Best Accessory Light Kits for Wyze Cam V3 in Low Light
Best Accessory Light Kit for Wyze Cam V3 in Low Light Conditions
When it comes to enhancing your Wyze Cam V3’s performance in low light conditions, having the right accessory light kit is essential. The Wyze Cam V3 Spotlight Kit is specifically designed to complement your Wyze Cam V3, providing bright, motion-activated illumination that significantly improves night vision and security monitoring in dark environments.
Wyze Cam V3 Spotlight Kit: Illuminate Your Night Vision
Powerful Motion-Activated Spotlight
The Wyze Cam V3 Spotlight Kit features a 70-lumen light output with 5 LEDs that cast a wide 130-degree beam. This motion-activated spotlight instantly brightens the area when movement is detected, ensuring your camera captures clear, detailed footage even in pitch-black conditions.
Durable and Weather-Resistant
Rated IP65, this spotlight is built to withstand outdoor elements such as rain, dust, and extreme temperatures ranging from -4°F to 131°F (-20°C to 55°C). Whether mounted indoors or outdoors, it provides reliable lighting support for your Wyze Cam V3.
Easy Power and Installation
Powered by a 5V 1A supply via Micro USB, the spotlight kit includes a USB cable splitter for convenient connection. Its compact size (21.5 x 55.8 x 34.4 mm) allows flexible mounting options near your camera.
"Wyze Cam V3 can watch it even better with this state-of-the-art, motion-activated, IP65 rated headlamp."
Wyze Cam V4: Advanced Camera with Built-In Lighting Features
While the Spotlight Kit is perfect for Wyze Cam V3, the newer Wyze Cam V4 models come equipped with integrated lighting solutions that enhance low light performance without additional accessories.
Enhanced Color Night Vision & Motion-Activated Spotlight
Wyze Cam V4 boasts 2.5K QHD resolution and a CMOS Starlight Sensor that captures vibrant color video even at night. It includes 4 IR LEDs and 2 white spotlight LEDs (72 lumens) that automatically activate upon motion detection, providing clear, colorful footage in low light.
Versatile Mounting and Weather Resistance
With multiple mounting options (stand, wall, ceiling, magnetic adhesive) and an IP65 weather resistance rating, Wyze Cam V4 is suitable for both indoor and outdoor use, ensuring your property is well-lit and monitored day and night.
Smart Features and Connectivity
Wyze Cam V4 supports Wi-Fi 6 for fast, reliable connections and integrates seamlessly with Alexa, Google Assistant, and IFTTT. It also offers 8x digital zoom, two-way talk, a built-in siren, and local storage options up to 512GB. Outdoor security camera with spotlight illuminating driveway at night Enhance your home security with Wyze Cam V4’s motion-activated spotlight
Wyze Cam V4 Outdoor Bundle: Complete Lighting and Security Solution
For those seeking a comprehensive package, the Wyze Cam V4 Outdoor Bundle includes the camera, an outdoor power adapter, and a 128GB microSD card for continuous local recording.
Superior Night Vision and Lighting
This bundle features Enhanced Color Night Vision and a motion-activated spotlight that brightens your outdoor spaces automatically. The wide dynamic range (WDR) ensures vibrant, clear images regardless of lighting conditions.
Robust Outdoor Compatibility
Designed for outdoor use, the bundle supports wired power for uninterrupted operation and includes weatherproof components to withstand harsh environments.
Smart Home Integration and Alerts
With Alexa and Google Assistant compatibility, plus advanced motion and sound detection, this bundle keeps you informed and in control of your home security at all times. Wyze Cam mounted outdoors with spotlight on, securing home perimeter Wyze Cam V4 Outdoor Bundle provides reliable lighting and security
Why Choose Wyze Accessory Light Kits and Cameras for Low Light Security?
  • Improved Night Vision: Whether using the Wyze Cam V3 Spotlight Kit or the built-in lighting of Wyze Cam V4, your camera captures clear, color-rich footage in darkness.
  • Motion-Activated Lighting: Lights only activate when needed, saving energy and alerting you to activity.
  • Weatherproof and Durable: IP65 rating ensures reliable performance in rain, snow, or dust.
  • Easy Installation: Flexible mounting options and simple power connections make setup hassle-free.
  • Smart Features: Integration with voice assistants and smart home platforms enhances convenience and control.
Summary of Recommended Products for Low Light Accessory Lighting
Product NameKey FeaturesPrice (USD)
Wyze Cam V3 Spotlight Kit70 lumens, motion-activated, IP65 rated$16.98
Wyze Cam V42.5K QHD, color night vision, built-in spotlight$100.00
Wyze Cam V4 Outdoor BundleOutdoor power adapter, 128GB microSD, enhanced color night vision$69.99
Enhance your Wyze Cam V3’s low light performance with the Spotlight Kit or upgrade to Wyze Cam V4 for integrated lighting and advanced security features. Both options provide excellent solutions to keep your home safe and well-lit during nighttime.
FeatureWyze Cam v3 Spotlight KitWyze Cam v4Wyze Cam v4 Outdoor Bundle
Product TypeAccessory (Spotlight Kit)CameraCamera Bundle
Price$16.98$35.98 (1 Pack)$69.99
ResolutionN/A (Accessory)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionNo (Spotlight only)Enhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated, IP65 rated headlampMotion-activated spotlightMotion-activated spotlight
Weather ResistanceIP65IP65IP65
Local RecordingN/A24/7 local recording (microSD card required)24/7 local recording (microSD card included)
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
Compatibility with Smart AssistantsN/AAlexa, Google AssistantAlexa, Google Assistant
Motion DetectionN/AYesYes
Sound DetectionN/AYesYes
Motion Detection ZonesN/AYesYes
Smoke & CO AlertsN/AYesYes
Power SourceN/AWiredWired
Outdoor CompatibilityYes (IP65 rated spotlight)Yes (IP65 rated)Yes
Included ItemsSpotlight KitWyze Cam v4 camera onlyWyze Cam v4, Outdoor Power Adapter, 128GB microSD Card
Field of ViewN/A115.9° (D) x 98.5° (H) x 53.1° (V)115.9° (D) x 98.5° (H) x 53.1° (V)
Spotlight SirenNo sirenBuilt-in sirenBuilt-in siren
WarrantyNot specified1 Year1 Year
What is the best accessory light kit for Wyze Cam V3 in low light conditions?The Wyze Cam V3 Spotlight Kit is the best accessory light kit for Wyze Cam V3 in low light conditions. It provides a 70-lumen, motion-activated spotlight that enhances night vision and security monitoring, ensuring your camera captures clear footage even in complete darkness.
How does the Wyze Cam V3 Spotlight Kit improve night vision?The Wyze Cam V3 Spotlight Kit features 5 LEDs with a 70-lumen output and a 130-degree beam. When motion is detected, the spotlight instantly illuminates the area, allowing your Wyze Cam V3 to capture clear, detailed video footage in low light or pitch-black environments.
Is the Wyze Cam V3 Spotlight Kit weatherproof?Yes, the Wyze Cam V3 Spotlight Kit is rated IP65, making it weather-resistant and suitable for both indoor and outdoor use. It can withstand rain, dust, and extreme temperatures ranging from -4°F to 131°F (-20°C to 55°C).
How do I power and install the Wyze Cam V3 Spotlight Kit?The Wyze Cam V3 Spotlight Kit is powered by a 5V 1A supply via Micro USB and includes a USB cable splitter for easy connection. Its compact size allows for flexible mounting options near your Wyze Cam V3 camera.
Does Wyze Cam V4 have built-in lighting for low light conditions?Yes, Wyze Cam V4 comes with integrated lighting features, including 4 IR LEDs and 2 white spotlight LEDs (72 lumens) that automatically activate upon motion detection. This provides enhanced color night vision and clear footage in low light without the need for additional accessories.
What are the key features of Wyze Cam V4 for night vision?Wyze Cam V4 offers 2.5K QHD resolution, a CMOS Starlight Sensor for vibrant color video at night, motion-activated spotlights, 8x digital zoom, two-way talk, a built-in siren, and local storage up to 512GB. It is also IP65 weather-resistant and supports Wi-Fi 6 for fast connectivity.
What is included in the Wyze Cam V4 Outdoor Bundle?The Wyze Cam V4 Outdoor Bundle includes the Wyze Cam V4 camera, an outdoor power adapter for continuous operation, and a 128GB microSD card for local recording. It is designed for outdoor use with weatherproof components and enhanced color night vision.
Can Wyze Cam V3 and V4 be used outdoors?Yes, both Wyze Cam V3 (with the Spotlight Kit) and Wyze Cam V4 are IP65 rated for weather resistance, making them suitable for outdoor installation. They can withstand rain, snow, dust, and extreme temperatures.
Do Wyze cameras with accessory lights support smart home integration?Yes, Wyze Cam V3 and V4 support smart home integration. Wyze Cam V4, in particular, works with Alexa, Google Assistant, and IFTTT, allowing you to control your camera and receive alerts through your preferred smart home platform.
What are the benefits of using motion-activated lighting with Wyze cameras?Motion-activated lighting with Wyze cameras improves night vision by illuminating the area only when movement is detected. This saves energy, alerts you to activity, and ensures your camera captures clear, detailed footage in low light conditions.
How much does the Wyze Cam V3 Spotlight Kit cost?The Wyze Cam V3 Spotlight Kit is priced at $16.98, making it an affordable solution to enhance your Wyze Cam V3’s performance in low light environments.
What is the price of Wyze Cam V4 and the Wyze Cam V4 Outdoor Bundle?The Wyze Cam V4 is priced at $100.00, while the Wyze Cam V4 Outdoor Bundle, which includes an outdoor power adapter and a 128GB microSD card, is available for $69.99.
Can you tell me more about the features of the Wyze Cam V4?How does the motion-activated spotlight work with the Wyze Cam V3?Do you have any deals, ongoing sales, discounts, or promotions?
