Sleek Design Outdoor Adapter for Aesthetic Wyze Camera Mounting
When it comes to mounting your Wyze outdoor cameras, having a sleek, weather-resistant power adapter is essential for both functionality and maintaining a clean, aesthetic look. The
Wyze Outdoor Power Adapter is designed specifically to complement your Wyze cameras while providing reliable power in any weather condition. Whether you own the Wyze Cam Pan v3, Wyze Cam v4, or other compatible models, this adapter ensures your setup looks neat and performs flawlessly outdoors.
Wyze Outdoor Power Adapter: Durable and Stylish Power Solution
Weather-Resistant and Reliable
The Wyze Outdoor Power Adapter boasts an
IP67 weather-resistant rating, making it ready for rain, snow, or shine. This means you can confidently mount your Wyze cameras outdoors without worrying about power interruptions due to weather conditions.
Compatibility and Versatility
- Works seamlessly with Wyze Cam v4, Cam Pan v3, Cam v3 Pro, OG series, and Battery Cam Pro (with appropriate adapters).
- Requires pairing with the L-shaped Micro USB Adapter for Cam v3 Pro and Pan v3.
- For Wyze Battery Cam Pro, use with the USB-C adapter.
- Note: Not compatible with the OG Stack Kit.
Sleek and Practical Design
The adapter’s compact and clean design ensures it blends well with your camera setup, maintaining an aesthetic outdoor installation without bulky or unsightly cables.
Wyze Cam Pan v3: Perfect Match for Outdoor Power Adapter
Experience 360° pan and 180° tilt with weather-resistant design
Key Features
- 360° horizontal and 180° vertical rotation for full coverage.
- IP65 weather resistance for reliable outdoor use.
- 1080p Full HD video with 4 IR LEDs for night vision.
- Built-in speaker and microphone with two-way audio and noise cancellation.
- Compatible with Wyze Outdoor Power Adapter for continuous power.
- Sleek matte polycarbonate body available in white or black.
Mounting and Power
- Mounts easily with a screw 1/4" - 20 thread.
- Powered via micro USB port, ideally paired with the Wyze Outdoor Power Adapter and L-shaped Micro USB Adapter for a tidy, weatherproof setup.
Wyze Cam v4 Outdoor Bundle: Ultimate Outdoor Security with Power Adapter Included
What’s Included
- Wyze Cam v4 with crystal-clear 2.5K QHD resolution.
- Wyze Outdoor Power Adapter for seamless outdoor power.
- 128GB Wyze MicroSD card for 24/7 local recording.
Features That Impress
- Enhanced Color Night Vision and motion-activated spotlight for superior night security.
- Wi-Fi 6 support for faster, more reliable connectivity.
- Compatible with Alexa and Google Assistant for smart home integration.
- IP65 weather resistance ensures durability in all outdoor conditions.
- Multiple mounting options to fit your aesthetic and functional needs.
Why Choose Wyze Outdoor Power Adapter for Your Wyze Cameras?
"Ready for rain, snow, or shine" — the Wyze Outdoor Power Adapter is engineered to keep your cameras powered without compromising on style or durability. Its sleek design complements the modern look of Wyze cameras, making it the perfect accessory for aesthetic outdoor mounting.
Summary of Compatible Wyze Outdoor Camera Solutions
Product | Key Outdoor Features | Power Adapter Compatibility |
Wyze Outdoor Power Adapter | IP67 weather-resistant, compact design | Works with Cam v4, Pan v3, v3 Pro |
Wyze Cam Pan v3 | 360° pan, IP65 weather resistance, 1080p HD | Requires Outdoor Power Adapter + L-shaped adapter |
Wyze Cam v4 Outdoor Bundle | 2.5K QHD, Enhanced Color Night Vision, IP65 | Includes Outdoor Power Adapter |
Enhance Your Outdoor Security Setup Today
Pair your Wyze cameras with the
Wyze Outdoor Power Adapter for a sleek, weatherproof, and reliable power solution that enhances both the look and functionality of your outdoor security system.
What is the Wyze Outdoor Power Adapter and why is it important for outdoor camera setups?
The Wyze Outdoor Power Adapter is a weather-resistant, sleek power solution designed specifically for Wyze outdoor cameras. It ensures reliable power in any weather condition while maintaining a clean and aesthetic look for your outdoor camera installation.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam v3 Pro, OG series, and Wyze Battery Cam Pro (with the appropriate adapters). Please note, it is not compatible with the OG Stack Kit.Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it suitable for use in rain, snow, or shine. This ensures your Wyze cameras remain powered and protected in all outdoor conditions.What adapters are needed to use the Wyze Outdoor Power Adapter with different Wyze camera models?
For Wyze Cam v3 Pro and Cam Pan v3, you need to pair the Wyze Outdoor Power Adapter with the L-shaped Micro USB Adapter. For Wyze Battery Cam Pro, use the USB-C adapter.Does the Wyze Outdoor Power Adapter help maintain a neat and aesthetic camera setup?
Yes, the Wyze Outdoor Power Adapter features a compact and clean design that blends seamlessly with your camera setup, ensuring a tidy and visually appealing outdoor installation without bulky cables.What are the key features of the Wyze Cam Pan v3 when used outdoors?
The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical rotation, IP65 weather resistance, 1080p Full HD video, night vision, two-way audio with noise cancellation, and is compatible with the Wyze Outdoor Power Adapter for continuous, weatherproof power.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with 2.5K QHD resolution, a Wyze Outdoor Power Adapter for seamless outdoor power, and a 128GB Wyze MicroSD card for 24/7 local recording.Can the Wyze Outdoor Power Adapter be used for continuous power supply to Wyze cameras?
Yes, the Wyze Outdoor Power Adapter is designed to provide continuous, reliable power to compatible Wyze cameras, ensuring uninterrupted operation and enhanced security.How does the Wyze Outdoor Power Adapter enhance outdoor security camera installations?
The Wyze Outdoor Power Adapter enhances outdoor security camera installations by providing a weatherproof, reliable, and aesthetically pleasing power solution, ensuring your cameras remain operational and your setup looks professional.Is the Wyze Outdoor Power Adapter included with any Wyze camera bundles?
Yes, the Wyze Outdoor Power Adapter is included with the Wyze Cam v4 Outdoor Bundle, offering a complete solution for outdoor security and continuous power.
