Wyze Battery Cam Pro: Crisp 2.5K HDR & Color Night Vision
Wyze Battery Cam Pro: Crisp Image Quality Even in Low Light
The Wyze Battery Cam Pro is a top-tier wireless security camera designed to deliver exceptional image clarity, even in challenging low light conditions. Featuring a stunning 2.5K HDR video resolution, this camera captures vibrant, balanced images with rich colors day or night. Its advanced Color Night Vision technology ensures you never miss a detail, providing clear visuals when lighting is minimal.
Key Features of Wyze Battery Cam Pro
  • 2.5K HDR Video Resolution: Experience high dynamic range imaging that balances bright and dark areas for crisp, detailed footage.
  • Color Night Vision: See full-color video even in low light, enhancing security and situational awareness.
  • Integrated Spotlight & Siren: A 150-lumen motion-activated LED spotlight deters intruders and illuminates dark areas.
  • Radar + PIR Motion Detection: Dual sensors provide early and precise motion alerts, reducing false alarms.
  • Wire-Free & No Hub Required: Completely wireless with removable, rechargeable battery packs for flexible placement.
  • IP65 Weatherproof: Durable against rain, dust, and extreme weather conditions.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Local Recording: Supports microSD card recording for continuous or event-based footage without subscription.
"Wyze Battery Cam Pro offers pro-grade protection with the freedom to place your camera anywhere, capturing every detail with crystal-clear quality."
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Endless Protection
For those seeking uninterrupted security, the Wyze Battery Cam Pro + Solar Panel bundle combines the powerful camera with a solar charging solution. This setup ensures your camera stays powered longer by converting sunlight into energy, reducing the need for frequent battery swaps or recharging.
Why Choose the Solar Panel Bundle?
  • Sustainable Power Source: Harness solar energy to keep your camera running continuously.
  • Same Crisp 2.5K HDR Video: Enjoy all the image quality benefits of the Battery Cam Pro.
  • Weather-Resistant Solar Panel: Built to withstand outdoor elements with an IP65 rating.
  • Easy Installation: No electrician needed; simply mount the solar panel near your camera.
  • Flexible Mounting Options: Use the Wyze Universal Mount for ceiling or wall placement.
This bundle is perfect for remote locations, outdoor areas without power outlets, or anyone wanting hassle-free, long-lasting security coverage.
Wyze Bird Feeder Wireless Camera Bundle: Security Meets Nature Watching
If you want to combine home security with a love for birdwatching, the Bird Feeder Wireless Camera Bundle is an excellent choice. It includes the Wyze Battery Cam Pro, Wyze Solar Panel, and a vibrant Wyze Bird Feeder designed to attract a variety of birds.
Bundle Highlights
  • Watch and Record Birds Live: The camera captures every feathered visitor in crisp 2.5K resolution.
  • Weatherproof and Wire-Free: Perfect for outdoor use with no wiring hassles.
  • Solar Powered: Keeps the camera charged for extended birdwatching sessions.
  • Easy Integration: View live feeds and recordings conveniently through the Wyze app.
  • Attractive Bird Feeder Design: Durable polycarbonate construction with a 1-liter seed capacity.
This bundle is ideal for nature enthusiasts who want to enjoy wildlife while maintaining home security.
Additional Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
  • 6200mAh Rechargeable Battery: Lasts up to 6 months on a single charge.
  • USB-C Charging Port: Convenient and fast charging.
  • Compact and Lightweight: Easy to swap without interrupting camera operation.
Wyze Battery Charging Dock
  • Charge Two Batteries Simultaneously: Keep multiple batteries ready for continuous use.
  • Compact Design: Fits easily on any desk or shelf.
Includes Power Adapter and USB-C Cable
Why Choose Wyze Battery Cam Pro for Low Light Security?
The Wyze Battery Cam Pro stands out for its ability to deliver crisp, clear images even in low light thanks to its HDR technology and color night vision. Its wire-free design and removable battery packs provide unmatched flexibility, while the integrated spotlight and siren add an active layer of security. Whether you opt for the standalone camera, the solar-powered bundle, or the bird feeder package, Wyze offers versatile solutions tailored to your security and lifestyle needs.
Outdoor Security Camera in Use Wyze Battery Cam Pro providing clear night vision and security outdoors. Solar Panel Charging Wyze Camera Solar panel powering Wyze Battery Cam Pro for continuous security. Bird Feeder with Wyze Camera Enjoy birdwatching and home security with the Wyze Bird Feeder Wireless Camera Bundle.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera Bundle
Included Items1x Wyze Battery Cam Pro1x Wyze Battery Cam Pro, 1x Wyze Solar PanelWyze Bird Feeder, Wyze Battery Cam Pro, Wyze Solar Panel
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)2.5K HDR (Wyze Battery Cam Pro)
Spotlight & SirenIntegrated Spotlight & SirenIntegrated Spotlight & SirenIntegrated Spotlight & Siren (Wyze Battery Cam Pro)
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion Detection (Wyze Battery Cam Pro)
BatteryRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs (Wyze Battery Cam Pro)
Solar PowerNoYesYes
Weatherproof RatingIP65IP65IP65 (All components)
WiFi Support2.4 & 5 GHz2.4 & 5 GHz2.4 & 5 GHz (Wyze Battery Cam Pro)
Local RecordingYes, with microSD card (not included)Yes, with microSD card (not included)Yes, with microSD card (Wyze Battery Cam Pro)
Bird Feeder IncludedNoNoYes
Bird Feeder ColorsN/AN/ABlue, Brown
Bird Feeder MaterialN/AN/APolycarbonate
Bird Feeder DimensionsN/AN/A7.48 in x 10.12 in x 8.58 in (190mm x 257mm x 218mm)
Bird Seed CapacityN/AN/A1 Liter
Operating Temperature Range-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
Price (USD)$89.98 (1 Pack)$109.98$139.98 (with Blue Bird Feeder)
What is the video resolution of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features a stunning 2.5K HDR video resolution, delivering crisp, detailed, and vibrant images both day and night.
Does the Wyze Battery Cam Pro have color night vision?Yes, the Wyze Battery Cam Pro is equipped with advanced Color Night Vision technology, allowing you to see full-color video even in low light conditions.
Is the Wyze Battery Cam Pro wireless and easy to install?Absolutely. The Wyze Battery Cam Pro is completely wire-free, featuring removable, rechargeable battery packs for flexible placement and easy installation without the need for a hub.
How does the Wyze Battery Cam Pro detect motion?The camera uses dual motion detection technology, combining radar and PIR (Passive Infrared) sensors to provide early and precise motion alerts while reducing false alarms.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it durable against rain, dust, and extreme weather conditions for reliable outdoor use.
Can I use the Wyze Battery Cam Pro with both 2.4 GHz and 5 GHz Wi-Fi networks?Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi, allowing seamless connection to both 2.4 GHz and 5 GHz networks for stable and reliable streaming.
Does the Wyze Battery Cam Pro support local recording?Yes, the camera supports local recording via a microSD card, enabling continuous or event-based footage storage without the need for a subscription.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the wireless camera and a weather-resistant solar panel, providing continuous, sustainable power and reducing the need for frequent battery recharging.
Is the Wyze Solar Panel weather-resistant?Yes, the Wyze Solar Panel is built to withstand outdoor elements with an IP65 weatherproof rating, ensuring reliable performance in various weather conditions.
How easy is it to install the Wyze Solar Panel?The Wyze Solar Panel is designed for easy installation. Simply mount it near your camera using the included hardware—no electrician required.
What is the Wyze Bird Feeder Wireless Camera Bundle?The Wyze Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a durable bird feeder, allowing you to enjoy live birdwatching in crisp 2.5K resolution while maintaining home security.
Can I watch live bird footage with the Wyze Bird Feeder Bundle?Yes, you can watch and record live bird activity in high resolution through the Wyze app, thanks to the integrated Wyze Battery Cam Pro in the bird feeder bundle.
What accessories are available for the Wyze Battery Cam Pro?Accessories include the Wyze Removable Battery Pack, which lasts up to 6 months on a single charge, and the Wyze Battery Charging Dock, which can charge two batteries simultaneously for continuous camera operation.
How long does the Wyze Removable Battery Pack last?The Wyze Removable Battery Pack has a 6200mAh capacity and can last up to 6 months on a single charge, depending on usage.
Why is the Wyze Battery Cam Pro ideal for low light security?The Wyze Battery Cam Pro excels in low light security due to its 2.5K HDR video resolution and advanced color night vision, ensuring clear, detailed images even in challenging lighting conditions.
Can you tell me more about the Color Night Vision feature of the Wyze Battery Cam Pro?How does the radar and PIR motion detection work in the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
