Affordable DIY Home Security Kits with Professional Monitoring
Affordable Home Security Kits with DIY Installation and Professional Monitoring
Securing your home has never been easier or more affordable. Whether you're looking for a comprehensive starter kit or an enhanced system with advanced features, these Wyze home security kits offer DIY installation combined with professional monitoring options to keep your home safe 24/7. Explore the best options tailored for your needs, all designed for easy setup and reliable protection.
Whole Home Security Starter Kit: Simple, Effective, and Affordable
The Whole Home Security Starter Kit is perfect for those new to home security or anyone wanting a straightforward, budget-friendly solution. This kit includes:
  • Wyze Cam v4: Crystal-clear 2.5K QHD resolution with enhanced color night vision and motion-activated spotlight.
  • Wyze Video Doorbell v2: Keep an eye on your front door with 1080p HD video and two-way audio.
  • Wyze Home Monitoring Starter Kit: Basic sensors and keypad for entry and motion detection.
Key Features:
  • DIY installation with no tools required.
  • Compatible with Alexa and Google Assistant.
  • 24/7 local recording and cloud storage options.
  • Weather-resistant cameras suitable for indoor and outdoor use.
  • Affordable price point around $155.95.
This kit is ideal for homeowners who want a reliable, easy-to-install system that covers the essentials of home security. Wyze Home Monitoring Lifestyle Easy DIY installation with no tools required
Whole Home Security Enhanced Kit: Advanced Protection with Floodlight
For those seeking more robust security, the Whole Home Security Enhanced Kit adds powerful floodlight cameras to the starter kit’s features:
  • Wyze Cam v4: Same high-resolution camera with night vision.
  • Wyze Cam Floodlight v2: Bright floodlights with motion detection to deter intruders.
  • Includes all components from the starter kit.
Why Choose the Enhanced Kit?
  • Enhanced outdoor security with floodlight illumination.
  • Motion-activated floodlights improve visibility and safety.
  • Still easy to install yourself with no professional help needed.
  • Priced affordably at $256.91, offering great value for added security.
This kit is perfect for larger homes or properties needing extra outdoor lighting and surveillance.
Wyze Home Monitoring Core Starter Kit: Professional Monitoring Included
If professional monitoring is a priority, the Wyze Home Monitoring Core Starter Kit offers a smart, connected system with 3 months of professional monitoring included:
  • Wyze Sense Hub with wireless sensors:
  • 2x Entry Sensors for doors/windows.
  • 1x Motion Sensor with 25 ft detection range.
  • 1x Wireless Keypad with emergency button and backlit keys.
  • Built-in siren with 88db alarm.
  • Battery backup lasting up to 10 hours.
  • Wireless sensors with 18-month battery life.
  • Indoor use with easy setup and control via the Wyze app.
Benefits:
  • Professional monitoring for peace of mind.
  • Wireless, no-fuss installation.
  • Expandable system supporting up to 100 sensors.
  • Compact and unobtrusive design.
This kit is ideal for those who want professional security monitoring without complicated installation or high costs. Wyze Home Monitoring Motion Sensor Wireless motion sensor with wide detection field
The Front Porch Security Bundle: Smart Access and Video Doorbell
Secure your entryway with the Front Porch Security Bundle, combining smart locks and video doorbell technology:
  • Wyze Video Doorbell v2: 1080p HD video, two-way audio, night vision, and motion alerts.
  • Wyze Lock Bolt: Remote lock/unlock via app, with lock history tracking.
  • Wyze Chime: Customizable doorbell sounds and intruder alarm.
Highlights:
  • Control your front door remotely from anywhere.
  • View live video and communicate with visitors.
  • Works seamlessly with Alexa and Google Assistant.
  • Weather-resistant and durable components.
This bundle is perfect for homeowners wanting smart access control combined with video surveillance for their front porch.
Wyze Cam v4: The Core of Your Security System
The Wyze Cam v4 is a versatile camera included in many kits and also available separately:
  • 2.5K QHD video resolution for crystal-clear images.
  • Enhanced color night vision with motion-activated spotlight.
  • Wi-Fi 6 support for faster, more reliable connectivity.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Weather-resistant (IP65) for indoor/outdoor use.
Why Wyze Cam v4?
  • Affordable yet high-quality security camera.
  • Multiple mounting options including magnetic and wall mounts.
  • Built-in siren and two-way audio for active deterrence and communication.
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 providing reliable home security
Wyze Cam Pan v3: 360° Coverage with Pan and Tilt
For full coverage of your property, the Wyze Cam Pan v3 offers:
  • 360° horizontal and 180° vertical rotation.
  • 1080p HD video with 8x digital zoom.
  • IP65 weather resistance for outdoor use (requires separate power adapter).
  • Two-way audio with noise and echo cancellation.
  • Easy installation and app control.
This camera is ideal for monitoring large areas with a single device, providing flexible and comprehensive surveillance.
Why Choose Wyze Security Kits?
Affordable, easy to install, and packed with professional-grade features, Wyze security kits empower you to protect your home without breaking the bank or needing expert help.
  • DIY installation with clear instructions and no tools required.
  • Professional monitoring options for added security.
  • Integration with popular smart home platforms.
  • Expandable systems to grow with your needs.
  • Reliable weather-resistant cameras and sensors.
Secure your home today with a Wyze security kit tailored to your budget and security needs.
Summary of Featured Products
  • Whole Home Security Starter Kit
  • Whole Home Security Enhanced Kit
  • Wyze Home Monitoring Core Starter Kit
  • The Front Porch Security Bundle
  • Wyze Cam v4
  • Wyze Cam Pan v3
FeatureWhole Home Security Starter KitWhole Home Security Enhanced KitWyze Home Monitoring Core Starter KitThe Front Porch Security BundleWyze Cam v4Wyze Cam Pan v3
Price$155.95$256.91$111.98 (with 3 months professional monitoring)$123.99 - $173.97 (varies by style)$100.00 (regular), $35.98 (with 32GB MicroSD card)$39.98
Included Devices1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Monitoring Kit1x Wyze Cam v4, 1x Wyze Cam Floodlight v2, Monitoring Kit1x Wyze Sense Hub, 2x Entry Sensors, 1x Motion Sensor, 1x KeypadWyze Lock, Wyze Lock Gateway, Wyze Video Doorbell, Wyze ChimeWyze Cam v4Wyze Cam Pan v3
Camera ResolutionWyze Cam v4: 2.5K QHDWyze Cam v4: 2.5K QHD, Floodlight v2 (not specified)N/AWyze Video Doorbell: 1080p HD2.5K QHD (2560x1440)1080p (1920x1080)
Video Doorbell IncludedYes (Wyze Video Doorbell v2)NoNoYes (Wyze Video Doorbell and Chime)NoNo
Floodlight Camera IncludedNoYes (Wyze Cam Floodlight v2)NoNoNoNo
Home Monitoring SystemYes (Wyze Home Monitoring Starter Kit included)Yes (included)Yes (Core Starter Kit)NoNoNo
Sensors IncludedIncluded in Monitoring KitIncluded in Monitoring KitEntry Sensors, Motion Sensor, KeypadNoNoNo
Motion DetectionYes (Wyze Cam v4 and Monitoring Kit)Yes (Wyze Cam v4, Floodlight v2, Monitoring Kit)Yes (Wyze Sense Motion Sensor)Yes (Video Doorbell)YesYes
Two-Way AudioYes (Wyze Cam v4, Video Doorbell)Yes (Wyze Cam v4)NoYes (Video Doorbell)YesYes
Weather ResistanceWyze Cam v4: IP65Wyze Cam v4 & Floodlight v2: IP65Indoor use onlyVideo Doorbell: IP65IP65IP65
Night VisionWyze Cam v4: Color Night VisionWyze Cam v4: Color Night VisionN/AVideo Doorbell: IR Night LightColor Night VisionIR Night Vision
Local StorageWyze Cam v4: microSD card up to 512 GBWyze Cam v4: microSD card up to 512 GBN/ANomicroSD card up to 512 GBmicroSD up to 256 GB
Cloud StorageAvailable with subscriptionAvailable with subscriptionN/AN/AAvailable with subscriptionN/A
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 6N/AVideo Doorbell: 2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi (5 GHz not supported)
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/AAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Siren IncludedYes (Wyze Cam v4 built-in siren)Yes (Wyze Cam v4 built-in siren)88db siren (Wyze Sense Hub)Intruder alarm sound on chimeYesNo
Battery BackupN/AN/ABuilt-in, 10 hrs backupBatteries for lock (4x AA)Wired power adapter requiredWired power adapter required
Operating Temperature Range-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)32°F to 104°F (0°C to 40°C)Video Doorbell: -4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specifiedNot specified1-Year warranty1-Year warranty
What is included in the Wyze Whole Home Security Starter Kit?The Wyze Whole Home Security Starter Kit includes a Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision, a Wyze Video Doorbell v2 with 1080p HD video and two-way audio, and a Wyze Home Monitoring Starter Kit featuring basic sensors and a keypad for entry and motion detection.
How easy is it to install Wyze home security kits?Wyze home security kits are designed for easy DIY installation with no tools required. Clear instructions are provided, making setup quick and hassle-free for homeowners.
Are Wyze security cameras weather-resistant?Yes, Wyze security cameras such as the Wyze Cam v4 and Wyze Cam Pan v3 are weather-resistant with an IP65 rating, making them suitable for both indoor and outdoor use.
Does Wyze offer professional monitoring with its security kits?Yes, the Wyze Home Monitoring Core Starter Kit includes 3 months of professional monitoring, providing 24/7 security and peace of mind for your home.
What are the benefits of the Wyze Whole Home Security Enhanced Kit?The Wyze Whole Home Security Enhanced Kit offers advanced protection with the addition of Wyze Cam Floodlight v2, providing bright floodlights and motion detection to deter intruders, along with all the features of the starter kit.
Can I control Wyze security devices with Alexa or Google Assistant?Yes, Wyze security devices are compatible with Alexa and Google Assistant, allowing you to control your system and receive alerts using your preferred smart home platform.
What is the price of the Wyze Whole Home Security Starter Kit?The Wyze Whole Home Security Starter Kit is affordably priced at around $155.95, making it a budget-friendly option for comprehensive home security.
What features does the Wyze Cam v4 offer?The Wyze Cam v4 features 2.5K QHD video resolution, enhanced color night vision, motion-activated spotlight, 24/7 local recording, cloud storage options, Wi-Fi 6 support, and compatibility with Alexa, Google Assistant, and IFTTT.
How does the Wyze Cam Pan v3 provide full property coverage?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical rotation, 1080p HD video, 8x digital zoom, and two-way audio, making it ideal for monitoring large areas with a single device.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell v2, Wyze Lock Bolt for remote locking and unlocking, and a Wyze Chime with customizable doorbell sounds and an intruder alarm.
Can Wyze security systems be expanded with additional sensors?Yes, the Wyze Home Monitoring Core Starter Kit supports up to 100 sensors, allowing you to expand your system as your security needs grow.
Is there a backup power option for Wyze security systems?Yes, the Wyze Home Monitoring Core Starter Kit features a battery backup that lasts up to 10 hours, ensuring your system remains operational during power outages.
What makes Wyze security kits a good choice for homeowners?Wyze security kits are affordable, easy to install, offer professional-grade features, integrate with popular smart home platforms, and provide reliable, weather-resistant protection for your home.
What are the key features of the Whole Home Security Starter Kit?Can you tell me more about the Wyze Home Monitoring Core Starter Kit?Are there any ongoing sales or discounts for the security kits?
