Top Affordable Noise Cancelling Bluetooth Headphones for Work
Best Affordable Noise Cancelling Bluetooth Headphones for Work Calls
When it comes to work calls, having clear audio and effective noise cancellation is essential for productivity and focus. If you're searching for the best affordable noise cancelling Bluetooth headphones that deliver excellent call quality without breaking the bank, the Wyze Noise-Cancelling Headphones stand out as a top choice. Below, we explore why these headphones are perfect for work calls and how they combine comfort, technology, and affordability.
Wyze Noise-Cancelling Headphones: Perfect for Work Calls and More
Hybrid Active Noise Cancellation for Focused Calls
The Wyze Noise-Cancelling Headphones feature Hybrid Active Noise Cancellation that blocks out up to 40 dB of ambient noise. This means whether you're working from a busy café, a noisy home office, or commuting, distractions fade away so you can focus on your calls and meetings.
Crystal Clear Voice-Isolating Microphones
Equipped with 6 total microphones designed for voice isolation, these headphones ensure your voice comes through loud and clear. The omnidirectional microphones with a sensitivity of -32 dB at 1kHz and a frequency response tailored for voice (50 - 10,000 Hz) make your work calls sound professional and crisp.
Long Battery Life and Quick Charging
Stay connected all day with up to 20 hours of wireless battery life on a single charge. If you're in a hurry, a quick 10-minute charge provides an additional 4 hours of use — perfect for back-to-back meetings or long conference calls.
Comfortable, Fatigue-Free Fit
Designed for extended wear, the headphones use a multilayer composite headband covered in protein leather and memory foam ear cushions. This fatigue-free fit lets you wear them comfortably throughout your workday without discomfort.
Smart Features for Convenience
  • Touch controls on the earcups allow easy management of calls and music.
  • Wear detection pauses audio when you take them off.
  • Compatible with Amazon Alexa and other voice assistants for hands-free control.
  • Supports multiple device connections simultaneously, so you can switch between your laptop and phone seamlessly.
Technical Highlights
  • Bluetooth 5.0 with a 33 ft (10 m) range
  • 40 mm dome-type drivers with neodymium magnets for rich sound
  • Frequency response over Bluetooth: 20 - 20,000 Hz
  • Lightweight at just 9.9 oz
"Like a symphony playing just for you." — Wyze
Wyze Noise-Cancelling Headphones Lifestyle Experience focused work calls with Wyze headphones on your daily commute.
Why Choose Wyze Noise-Cancelling Headphones for Work Calls?
  • Affordable Price: Starting at $89.99, these headphones offer premium noise cancellation and call clarity at a budget-friendly price.
  • Versatile Use: Ideal not only for calls but also for music, podcasts, and voice assistant commands.
  • Durability and Style: Available in black or white, with a sleek design that fits any professional setting.
  • Travel Ready: Optional travel case variants protect your headphones on the go.
Other Products to Consider
While the Wyze Noise-Cancelling Headphones are the best fit for affordable noise cancelling Bluetooth headphones for work calls, here are some other Wyze products that complement your work-from-home or office setup:
Though not headphones, the Google Nest Audio speaker offers excellent room-filling sound and built-in Google Assistant for hands-free voice commands, perfect for managing your smart home or office environment during work hours.
Wyze Lock Bolt
For enhanced home office security, the Wyze Lock Bolt offers smart keyless entry with fingerprint and app control, ensuring your workspace stays secure without hassle.
Summary
For professionals seeking the best affordable noise cancelling Bluetooth headphones tailored for work calls, the Wyze Noise-Cancelling Headphones deliver exceptional value. With hybrid active noise cancellation, voice-isolating microphones, long battery life, and a comfortable fit, they are designed to keep you focused and sounding your best during every call.
FeatureWyze Noise-Cancelling Headphones
ColorsBlack, White
StylesNo Travel Case, With Travel Case
Price Range$80.99 - $99.99 USD
Noise Cancellation40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)
Microphones4 noise-cancelling microphones + 2 voice-isolating microphones
Transparency ModeYes, outside sounds amplified with a touch
Wear DetectionYes, auto pause/resume audio when headphones are removed/put on
Quick ConversationsTouch right earcup to pause audio and enable Transparency Mode
DriversDual 40mm TPU Composite Diaphragm Drivers
Frequency ResponseUp to 38kHz
CustomizationWyze app with presets and custom EQ
ComfortResponsive memory foam, elongated earpads
ControlsTouch controls for calls, volume, voice assistant, playback
Voice AssistantsAmazon Alexa built-in, supports Siri, Google Assistant, Bixby
Bluetooth VersionBluetooth 5.0
Multi-Device ConnectionConnects to two devices simultaneously
Battery LifeNot specified
Included AccessoriesTravel case (optional variant)
Return Policy30-day hassle-free returns
What makes Wyze Noise-Cancelling Headphones the best affordable Bluetooth headphones for work calls?Wyze Noise-Cancelling Headphones offer premium features like hybrid active noise cancellation, six voice-isolating microphones, long battery life, and a comfortable fit—all at an affordable price starting at $89.99. These features ensure clear audio and effective noise reduction, making them ideal for professional work calls.
How effective is the noise cancellation on Wyze Noise-Cancelling Headphones?The Wyze Noise-Cancelling Headphones use hybrid active noise cancellation technology that blocks out up to 40 dB of ambient noise. This allows you to focus on your calls and meetings, even in noisy environments like cafés, home offices, or during commutes.
Are Wyze Noise-Cancelling Headphones comfortable for all-day wear?Yes, these headphones are designed for extended use with a multilayer composite headband covered in protein leather and memory foam ear cushions. This ensures a fatigue-free, comfortable fit throughout your workday.
How long does the battery last on Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones provide up to 20 hours of wireless battery life on a single charge. Additionally, a quick 10-minute charge gives you an extra 4 hours of use, making them perfect for long workdays and back-to-back meetings.
Do Wyze Noise-Cancelling Headphones have good microphone quality for calls?Absolutely. The headphones are equipped with six microphones designed for voice isolation, ensuring your voice is transmitted clearly and professionally during calls. The microphones have a sensitivity of -32 dB at 1kHz and a frequency response tailored for voice clarity.
What smart features do Wyze Noise-Cancelling Headphones offer?These headphones include touch controls for easy call and music management, wear detection that pauses audio when you remove them, compatibility with Amazon Alexa and other voice assistants, and support for connecting to multiple devices simultaneously.
Can I use Wyze Noise-Cancelling Headphones with multiple devices?Yes, Wyze Noise-Cancelling Headphones support multiple device connections, allowing you to seamlessly switch between your laptop and phone during your workday.
Are Wyze Noise-Cancelling Headphones suitable for travel?Yes, the headphones are lightweight at just 9.9 oz and offer optional travel case variants to protect them on the go, making them ideal for commuting or business travel.
What is the Bluetooth range of Wyze Noise-Cancelling Headphones?The headphones use Bluetooth 5.0 technology and have a wireless range of up to 33 feet (10 meters), providing reliable connectivity for your devices.
Are there other Wyze products that complement a work-from-home setup?Yes, Wyze also offers products like the Google Nest Audio speaker for room-filling sound and voice assistant capabilities, and the Wyze Lock Bolt for smart, keyless home office security.
What are the key features of the Wyze Noise-Cancelling Headphones?How do the Wyze Noise-Cancelling Headphones compare to other brands in terms of noise cancellation?Is there a warranty available for the Wyze Noise-Cancelling Headphones?
