Specialized Cable Solutions for Powering Wyze Cameras Outdoors
When setting up your Wyze camera outdoors, especially at tricky angles or locations, having the right power adapter and cable is essential for reliable performance and weather resistance. The
Wyze Outdoor Power Adapter is specifically designed to power Wyze cameras in challenging outdoor environments, ensuring your security system stays active rain or shine.
Wyze Outdoor Power Adapter: The Ultimate Outdoor Power Solution
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter is built to withstand harsh outdoor conditions with an
IP67 weather resistance rating, making it ready for rain, snow, or shine. This means you can confidently install your Wyze camera in exposed locations without worrying about water damage or dust ingress.
Flexible Cable Lengths for Tricky Angles
- Cable length: 12.5 ft (3.8 m) total, including an 8.5 ft (2.6 m) DC cable and a 3.9 ft (1.2 m) AC cable.
- The extended cable length allows you to power your camera even when the power outlet is far or positioned awkwardly.
- Comes with an L-shaped Micro USB adapter to help connect your camera at difficult angles, preventing cable strain and ensuring a neat installation.
Compatibility and Accessories
- Compatible with Wyze Cam v3 Pro, Pan v3, Battery Cam Pro, and other models (note: requires specific adapters for some models).
- Includes wire clips, screws, and screw anchors for secure mounting.
- Certified by FCC and UL for safety and reliability.
- Operates in temperatures from -30°C to 50°C (-22°F to 122°F).
The Wyze Outdoor Power Adapter is the go-to accessory for powering your Wyze cameras outdoors, especially when installation angles or distances make standard cables impractical.
Wyze Cam Pan v3 powered outdoors with weather-resistant adapter
Wyze Cam Pan v3: Flexible 360° Pan and Tilt with Outdoor Power
Designed for Indoor and Outdoor Use
The
Wyze Cam Pan v3 offers a full
360° horizontal and
180° vertical field of view, making it perfect for monitoring wide outdoor areas. It is fully
IP65 weather resistant, but for safe outdoor use, it requires the Wyze Outdoor Power Adapter.
Key Features
- 1080p Full HD video with smooth pan and tilt.
- Night vision with 4 IR LEDs.
- Built-in speaker and microphone for 2-way audio with noise and echo cancellation.
- Fast rotation speed up to 110° per second.
- Compatible with Android and iOS devices.
- Supports microSD cards up to 256 GB for local storage.
Power and Installation
- Comes with a 6 ft (1.8 m) power cable.
- Requires the Wyze Outdoor Power Adapter for outdoor setups.
- Mounts easily with a screw mount or magnetic base.
The Pan v3 combined with the Outdoor Power Adapter is ideal for users needing flexible camera angles and reliable outdoor power.
Wyze Cam v4: High-Resolution Outdoor Security with Power Adapter Support
Crystal-Clear 2.5K QHD Resolution
The
Wyze Cam v4 delivers stunning
2.5K QHD video quality with enhanced color night vision and a motion-activated spotlight, providing superior security day and night.
Outdoor-Ready Features
- IP65 weather resistance for outdoor durability.
- Supports Wi-Fi 6 for faster and more reliable connectivity.
- Compatible with Alexa, Google Assistant, and IFTTT.
- Offers 24/7 local recording and cloud storage options.
- Multiple mounting options including wall, ceiling, and magnetic mounts.
Power and Connectivity
- Comes with a 6-foot flat micro USB to USB-A cable.
- Can be powered outdoors using the Wyze Outdoor Power Adapter for extended cable length and weather protection.
For users seeking high-resolution video and smart home integration, the Wyze Cam v4 paired with the Outdoor Power Adapter is a perfect match.
Bird Feeder Plug-in Cam v4 Bundle: Outdoor Power and Nature Monitoring
All-in-One Birdwatching and Security Solution
This bundle includes the
Wyze Bird Feeder,
Wyze Cam v4, and the
Wyze Outdoor Power Adapter, making it easy to power your camera outdoors while enjoying live birdwatching.
Features
- Weather-resistant for all seasons.
- Multiple mounting options: wall, tree, pole, cord, suction cup.
- Compatible with Wyze Solar Panel for sustainable power.
- Macro lens adapter included for close-up bird viewing.
This bundle is perfect for nature lovers who want to monitor wildlife with a reliable outdoor power setup.
Why Choose Wyze Outdoor Power Adapter for Your Wyze Cameras?
- Extended cable length and L-shaped adapter for tricky angles.
- IP67 weather resistance ensures durability in all weather conditions.
- Compatible with multiple Wyze camera models.
- Includes mounting hardware for secure installation.
- Certified and backed by a 1-year warranty.
Power your Wyze cameras outdoors confidently with the specialized Wyze Outdoor Power Adapter, designed to handle challenging installations and harsh environments.
Enjoy clear two-way audio communication with Wyze Cam Pan v3
Summary of Relevant Products
- Wyze Outdoor Power Adapter: Specialized outdoor power cable with weather resistance and L-shaped adapter for tricky angles.
- Wyze Cam Pan v3: 360° pan/tilt camera requiring the outdoor power adapter for outdoor use.
- Wyze Cam v4: High-resolution outdoor camera compatible with the outdoor power adapter.
- Bird Feeder Plug-in Cam v4 Bundle: Includes Wyze Cam v4 and outdoor power adapter for nature and security monitoring.
Ensure your Wyze cameras stay powered and protected outdoors with the right accessories designed for challenging setups and weather conditions.
What is the Wyze Outdoor Power Adapter and why do I need it for my Wyze camera?
The Wyze Outdoor Power Adapter is a specialized power solution designed to provide reliable and weather-resistant power to Wyze cameras installed outdoors. It features an IP67 weather resistance rating, extended cable length, and an L-shaped Micro USB adapter, making it ideal for powering cameras in challenging outdoor environments and tricky installation angles.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3 Pro, Pan v3, Battery Cam Pro, and other models. Some cameras may require specific adapters for compatibility. Always check your camera model’s requirements before purchasing.How weather-resistant is the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is rated IP67 for weather resistance, meaning it is fully protected against dust and can withstand immersion in water up to 1 meter deep. This makes it suitable for use in rain, snow, and other harsh outdoor conditions.What is the total cable length of the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter offers a total cable length of 12.5 feet (3.8 meters), which includes an 8.5 ft (2.6 m) DC cable and a 3.9 ft (1.2 m) AC cable. This extended length allows for flexible installation even when power outlets are far from the camera location.Does the Wyze Outdoor Power Adapter come with installation accessories?
Yes, the Wyze Outdoor Power Adapter includes wire clips, screws, and screw anchors for secure and easy mounting, ensuring a neat and reliable installation.Can I use the Wyze Cam Pan v3 outdoors?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant and can be used outdoors, but it requires the Wyze Outdoor Power Adapter for safe and reliable outdoor power.What are the key features of the Wyze Cam Pan v3 for outdoor security?
The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical pan and tilt, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, and fast rotation speed. It is compatible with Android and iOS devices and supports microSD cards up to 256 GB for local storage.Is the Wyze Cam v4 suitable for outdoor use?
Yes, the Wyze Cam v4 is IP65 weather resistant and designed for outdoor use. It features 2.5K QHD video quality, enhanced color night vision, a motion-activated spotlight, and supports Wi-Fi 6 for fast connectivity. For outdoor power, it is compatible with the Wyze Outdoor Power Adapter.What is included in the Bird Feeder Plug-in Cam v4 Bundle?
The Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter. It is designed for outdoor birdwatching and security, offering weather resistance, multiple mounting options, and compatibility with the Wyze Solar Panel for sustainable power.What certifications does the Wyze Outdoor Power Adapter have?
The Wyze Outdoor Power Adapter is certified by FCC and UL, ensuring safety and reliability for outdoor camera installations.What temperature range can the Wyze Outdoor Power Adapter operate in?
The Wyze Outdoor Power Adapter is designed to operate in temperatures ranging from -30°C to 50°C (-22°F to 122°F), making it suitable for use in extreme weather conditions.Why should I choose the Wyze Outdoor Power Adapter for my outdoor camera setup?
The Wyze Outdoor Power Adapter offers extended cable length, an L-shaped adapter for tricky angles, IP67 weather resistance, compatibility with multiple Wyze camera models, included mounting hardware, and is certified for safety. It is backed by a 1-year warranty, making it a reliable choice for powering Wyze cameras outdoors.
