Affordable Wireless Noise Cancelling Headphones with Transparency Mode
If you're searching for
affordable wireless noise cancelling headphones that also feature
transparency mode, the Wyze Noise-Cancelling Headphones stand out as an excellent choice. Designed to deliver premium sound quality and advanced noise control without breaking the bank, these headphones combine comfort, smart features, and affordability in one sleek package.
Wyze Noise-Cancelling Headphones: Premium Features at a Great Price
Powerful Active Noise Cancellation (ANC)
Experience the world on your terms with Wyze’s
40dB Quick On/Off Hybrid Active Noise Cancellation. Equipped with four noise-cancelling microphones and an ultra-fast processor, these headphones reduce outside noise to a whisper, allowing you to focus on your music, podcasts, or calls even in noisy environments like busy streets or public transit.
Transparency Mode for Situational Awareness
Need to hear your surroundings without removing your headphones? The
Transparency Mode amplifies outside sounds with a simple touch, so you can catch your coffee order or have quick conversations without missing a beat. This feature is perfect for urban commuters or anyone who wants to stay aware while enjoying their audio.
Superior Sound Quality
Wyze headphones feature
dual TPU composite diaphragm 40mm drivers delivering deep bass, stable mids, and crisp highs across a wide frequency range up to 38kHz. Whether you’re into music, movies, or gaming, these headphones provide a rich, immersive audio experience usually reserved for high-end brands.
Comfortable All-Day Wear
Designed with
responsive memory foam and elongated earpads, these headphones offer a fatigue-free fit that you can wear for hours without discomfort. The intuitive touch controls on the earcups let you manage calls, volume, and playback effortlessly.
Smart Features and Connectivity
- Wear Detection: Audio automatically pauses when you remove the headphones and resumes when you put them back on.
- Quick Conversations: Tap the right earcup to pause audio and enable Transparency Mode instantly.
- Voice Assistant Integration: Built-in Amazon Alexa and compatibility with Siri, Google Assistant, and Bixby let you control music, check weather, and manage smart home devices hands-free.
- Dual Device Bluetooth 5.0: Connect to two devices simultaneously and switch seamlessly between them.
Pricing and Variants
- Black without travel case: $80.99
- Black with travel case: $99.99
- White with travel case: $94.98
(Note: Some variants may be out of stock)
Enjoy music anywhere with Wyze headphones
Budget-Friendly Option: (Refurbished) Wyze Noise-Cancelling Headphones
For those looking to save even more, the
refurbished Wyze Noise-Cancelling Headphones offer the same premium features at a significantly reduced price. Fully tested and guaranteed to work like new, this option is perfect for budget-conscious buyers who want quality noise cancelling and transparency mode without compromise.
Key Features
- Same 40dB Hybrid ANC and Transparency Mode as new models
- Wear detection and quick conversation tap controls
- Dual 40mm drivers for rich sound
- Voice assistant support and Bluetooth 5.0 connectivity
Price
- Refurbished Black, no travel case: $34.99 (final sale, limited stock)
This refurbished model is a fantastic way to experience Wyze’s advanced audio technology at a fraction of the cost.
Perfect for urban commuting and daily use
Why Choose Wyze Noise-Cancelling Headphones?
"Like a symphony playing just for you." — Wyze
Wyze headphones combine world-class engineering, proprietary AI, and premium hardware to deliver an audio experience that rivals top-tier brands — all while remaining affordable. Whether you want to drown out distractions, stay aware with transparency mode, or enjoy crystal-clear calls with voice-isolating microphones, Wyze has you covered.
Summary of Features
Feature | Wyze Noise-Cancelling Headphones (New & Refurbished) |
Active Noise Cancellation | 40dB Quick On/Off Hybrid ANC |
Transparency Mode | Yes, with quick tap activation |
Drivers | Dual 40mm TPU Composite Diaphragm |
Frequency Range | Up to 38kHz |
Comfort | Memory foam, elongated earpads |
Connectivity | Bluetooth 5.0, dual device pairing |
Voice Assistants | Alexa built-in, Siri, Google Assistant, Bixby |
Battery Life | Long-lasting (details in product specs) |
Price Range | $80.99 - $99.99 (new), $34.99 (refurbished) |
Wyze Noise-Cancelling Headphones deliver exceptional value for anyone seeking
affordable wireless noise cancelling headphones with transparency mode. Whether you choose the brand-new or refurbished model, you get premium sound, smart features, and all-day comfort at a price that fits your budget.
What are the key features of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones offer 40dB hybrid active noise cancellation, transparency mode, dual 40mm TPU composite diaphragm drivers, memory foam earpads for comfort, Bluetooth 5.0 with dual device pairing, wear detection, quick conversation tap controls, and built-in voice assistant support for Alexa, Siri, Google Assistant, and Bixby.How does the active noise cancellation (ANC) work on Wyze headphones?
Wyze headphones use 40dB Quick On/Off Hybrid Active Noise Cancellation with four noise-cancelling microphones and an ultra-fast processor to significantly reduce outside noise, allowing you to enjoy music, calls, or podcasts even in noisy environments.What is transparency mode on Wyze Noise-Cancelling Headphones?
Transparency mode on Wyze headphones amplifies outside sounds, letting you hear your surroundings without removing the headphones. This feature is activated with a simple tap, making it easy to have conversations or stay aware of your environment.Are Wyze Noise-Cancelling Headphones comfortable for long-term use?
Yes, Wyze headphones are designed for all-day comfort with responsive memory foam and elongated earpads, ensuring a fatigue-free fit even during extended listening sessions.Can I connect Wyze headphones to multiple devices at once?
Yes, Wyze Noise-Cancelling Headphones support Bluetooth 5.0 with dual device pairing, allowing you to connect to two devices simultaneously and switch between them seamlessly.Do Wyze headphones support voice assistants?
Yes, Wyze headphones have built-in Amazon Alexa and are compatible with Siri, Google Assistant, and Bixby, enabling hands-free control of music, calls, and smart home devices.What is the price range for Wyze Noise-Cancelling Headphones?
The new Wyze Noise-Cancelling Headphones range from $80.99 (black without travel case) to $99.99 (black with travel case) and $94.98 (white with travel case). Refurbished models are available for $34.99 (black, no travel case), subject to stock availability.Are refurbished Wyze Noise-Cancelling Headphones available?
Yes, refurbished Wyze Noise-Cancelling Headphones are available at a lower price. They offer the same premium features as new models, including 40dB hybrid ANC, transparency mode, wear detection, and voice assistant support, and are fully tested to work like new.What is the sound quality like on Wyze Noise-Cancelling Headphones?
Wyze headphones deliver superior sound quality with dual 40mm TPU composite diaphragm drivers, providing deep bass, stable mids, and crisp highs across a wide frequency range up to 38kHz for an immersive audio experience.How do I activate transparency mode or pause audio quickly?
You can activate transparency mode or pause audio instantly by tapping the right earcup, making it easy to have quick conversations or stay aware of your surroundings without removing the headphones.
