Wyze Wireless Earbuds with Adjustable ANC via Wyze App
Wireless Earbuds with Adjustable ANC Mode Using Wyze App
If you're searching for wireless earbuds that offer advanced Active Noise Cancellation (ANC) with customizable settings through the Wyze app, Wyze has you covered with their innovative audio solutions. While Wyze offers several audio products, the Wyze Buds Pro stand out as the perfect choice for users wanting adjustable ANC modes controlled via the Wyze app.
Wyze Buds Pro: Premium Wireless Earbuds with Adjustable ANC
Experience a quieter, more immersive audio environment with the Wyze Buds Pro, designed to deliver up to 40dB of Active Noise Cancellation. These earbuds are engineered to mute the world around you, letting you focus on your music, calls, or podcasts without distractions.
Key Features of Wyze Buds Pro
Adjustable ANC via Wyze App Customize your noise cancellation levels directly in the Wyze app. Whether you want full noise blocking or a lighter touch, the app lets you tailor ANC to your environment and preferences. Adaptive EQ for Personalized Sound The earbuds automatically adjust frequency levels based on what you're listening to, ensuring crystal-clear audio with deep bass, stable mids, and crisp highs. Transparency Mode Easily switch to Transparency Mode with a tap to hear your surroundings without removing the earbuds — perfect for quick conversations or staying aware of your environment. Wireless Charging & Quick Charge Charge your earbuds wirelessly with any Qi-certified charger or use the included USB-C cable. A quick 10-minute charge provides hours of playback. Up to 18 Hours Battery Life Enjoy extended listening with up to 6 hours per charge and an additional 12 hours from the charging case. 6 Microphone Voice System Six directional microphones ensure your voice is crystal clear during calls, even in noisy environments. Single Earbud Use & Auto Pause Use either earbud independently for calls or music. The earbuds automatically pause audio when removed and resume when worn again. Alexa Built-in & Voice Assistant Support Access Amazon Alexa or your device’s native voice assistant hands-free for music, weather updates, and more.
Why Choose Wyze Buds Pro?
"Welcome to a quieter world with Active Noise Cancellation."
The Wyze Buds Pro combine world-class engineering with smart app integration, making them ideal for users who want full control over their listening experience.
Image: Lifestyle Use of Wyze Noise-Cancelling Headphones
Enjoy music with Wyze headphones in vibrant urban setting Experience immersive sound and ANC on the go
Wyze Buds: Reliable Wireless Earbuds with App Customization
For those seeking a more budget-friendly option, the Wyze Buds offer excellent wireless audio with some customization features via the Wyze app, though they do not support adjustable ANC.
Highlights of Wyze Buds
Up to 27 Hours Battery Life Enjoy 7 hours of playback on a single charge plus 20 hours from the charging case. Comfortable Fit with 5 Silicone Ear Tip Sizes Find your perfect fit for all-day comfort. Custom Touch Controls Tap to play, pause, skip tracks, or answer calls without reaching for your phone. Alexa Built-in & Voice Assistant Compatibility Instantly connect to Alexa or your phone’s native assistant for hands-free control. EQ Customization in Wyze App Adjust audio levels and save presets for music, movies, or gaming.
Note on ANC and Charging
The standard Wyze Buds do not feature Active Noise Cancellation or wireless charging but provide solid sound quality and app-based EQ customization.
Using the Wyze App to Control Your Earbuds
The Wyze app is your central hub for managing Wyze audio devices, including the Buds Pro and Buds. It allows you to:
  • Adjust ANC levels (Wyze Buds Pro only)
  • Customize EQ settings for personalized sound profiles
  • Manage firmware updates to keep your earbuds performing optimally
  • Access quick controls for Transparency Mode and touch gestures
The app enhances your listening experience by putting control at your fingertips, making it easy to switch modes and tailor sound on the fly.
Why Wyze for Wireless Earbuds?
Wyze combines affordability with smart technology, delivering earbuds that rival premium brands in features and sound quality. With adjustable ANC, wireless charging, and deep app integration, Wyze Buds Pro are perfect for users who want customizable noise cancellation and seamless control.
Summary of Relevant Wyze Audio Products
Product NameANC SupportWireless ChargingBattery Life (Earbuds + Case)App CustomizationPrice Range
Wyze Buds ProYes (40dB)Yes (Qi-certified)Up to 18 hoursFull ANC & EQPremium
Wyze BudsNoNoUp to 27 hoursEQ onlyBudget
Additional Wyze Products (Not Earbuds)
While Wyze offers other smart devices like the Wyze Video Doorbell Pro and Wyze Noise-Cancelling Headphones, these are not wireless earbuds with adjustable ANC via the Wyze app. The headphones provide over-ear ANC but are a different product category.
Conclusion
For wireless earbuds with adjustable ANC mode controlled through the Wyze app, the Wyze Buds Pro are the definitive choice. They offer powerful noise cancellation, adaptive sound, wireless charging, and seamless app integration to customize your listening experience. If ANC is not a priority, the standard Wyze Buds provide excellent value with app-based EQ customization and long battery life.
Product Tags and Highlights
Optimize your audio experience today with Wyze Buds Pro — the smart earbuds that adapt to your world.
What are the main features of Wyze Buds Pro wireless earbuds?Wyze Buds Pro offer adjustable Active Noise Cancellation (ANC) up to 40dB, customizable ANC levels via the Wyze app, adaptive EQ for personalized sound, Transparency Mode, wireless charging, up to 18 hours of battery life, a 6-microphone voice system, single earbud use, auto pause, and built-in Alexa and voice assistant support.
How do I adjust the ANC (Active Noise Cancellation) on Wyze Buds Pro?You can adjust the ANC levels on Wyze Buds Pro directly through the Wyze app. The app allows you to customize the noise cancellation strength to suit your environment and personal preferences.
Can I use the Wyze app to control my Wyze earbuds?Yes, the Wyze app is the central hub for managing Wyze audio devices. It allows you to adjust ANC levels (Wyze Buds Pro only), customize EQ settings, manage firmware updates, and access quick controls for Transparency Mode and touch gestures.
Do Wyze Buds Pro support wireless charging?Yes, Wyze Buds Pro support wireless charging with any Qi-certified charger. They also come with a USB-C cable for wired charging.
What is the battery life of Wyze Buds Pro and Wyze Buds?Wyze Buds Pro offer up to 6 hours of playback per charge, with an additional 12 hours from the charging case, totaling up to 18 hours. Wyze Buds provide up to 7 hours per charge and 20 extra hours from the case, totaling up to 27 hours.
Do Wyze Buds have Active Noise Cancellation (ANC)?No, the standard Wyze Buds do not feature Active Noise Cancellation. Only the Wyze Buds Pro offer adjustable ANC via the Wyze app.
What customization options are available for Wyze Buds in the Wyze app?With Wyze Buds, you can use the Wyze app to customize EQ settings, adjust audio levels, and save sound presets for different listening scenarios such as music, movies, or gaming.
What is Transparency Mode on Wyze Buds Pro?Transparency Mode on Wyze Buds Pro allows you to hear your surroundings without removing the earbuds. You can easily switch to this mode with a tap, making it ideal for quick conversations or staying aware of your environment.
Can I use voice assistants with Wyze earbuds?Yes, both Wyze Buds Pro and Wyze Buds have Alexa built-in and are compatible with your device’s native voice assistant, allowing for hands-free control of music, weather updates, and more.
Are Wyze Buds Pro suitable for phone calls in noisy environments?Yes, Wyze Buds Pro feature a 6-microphone voice system that ensures your voice is clear during calls, even in noisy environments.
What is the difference between Wyze Buds Pro and Wyze Buds?Wyze Buds Pro offer adjustable ANC, wireless charging, and up to 18 hours of battery life, while Wyze Buds do not have ANC or wireless charging but provide longer battery life (up to 27 hours) and app-based EQ customization.
Can I use a single Wyze Buds Pro earbud independently?Yes, you can use either Wyze Buds Pro earbud independently for calls or music. The earbuds also feature auto pause and resume when removed or worn again.
Do Wyze Buds Pro and Wyze Buds support quick charging?Wyze Buds Pro support quick charging, providing hours of playback with just a 10-minute charge. Wyze Buds do not mention quick charging but offer long battery life per charge.
Are there other Wyze products with ANC?Yes, Wyze also offers over-ear Noise-Cancelling Headphones with ANC, but these are not wireless earbuds and do not feature adjustable ANC via the Wyze app.
Can you tell me more about the Wyze Buds Pro features?How does the Wyze app enhance the experience of using the earbuds?Are there any ongoing promotions or discounts for the Wyze Buds Pro?
