Best Budget Noise Cancelling Headphones with Touch Controls
Budget Noise Cancelling Headphones with Touch Controls for Calls
If you're searching for affordable yet high-quality noise cancelling headphones that offer intuitive touch controls for seamless call management, the Wyze Noise-Cancelling Headphones stand out as the perfect choice. Designed to deliver premium sound and advanced features without breaking the bank, these headphones combine comfort, technology, and convenience in one sleek package.
Wyze Noise-Cancelling Headphones: Affordable Excellence in Audio
Powerful Active Noise Cancellation (ANC)
Experience a world where distractions fade away. The Wyze Noise-Cancelling Headphones feature 40dB Quick On/Off Hybrid ANC powered by four noise-cancelling microphones and an ultra-fast processor. This technology reduces outside noise to a whisper, allowing you to focus on your music, calls, or podcasts even in noisy environments.
Intuitive Touch Controls for Calls and More
Managing calls and media is effortless with the headphones’ intuitive touch and tap controls. Answer or end calls, adjust volume, pause/play music, skip tracks, or activate your voice assistant—all with simple gestures on the earcups. The dual voice-isolating microphones ensure your voice is crystal clear during calls, even in busy surroundings.
Transparency Mode & Quick Conversations
Need to hear your surroundings without removing your headphones? Just a gentle touch activates Transparency Mode, amplifying outside sounds so you can catch your coffee order or join a quick conversation instantly. Audio automatically pauses when you remove the headphones thanks to wear detection, resuming when you put them back on.
Premium Sound Quality
Enjoy rich, immersive sound with dual 40mm TPU composite diaphragm drivers delivering deep bass, stable mids, and crisp highs across a frequency range up to 38kHz. Whether you’re listening to music, watching movies, or gaming, these headphones provide a front-row audio experience.
Comfortable All-Day Wear
Designed for long listening sessions, the headphones feature responsive memory foam and elongated earpads that gently embrace your ears for a fatigue-free fit. Lightweight and stylish, they are perfect for commuting, working, or relaxing at home.
Seamless Connectivity & Voice Assistant Integration
With Bluetooth 5.0, connect to two devices simultaneously and switch effortlessly between calls and media. Built-in support for Amazon Alexa and your device’s native voice assistant (Siri, Google Assistant, Bixby) lets you access music, weather, reminders, and smart home controls hands-free.
Wyze Noise-Cancelling Headphones Lifestyle Enjoy music anywhere with Wyze Noise-Cancelling Headphones
Why Choose Wyze Noise-Cancelling Headphones?
  • Affordable price point starting at $80.99 for the no travel case version, with options including a travel case for added convenience.
  • Advanced noise cancellation technology usually found in premium headphones.
  • Touch controls that simplify call handling and media playback.
  • Clear voice calls with dual voice-isolating microphones.
  • Customizable sound profiles via the Wyze app for music, movies, gaming, and more.
  • Comfort-focused design for extended wear without fatigue.
  • Voice assistant support for hands-free control and smart home integration.
Summary
For those on a budget who refuse to compromise on sound quality, noise cancellation, and call management, the Wyze Noise-Cancelling Headphones deliver exceptional value. Their combination of advanced ANC, responsive touch controls, and comfortable design makes them an ideal choice for daily use—whether commuting, working remotely, or relaxing at home.
"Put the outside world on mute and enjoy your own private symphony with Wyze Noise-Cancelling Headphones."
FeatureWyze Noise-Cancelling Headphones
Colors AvailableBlack, White
Styles AvailableNo Travel Case, With Travel Case
Price Range$80.99 - $99.99
Noise Cancellation40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)
Microphones4 noise-cancelling microphones
Transparency ModeYes
Wear DetectionYes (pauses/resumes audio automatically)
Quick ConversationsYes (touch right earcup to pause and enable Transparency Mode)
DriversDual 40mm TPU Composite Diaphragm Drivers
Frequency ResponseUp to 38kHz
CustomizationVia Wyze app with presets and custom adjustments
ComfortResponsive memory foam and elongated earpads
ControlsTouch controls for calls, volume, voice assistant, playback
Voice AssistantsAmazon Alexa built-in, Siri, Google Assistant, Bixby
Voice IsolationDual voice-isolating microphones
Bluetooth VersionBluetooth 5.0
Multi-device ConnectionConnects to two devices simultaneously
Battery LifeNot specified
Return Policy30-day hassle-free returns
What features make Wyze Noise-Cancelling Headphones a good budget option?Wyze Noise-Cancelling Headphones offer advanced active noise cancellation, intuitive touch controls, premium sound quality, and comfortable all-day wear at an affordable price starting at $80.99. They provide features typically found in higher-end headphones, making them an excellent value for budget-conscious buyers.
How effective is the noise cancellation on Wyze Noise-Cancelling Headphones?The Wyze Noise-Cancelling Headphones feature 40dB Quick On/Off Hybrid Active Noise Cancellation powered by four noise-cancelling microphones and an ultra-fast processor. This technology significantly reduces outside noise, allowing you to focus on your music, calls, or podcasts even in noisy environments.
Do Wyze Noise-Cancelling Headphones have touch controls for calls and music?Yes, Wyze Noise-Cancelling Headphones come with intuitive touch and tap controls on the earcups. You can answer or end calls, adjust volume, pause/play music, skip tracks, and activate your voice assistant with simple gestures.
Can I use voice assistants with Wyze Noise-Cancelling Headphones?Absolutely. The headphones support Amazon Alexa as well as your device’s native voice assistants, including Siri, Google Assistant, and Bixby, allowing for hands-free control and smart home integration.
What is Transparency Mode on Wyze Noise-Cancelling Headphones?Transparency Mode lets you hear your surroundings without removing your headphones. With a gentle touch, outside sounds are amplified so you can catch announcements or have quick conversations, and audio automatically pauses when you remove the headphones thanks to wear detection.
How is the sound quality of Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones deliver rich, immersive sound with dual 40mm TPU composite diaphragm drivers. They provide deep bass, stable mids, and crisp highs across a frequency range up to 38kHz, ensuring a high-quality audio experience for music, movies, and gaming.
Are Wyze Noise-Cancelling Headphones comfortable for long-term use?Yes, these headphones are designed for comfort with responsive memory foam and elongated earpads that gently embrace your ears. Their lightweight and ergonomic design makes them suitable for extended listening sessions without causing fatigue.
Can Wyze Noise-Cancelling Headphones connect to multiple devices at once?Yes, with Bluetooth 5.0, Wyze Noise-Cancelling Headphones can connect to two devices simultaneously, allowing you to switch effortlessly between calls and media.
Is there an app to customize the sound profile of Wyze Noise-Cancelling Headphones?Yes, you can use the Wyze app to customize sound profiles for different activities such as music, movies, and gaming, tailoring the audio experience to your preferences.
What is included in the price of Wyze Noise-Cancelling Headphones?The base price of $80.99 includes the headphones without a travel case. There are also options available that include a travel case for added convenience.
What are the key features of the Wyze Noise-Cancelling Headphones?How does the active noise cancellation work in these headphones?Are there any ongoing sales or discounts for the Wyze Noise-Cancelling Headphones?
