High Definition Battery Cameras for Front Door Surveillance
When it comes to securing your front door with crystal-clear video and flexible installation, Wyze offers top-tier battery-powered cameras designed for effortless, wire-free protection. The
Wyze Battery Cam Pro and its solar-powered bundle provide exceptional 2.5K HDR video quality, advanced motion detection, and weatherproof durability — perfect for front door surveillance without the hassle of wiring or hubs.
Wyze Battery Cam Pro: Wire-Free, High Definition Security
Stunning 2.5K HDR Video Resolution
Experience sharp, vibrant video footage with 2.5K HDR resolution that captures every detail day or night. The camera’s high dynamic range balances bright and dark areas, ensuring you never miss a visitor or package at your front door.
Advanced Motion Detection with Radar + PIR
Wyze Battery Cam Pro combines radar and PIR sensors for superior motion detection accuracy. This dual-sensor system detects movement earlier and reduces false alerts, so you get notified only when it matters. Customize detection zones in the Wyze app for precise monitoring.
Integrated Spotlight & Siren
The built-in 150-lumen spotlight activates on motion to illuminate your doorstep, deterring intruders and enhancing night visibility. You can also manually control the spotlight via the app for added security during nighttime activities.
Flexible Power Options & Weatherproof Design
- Removable, rechargeable battery packs allow easy hot-swapping to keep your camera running without downtime.
- Rated IP65 weatherproof, the camera withstands rain, snow, and dust, making it ideal for outdoor front door placement.
- Supports both 2.4 GHz and 5 GHz Wi-Fi for reliable connectivity.
Local and Cloud Storage
Record locally to a microSD card (sold separately) for continuous event capture without subscription fees. For enhanced smart detections like person, package, and vehicle notifications, Wyze offers optional Cam Plus cloud plans.
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Endless Protection
Solar-Powered Convenience
Never worry about battery life again. The Wyze Battery Cam Pro + Solar Panel bundle converts sunlight into power, extending your camera’s uptime and reducing the need for manual recharging. This is perfect for front doors exposed to sunlight, ensuring uninterrupted surveillance.
All the Features of Wyze Battery Cam Pro
This bundle includes everything from the standard Battery Cam Pro: 2.5K HDR video, radar + PIR motion detection, integrated spotlight and siren, and IP65 weather resistance — plus the added benefit of solar charging.
Easy Setup and Mounting
Mount your camera anywhere around your front door with flexible options, including wall, ceiling, or eave mounts. The solar panel attaches seamlessly to keep your camera powered day and night.
Essential Accessories for Extended Use
Wyze Removable Battery Pack
Keep your camera powered longer with extra 6200mAh rechargeable battery packs. Each battery lasts up to 6 months on a single charge, and the USB-C charging port makes recharging quick and convenient.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with this compact dock, ensuring you always have a fresh battery ready to swap in your camera.
Why Choose Wyze Battery Cameras for Front Door Surveillance?
"Wyze Battery Cam Pro offers pro-grade security with the freedom of wireless installation and high-definition video clarity. Its weatherproof design and smart motion detection make it the perfect choice for front door monitoring."
- No wires or hubs required — install anywhere with ease
- 2.5K HDR video for crystal-clear images
- Radar + PIR sensors for precise motion alerts
- Integrated spotlight and siren for active deterrence
- IP65 weatherproof for all-season reliability
- Solar panel option for continuous power without hassle
Wyze Battery Cam Pro providing weather-resistant outdoor security
Summary of Wyze Battery Camera Options for Front Door
Product | Video Resolution | Power Source | Weatherproof | Special Features | Price Range |
Wyze Battery Cam Pro | 2.5K HDR | Rechargeable Battery | IP65 | Radar + PIR, Spotlight, Siren | $89.98 (1 pack) |
Wyze Battery Cam Pro + Solar Panel | 2.5K HDR | Battery + Solar Panel | IP65 | Continuous solar power, all above | $109.98 |
Enhance Your Front Door Security Today
Choose the Wyze Battery Cam Pro or the Solar Panel bundle for a high-definition, wire-free security solution that keeps your front door safe and monitored 24/7. With flexible power options, smart motion detection, and weatherproof durability, these cameras are designed to protect your home effortlessly.
What is the video quality of the Wyze Battery Cam Pro for front door surveillance?
The Wyze Battery Cam Pro offers stunning 2.5K HDR video resolution, providing sharp and vibrant footage that captures every detail at your front door, day or night.How does the Wyze Battery Cam Pro detect motion?
The Wyze Battery Cam Pro uses advanced motion detection with both radar and PIR (Passive Infrared) sensors. This dual-sensor system increases accuracy, detects movement earlier, and reduces false alerts. You can also customize detection zones in the Wyze app for precise monitoring.Is the Wyze Battery Cam Pro weatherproof for outdoor use?
Yes, the Wyze Battery Cam Pro is rated IP65 weatherproof, making it resistant to rain, snow, and dust. It is ideal for outdoor front door placement in all seasons.What power options are available for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features removable, rechargeable battery packs for easy hot-swapping. It also supports a solar panel bundle for continuous power, reducing the need for manual recharging.Can I use the Wyze Battery Cam Pro without a subscription?
Yes, you can record locally to a microSD card (sold separately) for continuous event capture without any subscription fees. For enhanced smart detections like person, package, and vehicle notifications, Wyze offers optional Cam Plus cloud plans.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera with all its features—2.5K HDR video, radar + PIR motion detection, integrated spotlight and siren, and IP65 weather resistance—plus a solar panel for continuous, sunlight-powered operation.How long does the Wyze removable battery pack last?
Each Wyze removable battery pack has a capacity of 6200mAh and can last up to 6 months on a single charge, depending on usage and environmental conditions.Does the Wyze Battery Cam Pro have a spotlight and siren?
Yes, the Wyze Battery Cam Pro features a built-in 150-lumen spotlight that activates on motion to illuminate your doorstep and deter intruders. It also includes a siren for added security.What Wi-Fi networks are supported by the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks, ensuring reliable connectivity for your front door surveillance.How easy is it to install the Wyze Battery Cam Pro at my front door?
The Wyze Battery Cam Pro is designed for effortless, wire-free installation. It can be mounted on walls, ceilings, or eaves, and does not require any wires or hubs, making it easy to set up anywhere around your front door.
