Securely Mount Your Wyze Cam Outdoors with the Weather-Resistant Wyze Outdoor Power Adapter
For mounting your Wyze Cam outdoors, especially under gutters, we recommend the Wyze Outdoor Power Adapter. Here’s why it’s a great fit:
  • Specifically designed for outdoor use with Wyze Cameras, offering IP67 weather resistance to withstand rain, snow, or shine.
  • Compatible with Wyze Cam v3, Wyze Cam v4, Pan v3, and Battery Cam Pro (with the appropriate adapter).
  • Includes a 12.5 ft (3.8 m) cable, providing flexibility for mounting in various outdoor locations, such as under gutters.
  • Comes with mounting accessories like wire clips, screws, and screw anchors to help secure the adapter and cable neatly along your installation path.
  • Certified for safety (FCC, UL) and backed by a 1-year warranty.
Please note: For Wyze Cam v3 Pro and Pan v3, both the Outdoor Power Adapter and the L-shaped MicroUSB Adapter are required. For Wyze Battery Cam Pro, you’ll need the Outdoor Power Adapter and USB-C adapter. These adapters are not compatible with the OG Stack Kit. This solution ensures your Wyze Cam remains powered and protected in outdoor environments, making it ideal for mounting under gutters or other exposed areas.
Can you tell me more about the compatibility of the Wyze Outdoor Power Adapter with different Wyze Cam models?What mounting accessories are included with the Wyze Outdoor Power Adapter?What should I do if I need to return the Wyze Outdoor Power Adapter?
