support.
  • 24/7 local recording and compatibility with Alexa and Google Assistant.
Essential Security Bundle
  • Includes Wyze Video Doorbell v2, Wyze Lock Bolt with fingerprint sensor and backlit keypad, Wyze Cam Pan v3, and two Wyze Cam OG cameras.
  • Comprehensive home protection with smart locks, video monitoring, and motion detection.
Wyze Outdoor Security Camera Enhance your home security with Wyze Cam v4 Outdoor Bundle.
Summary
Installing your Wyze Sense Keypad with permanent adhesive is a quick and effective way to secure your home entrance without drilling holes. Follow the steps above to ensure a strong, lasting installation. Pair it with other Wyze security devices for a smart, connected home monitoring system.
"Disarm your home security remotely with ease and confidence using the Wyze Sense Keypad."
FeatureWyze Sense KeypadWyze Cam v4 Outdoor BundleEssential Security Bundle
Price$27.98$69.99$199.99
Product TypeHome Monitoring KeypadOutdoor Security Camera BundleComprehensive Home Security Bundle
Main FunctionArm/disarm home security remotely; emergency button2.5K QHD outdoor camera with color night vision, motion-activated spotlightIncludes video doorbell, smart lock, pan camera, and 2 plug-in cameras with spotlights and color night vision
RequiresWyze Sense Hub and Wyze Home MonitoringWyze Cam v4, Outdoor Power Adapter, 128GB microSD cardWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OG
Video ResolutionN/A2.5K QHD (2560x1440)Video Doorbell: 1080p HD; Cameras: 1080p HD
Night VisionN/AEnhanced Color Night VisionColor Night Vision on cameras
ConnectivityRequires Wyze Sense HubWi-Fi 6, 2.4 GHz Wi-FiBluetooth (Lock), Wi-Fi (Cameras)
Emergency ButtonYesNoNo
Camera FeaturesN/AMotion and sound detection, smoke & CO alerts, 24/7 local recordingPan camera: 360° pan, 180° tilt, motion tracking; OG cams: motion-activated spotlight
Smart Home IntegrationRequires Wyze Home MonitoringAlexa, Google AssistantNot specified
StorageN/ALocal microSD (128GB), Cloud with subscriptionLocal microSD and cloud recording
Weather ResistanceN/AIP65IP65 for cameras
Included Devices1 Keypad1 Wyze Cam v4, 1 Outdoor Power Adapter, 1 128GB microSD card1 Wyze Video Doorbell v2, 1 Wyze Lock Bolt, 1 Wyze Cam Pan v3, 2 Wyze Cam OG
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the Wyze Sense Keypad and how does it work?The Wyze Sense Keypad is a device designed to arm and disarm your Wyze Home Monitoring security system quickly and conveniently. It works seamlessly with the Wyze Sense Hub and requires an active Wyze Home Monitoring subscription. The keypad is not a standalone device and does not work with Wyze Sense v1 sensors.
Can I install the Wyze Sense Keypad using permanent adhesive?Yes, the Wyze Sense Keypad can be installed using permanent adhesive strips such as 3M double-sided tape. This method allows for a secure, drill-free installation on a flat, clean surface near your main entrance.
What do I need to install the Wyze Sense Keypad with permanent adhesive?To install the Wyze Sense Keypad with permanent adhesive, you will need the keypad itself, strong double-sided adhesive strips (like 3M), a clean cloth or alcohol wipes, and a flat, clean surface near your main entrance.
How do I install the Wyze Sense Keypad using permanent adhesive?To install the Wyze Sense Keypad with permanent adhesive: 1) Choose a flat, clean location near your main entrance. 2) Clean the surface with a cloth or alcohol wipe. 3) Cut and attach the adhesive strips to the back of the keypad. 4) Press the keypad firmly against the wall for about 30 seconds. 5) Test the keypad to ensure it is working correctly.
Where should I place the Wyze Sense Keypad for optimal security?For optimal security, place the Wyze Sense Keypad next to your primary entrance, at chest level, and out of reach of children and pets. Avoid areas near heat sources, direct sunlight, or places prone to moisture.
Does the Wyze Sense Keypad work with Wyze Sense v1 sensors?No, the Wyze Sense Keypad does not work with Wyze Sense v1 sensors. It is designed to operate with the Wyze Sense Hub and requires Wyze Home Monitoring.
What are the key features of the Wyze Sense Keypad?Key features of the Wyze Sense Keypad include remote arming and disarming of your security system, an on-device emergency button for quick alerts, compact design for easy placement, and seamless integration with the Wyze Sense Hub.
How can I ensure the adhesive holds the Wyze Sense Keypad securely?To ensure the adhesive holds securely, clean the mounting surface thoroughly to remove dust, dirt, or grease. Press the keypad firmly against the wall for at least 30 seconds and avoid placing it near heat sources or in direct sunlight.
What should I avoid when installing the Wyze Sense Keypad?Avoid installing the Wyze Sense Keypad near heat sources, in direct sunlight, or in areas prone to moisture or extreme temperature changes, as these conditions can weaken the adhesive and affect device performance.
What other Wyze security products can I use with the Wyze Sense Keypad?You can enhance your home security by pairing the Wyze Sense Keypad with other Wyze products such as the Wyze Cam v4 Outdoor Bundle, Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and Wyze Cam OG cameras for comprehensive protection.
Can you provide more details on how to test the placement of the Wyze Sense Keypad after installation?What should I do if the adhesive fails and the keypad falls off?Are there any specific locations where I should avoid placing the Wyze Sense Keypad?
