Bluetooth Noise Cancelling Headphones with Voice Assistant Support
Discover the perfect blend of immersive sound, advanced noise cancellation, and smart voice assistant compatibility with Wyze Noise-Cancelling Headphones. Designed for music lovers, commuters, and anyone seeking a premium audio experience, these headphones deliver crystal-clear audio and seamless hands-free control.
Wyze Noise-Cancelling Headphones: Your Ultimate Audio Companion
Hybrid Active Noise Cancellation for Pure Sound
Experience up to 40 dB of hybrid active noise cancellation that blocks out distracting background noise, letting you focus on your music, calls, or podcasts. Whether you're on a busy train or working in a noisy café, these headphones create a private sound bubble just for you.
Voice Assistant Compatibility
Stay connected and in control with built-in support for Amazon Alexa and other native voice assistants. Use simple voice commands to play music, check the weather, or manage your smart home devices without lifting a finger.
Long-Lasting Battery Life & Quick Charge
Enjoy up to 20 hours of wireless playback or calls on a single charge. When you're in a hurry, a quick 10-minute charge provides an additional 4 hours of listening time, so your headphones are ready whenever you are.
Comfortable, Durable Design
Crafted with a multilayer composite headband covered in protein leather and memory foam ear cushions, these headphones offer a fatigue-free fit for extended wear. The touch-sensitive earcup controls make it easy to adjust volume, skip tracks, or answer calls with a tap.
Advanced Audio Technology
- 40 mm dome-type drivers with copper wire voice coils deliver rich, balanced sound.
- Frequency response ranges from 20 Hz to 20,000 Hz over Bluetooth, ensuring crisp highs and deep lows.
- Six omnidirectional microphones isolate your voice for clear calls and voice commands.
Connectivity & Convenience
- Bluetooth 5.0 with a 33 ft (10 m) range for stable wireless connection.
- Supports simultaneous connection to two devices, so you can switch between phone and laptop effortlessly.
- Transparency mode lets you hear ambient sounds without removing the headphones.
"Like a symphony playing just for you."
Enjoy music anywhere with Wyze headphones
Why Choose Wyze Noise-Cancelling Headphones?
- Hybrid Active Noise Cancellation for immersive listening
- Voice Assistant Support for hands-free control
- Comfortable Fit with premium materials
- Long Battery Life with fast charging
- High-Quality Audio with advanced drivers and microphones
- Multiple Device Connectivity for versatile use
Whether you're commuting, working, or relaxing at home, Wyze Noise-Cancelling Headphones provide the perfect balance of sound quality, comfort, and smart features.
Enhance Your Smart Home Audio Experience
Pair your Wyze Noise-Cancelling Headphones with smart home devices like Google Nest Audio or Wyze Cam for a connected lifestyle. Use voice commands to control your smart home, stream music, or check your security cameras effortlessly.
Seamless voice assistant integration
Summary of Wyze Noise-Cancelling Headphones Specs
Feature | Specification |
Noise Cancellation | Hybrid Active Noise Cancellation (40 dB) |
Battery Life | Up to 20 hours |
Quick Charge | 10 minutes = 4 hours playback |
Bluetooth Version | 5.0 |
Bluetooth Range | 33 ft (10 m) |
Voice Assistant | Amazon Alexa & native assistants |
Microphones | 6 omnidirectional microphones |
Frequency Response | 20 - 20,000 Hz (Bluetooth) |
Weight | 9.9 oz (280 g) |
Materials | Protein leather, memory foam, ABS plastic |
Connectivity | Supports 2 devices simultaneously |
Related Products for Smart Living
While Wyze Noise-Cancelling Headphones are the top choice for Bluetooth noise cancelling with voice assistant support, consider complementing your setup with these Wyze smart home products:
- Wyze Cam v4 Outdoor Bundle: Crystal-clear 2.5K QHD security camera with Alexa and Google Assistant compatibility for smart home monitoring.
- Google Nest Audio + Wyze Bundles: High-quality smart speaker with built-in Google Assistant for voice-controlled music and smart home management.
These devices integrate smoothly with your headphones’ voice assistant features, creating a cohesive and convenient smart home environment.
Conclusion
For those seeking Bluetooth noise cancelling headphones with voice assistant support, Wyze Noise-Cancelling Headphones stand out with their superior sound quality, comfort, and smart features. Enjoy immersive audio, effortless voice control, and long-lasting battery life in a stylish, durable design.
Upgrade your listening experience today with Wyze — where technology meets lifestyle.
What are the key features of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones offer hybrid active noise cancellation up to 40 dB, voice assistant compatibility (including Amazon Alexa), up to 20 hours of battery life, quick charging, comfortable protein leather and memory foam design, advanced 40 mm drivers, six omnidirectional microphones, Bluetooth 5.0 connectivity, and support for connecting to two devices simultaneously.How effective is the noise cancellation on Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones feature hybrid active noise cancellation that blocks up to 40 dB of background noise, creating a private listening environment ideal for commuting, working, or relaxing in noisy spaces.Are Wyze Noise-Cancelling Headphones compatible with voice assistants?
Yes, Wyze Noise-Cancelling Headphones support Amazon Alexa and other native voice assistants, allowing you to use voice commands to play music, check the weather, control smart home devices, and more.How long does the battery last on Wyze Noise-Cancelling Headphones?
The headphones provide up to 20 hours of wireless playback or calls on a single charge. Additionally, a quick 10-minute charge gives you up to 4 hours of extra listening time.Can I connect Wyze Noise-Cancelling Headphones to multiple devices at once?
Yes, Wyze Noise-Cancelling Headphones support simultaneous connection to two devices, making it easy to switch between your phone and laptop without disconnecting.What is the Bluetooth range of Wyze Noise-Cancelling Headphones?
The headphones use Bluetooth 5.0 technology and offer a wireless range of up to 33 feet (10 meters) for stable and reliable connectivity.Are Wyze Noise-Cancelling Headphones comfortable for long-term use?
Yes, the headphones are designed with a multilayer composite headband covered in protein leather and memory foam ear cushions, providing a fatigue-free fit for extended listening sessions.What audio quality can I expect from Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones feature 40 mm dome-type drivers with copper wire voice coils, delivering rich, balanced sound with a frequency response of 20 Hz to 20,000 Hz over Bluetooth for crisp highs and deep lows.Do Wyze Noise-Cancelling Headphones have a transparency mode?
Yes, the headphones include a transparency mode that allows you to hear ambient sounds without removing the headphones, enhancing safety and awareness in public spaces.How do Wyze Noise-Cancelling Headphones enhance smart home audio experiences?
You can pair Wyze Noise-Cancelling Headphones with smart home devices like Google Nest Audio or Wyze Cam, using voice commands to control your smart home, stream music, or check security cameras for a seamless connected lifestyle.What materials are used in the construction of Wyze Noise-Cancelling Headphones?
The headphones are made with premium materials, including protein leather, memory foam, and ABS plastic, ensuring both durability and comfort.How much do Wyze Noise-Cancelling Headphones weigh?
Wyze Noise-Cancelling Headphones weigh 9.9 ounces (280 grams), making them lightweight and comfortable for everyday use.
