Professional Grade Weatherproof Adapter for Commercial Wyze Camera Setups
When it comes to securing your commercial property with Wyze cameras, having a reliable, weatherproof power solution is essential. The
Wyze Outdoor Power Adapter is designed specifically to meet the demands of outdoor environments, ensuring your Wyze cameras stay powered rain or shine. This page highlights the best Wyze products tailored for professional-grade, weatherproof commercial camera setups, focusing on the Wyze Outdoor Power Adapter and compatible Wyze cameras.
Wyze Outdoor Power Adapter: Rugged and Reliable Power for Outdoor Use
Weatherproof and Durable Design
The Wyze Outdoor Power Adapter is built to withstand harsh weather conditions with an
IP67 rating, making it fully resistant to rain, snow, and dust. This ensures uninterrupted power supply to your Wyze cameras in any outdoor environment, from commercial parking lots to building perimeters.
- Operating Temperature: -30°C to 50°C (-22°F to 122°F)
- Cable Length: 12.5 ft (3.8 m) for flexible installation
- Input Power: 100V-240V AC
- Output Power: 5V 2A DC
- Connector: Micro USB to camera, 2-pin flat US plug to wall
- Certifications: FCC, UL for safety and compliance
- Warranty: 1-Year
Compatibility and Included Accessories
This adapter is compatible with multiple Wyze camera models, including:
- Wyze Cam v3 Pro and Pan v3 (requires L-shaped MicroUSB Adapter)
- Wyze Battery Cam Pro (requires USB-C adapter)
- Wyze Cam v3 and v4
The package includes the outdoor power adapter, weatherproof L-shaped Micro-USB adapter, wire clips, screws, and anchors for secure mounting.
Ready for rain, snow, or shine — the Wyze Outdoor Power Adapter is your go-to solution for powering Wyze cameras outdoors with confidence.
Wyze Cam Pan v3: The Ideal Outdoor Camera for Commercial Security
360° Pan and 180° Tilt with Weather Resistance
The
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring a 360° horizontal pan and 180° vertical tilt, allowing comprehensive coverage of your commercial property. It boasts an
IP65 weather resistance rating, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
- Video Resolution: Full HD 1080p
- Field of View: 120° FOV with 8x digital zoom
- Night Vision: 4 IR LEDs for clear nighttime monitoring
- Audio: Built-in speaker and microphone with 2-way audio and noise cancellation
- Connectivity: 2.4 GHz Wi-Fi (no 5 GHz support)
- Operating Temperature: -20°C to 50°C (-4°F to 122°F)
- Storage: Supports up to 256 GB microSD card
Professional Features for Commercial Use
- Fast rotation speed up to 110° per second for quick area scanning
- Push notifications for instant alerts
- Compatible with Alexa, Google Assistant, and IFTTT for smart integrations
For commercial setups requiring dynamic coverage and weatherproof reliability, the Wyze Cam Pan v3 combined with the Outdoor Power Adapter is a powerful duo.
Wyze Cam Pan v3 Security Bundles: Ready-to-Deploy Solutions
Bundled Convenience for Commercial Installations
For businesses looking to outfit multiple areas, the
Pan v3 Security Bundle offers two Wyze Cam Pan v3 cameras, each with a 6-foot micro USB cable, power adapter, mounting kit, and 32GB microSD cards. This bundle ensures you have everything needed for a professional-grade, weatherproof camera setup.
- Includes: 2x Wyze Cam Pan v3, 2x Power Adapters, 2x Mounting Kits, 2x 32GB microSD Cards
- Ideal For: Multi-zone commercial surveillance with weatherproof power solutions
Bundles like this simplify deployment and provide cost-effective, scalable security for commercial properties.
Additional Wyze Outdoor Accessories for Enhanced Commercial Use
While primarily designed for birdwatching, the
Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Outdoor Power Adapter and Wyze Cam v4, which is also weather-resistant and suitable for outdoor commercial use. This bundle offers flexible mounting options and a macro lens adapter, expanding the versatility of your outdoor camera setup.
- Compatible with multiple Wyze cameras including Battery Cam Pro and Cam Outdoor versions
- Weather-resistant for all seasons
- Easy installation on walls, poles, trees, or suction cups
Why Choose Wyze Outdoor Power Adapter for Commercial Setups?
The Wyze Outdoor Power Adapter is the professional-grade solution that ensures your Wyze cameras remain powered and operational in any weather condition. Its IP67 rating, long cable length, and compatibility with multiple Wyze camera models make it the ideal choice for commercial security systems requiring durability and reliability.
Summary of Key Products for Weatherproof Commercial Wyze Camera Setups
Product | Key Features | Weatherproof Rating | Compatibility |
Wyze Outdoor Power Adapter | IP67, 12.5 ft cable, Micro USB connector | IP67 | Wyze Cam v3, v4, Pan v3, Battery Cam Pro |
Wyze Cam Pan v3 | 360° pan, 1080p HD, 2-way audio, IP65 | IP65 | Works with Outdoor Power Adapter |
Pan v3 Security Bundle | 2x Pan v3 cameras + accessories + SD cards | IP65 | Includes Outdoor Power Adapter |
Bird Feeder Plug-in Cam v4 Bundle | Weather-resistant, multiple mounting options | Weather-resistant | Wyze Cam v4, Battery Cam Pro, Outdoor Cams |
By choosing the Wyze Outdoor Power Adapter alongside compatible Wyze cameras like the Pan v3, you ensure a professional, weatherproof, and reliable commercial camera setup that performs flawlessly in all conditions.
What is the Wyze Outdoor Power Adapter and why is it important for commercial Wyze camera setups?
The Wyze Outdoor Power Adapter is a professional-grade, weatherproof power solution designed to keep Wyze cameras powered in outdoor commercial environments. With an IP67 rating, it ensures reliable operation in rain, snow, and dust, making it essential for businesses that require uninterrupted security camera performance outdoors.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with several Wyze camera models, including Wyze Cam v3 Pro and Pan v3 (with L-shaped MicroUSB Adapter), Wyze Battery Cam Pro (with USB-C adapter), Wyze Cam v3, and Wyze Cam v4.What weatherproof ratings do the Wyze Outdoor Power Adapter and Wyze Cam Pan v3 have?
The Wyze Outdoor Power Adapter has an IP67 weatherproof rating, making it fully resistant to rain, snow, and dust. The Wyze Cam Pan v3 features an IP65 weather resistance rating, ensuring reliable outdoor performance when paired with the Outdoor Power Adapter.What is included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter package includes the outdoor power adapter itself, a weatherproof L-shaped Micro-USB adapter, wire clips, screws, and anchors for secure and flexible installation.What are the key features of the Wyze Cam Pan v3 for commercial security?
The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, Full HD 1080p video, 120° field of view, 8x digital zoom, night vision with 4 IR LEDs, two-way audio with noise cancellation, and fast rotation speed. It is weather-resistant (IP65) and supports up to 256 GB microSD card storage, making it ideal for commercial surveillance.What is included in the Wyze Cam Pan v3 Security Bundle?
The Wyze Cam Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, two power adapters, two mounting kits, and two 32GB microSD cards. This bundle is designed for multi-zone commercial surveillance and comes with weatherproof power solutions.Can the Wyze Outdoor Power Adapter be used in extreme temperatures?
Yes, the Wyze Outdoor Power Adapter is designed to operate in extreme temperatures, ranging from -30°C to 50°C (-22°F to 122°F), making it suitable for a wide variety of outdoor commercial environments.Are there additional Wyze outdoor accessories suitable for commercial use?
Yes, the Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Outdoor Power Adapter and Wyze Cam v4, which is weather-resistant and suitable for outdoor commercial use. This bundle offers flexible mounting options and is compatible with multiple Wyze cameras, including Battery Cam Pro and Cam Outdoor versions.What certifications does the Wyze Outdoor Power Adapter have?
The Wyze Outdoor Power Adapter is FCC and UL certified, ensuring safety and compliance for commercial installations.Why should businesses choose the Wyze Outdoor Power Adapter for their commercial security systems?
Businesses should choose the Wyze Outdoor Power Adapter because it provides a durable, weatherproof, and reliable power source for Wyze cameras. Its IP67 rating, long cable length, and compatibility with multiple camera models make it the ideal choice for commercial security systems that require continuous operation in any weather condition.
