Wyze Cam v3 Motion Activated 70 Lumen Headlamp Kit for Low Light Surveillance
For those seeking reliable, motion-activated surveillance solutions in low light environments, the Wyze Cam v3 combined with the 70 lumen Spotlight Kit offers an unbeatable duo. This setup is perfect for enhancing visibility and security during nighttime or dimly lit conditions, making it ideal for home security, outdoor monitoring, or any situation where clear vision and motion detection are critical.
Wyze Cam v3: Advanced Surveillance with Night Vision
The Wyze Cam v3 is a versatile security camera designed to deliver crystal-clear video and smart features that keep your property safe around the clock.
Key Features:
- 2.5K QHD Video Resolution: Capture sharp, detailed footage at 2560x1440 pixels.
- Motion-Activated Spotlight: Integrated white spotlight LEDs (72 lumens) activate on motion detection to illuminate the scene.
- Color Night Vision: Unlike traditional IR night vision, the Wyze Cam v3 provides enhanced color night vision for better clarity in darkness.
- Wide Field of View: With a 115.8° diagonal field of view, it covers a broad area.
- Weather Resistant: Rated IP65, suitable for indoor and outdoor use.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
- Two-Way Audio & Built-in Siren: Communicate or deter intruders with 99dB siren and noise-canceling audio.
- Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for stable streaming.
- Storage: Local microSD card support up to 512GB and optional cloud storage.
This camera is perfect for low-light surveillance thanks to its CMOS Starlight Sensor and dual IR and white LED night vision system.
Wyze Cam v3 Spotlight Kit: Brighten Your Surveillance
Enhance your Wyze Cam v3’s night-time performance with the dedicated Spotlight Kit, a motion-activated headlamp designed specifically for this camera.
Spotlight Kit Highlights:
- 70 Lumens Brightness: Provides ample illumination to brighten dark areas when motion is detected.
- Wide 130° Beam Angle: Covers a broad area to complement the camera’s field of view.
- IP65 Rated: Durable and weather-resistant for outdoor use.
- Compact & Lightweight: Dimensions of 21.5 x 55.8 x 34.4 mm, easy to mount alongside your camera.
- Power Supply: Powered via 5V 1A through Micro USB connection.
- Operating Temperature: Works reliably from -4°F to 131°F (-20°C to 55°C).
- Included Accessories: Comes with the spotlight and a USB cable splitter for easy connection.
This kit is ideal for illuminating dark corners, driveways, or pathways, ensuring your Wyze Cam v3 captures clear footage even in pitch-black conditions.
Why Choose the Wyze Cam v3 with Spotlight Kit for Low Light Surveillance?
"Combining the Wyze Cam v3 with the 70 lumen Spotlight Kit creates a powerful low-light surveillance system that activates only when needed, saving energy while maximizing security."
- Motion-Activated Lighting: The spotlight only turns on when motion is detected, reducing unnecessary power use and light pollution.
- Enhanced Night Vision: The combination of white spotlight and IR LEDs ensures color and clarity in darkness.
- Weatherproof Durability: Both camera and spotlight withstand harsh outdoor conditions.
- Flexible Installation: Multiple mounting options allow you to position the camera and spotlight exactly where you need them.
- Affordable Security: This kit offers professional-grade surveillance features at a budget-friendly price.
Lifestyle Image
Enhance your home security with motion-activated lighting and clear night vision.
Summary
For low light surveillance needs, the Wyze Cam v3 paired with the 70 lumen Spotlight Kit is an excellent choice. This combination offers high-resolution video, motion-activated illumination, and robust weather resistance, ensuring your property stays secure day and night. Whether monitoring your front porch, backyard, or any dimly lit area, this kit provides peace of mind with smart, responsive security technology.
What is the Wyze Cam v3 Motion Activated 70 Lumen Headlamp Kit?
The Wyze Cam v3 Motion Activated 70 Lumen Headlamp Kit is a surveillance solution that combines the Wyze Cam v3 security camera with a 70 lumen Spotlight Kit. This setup is designed for low light environments, providing motion-activated illumination and high-resolution video to enhance visibility and security during nighttime or in dimly lit areas.How does the Wyze Cam v3 perform in low light conditions?
The Wyze Cam v3 excels in low light conditions thanks to its CMOS Starlight Sensor, color night vision, and dual IR and white LED night vision system. When paired with the 70 lumen Spotlight Kit, it provides clear, color footage even in pitch-black environments.What are the key features of the Wyze Cam v3?
Key features of the Wyze Cam v3 include 2.5K QHD video resolution (2560x1440 pixels), motion-activated 72 lumen spotlight, color night vision, a 115.8° wide field of view, IP65 weather resistance, multiple mounting options, two-way audio with a 99dB siren, support for 2.4 GHz Wi-Fi and Wi-Fi 6, and local microSD card storage up to 512GB.What does the Wyze Cam v3 Spotlight Kit offer?
The Wyze Cam v3 Spotlight Kit provides 70 lumens of brightness with a wide 130° beam angle, enhancing the camera’s night-time performance. It is IP65 rated for outdoor durability, compact and lightweight, and powered via a 5V 1A Micro USB connection. The kit includes a spotlight and a USB cable splitter for easy installation.Is the Wyze Cam v3 with Spotlight Kit weatherproof?
Yes, both the Wyze Cam v3 and the Spotlight Kit are IP65 rated, making them weather-resistant and suitable for both indoor and outdoor use, even in harsh conditions.How is the spotlight activated on the Wyze Cam v3?
The spotlight on the Wyze Cam v3 is motion-activated. It automatically turns on when motion is detected, providing illumination only when needed to save energy and reduce light pollution.What are the installation options for the Wyze Cam v3 and Spotlight Kit?
The Wyze Cam v3 and Spotlight Kit offer flexible installation options, including stand, wall, ceiling, or magnetic mounts. This allows you to position the camera and spotlight exactly where you need them for optimal coverage.What storage options are available for the Wyze Cam v3?
The Wyze Cam v3 supports local storage via a microSD card up to 512GB and also offers optional cloud storage for video recordings.What is the operating temperature range for the Wyze Cam v3 Spotlight Kit?
The Wyze Cam v3 Spotlight Kit operates reliably in temperatures ranging from -4°F to 131°F (-20°C to 55°C), making it suitable for various climates.Why should I choose the Wyze Cam v3 with Spotlight Kit for home security?
The Wyze Cam v3 with Spotlight Kit offers professional-grade surveillance features at an affordable price. It provides high-resolution video, motion-activated lighting, enhanced night vision, weatherproof durability, and flexible installation, making it an excellent choice for securing your property in low light conditions.
