Essential Accessories for Wyze Battery Cam Pro
Enhance your Wyze Battery Cam Pro experience with a range of specially designed accessories that boost functionality, extend battery life, and improve convenience. Whether you want longer recording times, easier battery management, or reliable outdoor power, these accessories are tailored to meet your needs.
Extend Battery Life and Power Options
Wyze Battery Cam Solar Panel
Keep your Wyze Battery Cam Pro powered up without the hassle of frequent recharging. The Wyze Battery Cam Solar Panel is a weather-resistant accessory designed to attach seamlessly to your camera. It harnesses solar energy to extend your camera’s battery life, making it perfect for outdoor use in any season. Compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, this solar panel features a sleek white frame with black solar cells and can be mounted virtually anywhere.
- Weather-resistant and durable for all seasons
- Easy installation and versatile mounting options
- Compatible with multiple Wyze outdoor cameras
- Price: $24.99 for the solar panel, $5.99 for USB-C adapter cable
Wyze Removable Battery Pack
Never worry about your camera running out of juice. The Wyze Removable Battery Pack offers a powerful 6200mAh rechargeable battery designed specifically for the Battery Cam Pro and Duo Cam Doorbell. Swap batteries quickly to keep your camera running continuously without downtime.
- High-capacity 6200mAh battery for extended use
- Rechargeable and easy to replace
- Sleek white design matching Wyze devices
- Price: $22.99
Wyze Battery Charging Dock
Charge smarter with the Wyze Battery Charging Dock, capable of charging two batteries simultaneously. This dual dock is perfect for users who want to keep multiple batteries ready to go, ensuring your Wyze Battery Cam Pro is always powered up and ready.
- Dual battery charging capability
- Compact and user-friendly design
- White finish complements Wyze accessories
- Price: $17.99
Reliable Outdoor Power Solutions
Wyze Outdoor Power Adapter
Designed to withstand rain, snow, and shine, the Wyze Outdoor Power Adapter is IP67 weather-resistant, making it ideal for continuous outdoor camera use. For the Wyze Battery Cam Pro, this adapter requires the USB-C adapter to function properly. It ensures your camera stays powered without interruption, even in harsh weather conditions.
- IP67-rated weather resistance for outdoor durability
- Compatible with Wyze Battery Cam Pro (with USB-C adapter)
- Multiple adapter styles available for different Wyze cameras
- Price ranges from $5.99 to $19.99 depending on the variant
Storage and Additional Accessories
Wyze MicroSD Card
Unlock continuous recording and time-lapse features with the Wyze MicroSD Card. Available in 32GB, 128GB, and 256GB sizes, this memory card is perfect for storing all your footage locally, ensuring you never miss a moment.
- Supports continuous recording and time lapses
- Multiple storage sizes to fit your needs
- Compatible with all Wyze cameras
- Price: $8.99 to $29.99 depending on size
Wyze Bird Feeder
For nature lovers, the Wyze Bird Feeder is a unique accessory that pairs perfectly with your Wyze Camera. Watch and record live video of birds visiting the feeder, turning your outdoor space into a vibrant birdwatching station. Its bright blue and orange design attracts a variety of feathered friends.
- Designed to attract and record birds live
- Durable polycarbonate construction
- Compatible with your favorite Wyze Camera
- Price: $39.99
Elevate your Wyze Battery Cam Pro setup with these essential accessories designed to maximize performance, convenience, and outdoor durability. Whether you want to extend battery life, ensure continuous power, or capture more moments, these accessories have you covered.
Solar panel accessory powering Wyze Battery Cam Pro outdoors
Dual battery charging dock for uninterrupted camera use
Wyze Bird Feeder attracting birds for live video capture
What are the best accessories to enhance my Wyze Battery Cam Pro?
The best accessories for the Wyze Battery Cam Pro include the Wyze Battery Cam Solar Panel for extended battery life, Wyze Removable Battery Pack for quick battery swaps, Wyze Battery Charging Dock for charging multiple batteries, Wyze Outdoor Power Adapter for reliable outdoor power, Wyze MicroSD Card for local storage, and the Wyze Bird Feeder for birdwatching and live video capture.How does the Wyze Battery Cam Solar Panel work?
The Wyze Battery Cam Solar Panel is a weather-resistant accessory that attaches to your Wyze Battery Cam Pro and harnesses solar energy to keep your camera charged. It is easy to install, can be mounted almost anywhere, and is compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel is designed to be weather-resistant and durable, making it suitable for outdoor use in all seasons.Can I use the Wyze Removable Battery Pack with my Wyze Battery Cam Pro?
Yes, the Wyze Removable Battery Pack is specifically designed for the Wyze Battery Cam Pro and Duo Cam Doorbell. It features a high-capacity 6200mAh rechargeable battery that is easy to swap for continuous camera operation.What is the benefit of the Wyze Battery Charging Dock?
The Wyze Battery Charging Dock allows you to charge two batteries at the same time, ensuring you always have a fully charged battery ready for your Wyze Battery Cam Pro. Its compact and user-friendly design makes battery management easy.Is there a way to power my Wyze Battery Cam Pro continuously outdoors?
Yes, the Wyze Outdoor Power Adapter is IP67 weather-resistant and provides continuous power to your Wyze Battery Cam Pro when used with the USB-C adapter. It is designed to withstand rain, snow, and harsh outdoor conditions.What storage options are available for Wyze cameras?
The Wyze MicroSD Card is available in 32GB, 128GB, and 256GB sizes, supporting continuous recording and time-lapse features. It is compatible with all Wyze cameras and allows you to store footage locally.How can I use my Wyze camera for birdwatching?
The Wyze Bird Feeder is a unique accessory that pairs with your Wyze Camera, allowing you to watch and record live video of birds visiting your feeder. Its bright design attracts a variety of birds and is made from durable polycarbonate.Are Wyze accessories easy to install and use?
Yes, Wyze accessories such as the solar panel, battery pack, charging dock, and outdoor power adapter are designed for easy installation and user-friendly operation, making it simple to enhance your Wyze Battery Cam Pro experience.What is the price range for Wyze Battery Cam Pro accessories?
Wyze Battery Cam Pro accessories range in price: the solar panel is $24.99, the USB-C adapter cable is $5.99, the removable battery pack is $22.99, the battery charging dock is $17.99, the outdoor power adapter ranges from $5.99 to $19.99, the microSD card ranges from $8.99 to $29.99 depending on size, and the bird feeder is $39.99.
