Motion Activated Outdoor Lighting Solutions for Wyze Cam Cameras
When it comes to securing your home with smart, motion-activated outdoor lighting, Wyze offers a range of innovative cameras designed to illuminate and protect your property effectively. Whether you want powerful floodlights with AI detection or a discreet bulb cam that fits into existing fixtures, Wyze has the perfect solution tailored for your outdoor security needs.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable
Powerful Illumination and Clear Video
The Wyze Cam Floodlight v2 is engineered to dominate the dark with
2800 lumens of bright LED light and a
2K resolution camera featuring Color Night Vision. Its
160° wide-angle view ensures broad coverage of your outdoor spaces, capturing every detail with clarity.
Intelligent Features for Enhanced Security
- AI-Powered Light Control automatically adjusts lighting based on detected motion.
- Dusk-to-Dawn Automation ensures your property is lit only when needed.
- Two-Way Talk lets you communicate directly through the built-in speaker and microphone.
- 105dB Siren adds an audible deterrent to unwanted visitors.
- Supports 24/7 local recording with up to 256GB microSD card storage.
Durable and Weather Resistant
With an
IP65 rating, the Floodlight v2 withstands rain, snow, and extreme temperatures from -4°F to 140°F, making it perfect for year-round outdoor use.
Experience seamless integration with Alexa, Google Assistant, and IFTTT for smart home automation.
Alt text: Wyze Cam Floodlight v2 lighting a driveway with motion detection at night
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Wide Coverage
Superior Video and Lighting Performance
The Wyze Cam Floodlight Pro steps up the game with a
2.5K QHD camera and an expansive
180° diagonal field of view. Its
3000 lumens of brightness from three dimmable LED panels provide exceptional illumination for large outdoor areas.
Smart AI Motion Detection
- Uses onboard AI computer vision to detect specific objects like people and vehicles.
- Lights activate only for selected motion types, reducing false alarms.
- Dual-band WiFi (2.4 & 5 GHz) ensures stable connectivity.
Robust Outdoor Durability
Rated
IP65 water resistant, it operates reliably in temperatures from -4°F to 140°F. The built-in
105dB siren and two-way audio enhance your home security system.
The Floodlight Pro is ideal for those who want a high-powered, intelligent security camera with bright, responsive lighting.
Alt text: Wyze Cam Floodlight Pro installed outdoors with woman and dog
Wyze Bulb Cam: Discreet Motion-Activated Lighting and Security
2-in-1 Security Camera and Smart LED Bulb
The Wyze Bulb Cam combines a
2K HD camera with a smart LED bulb that fits into standard E26 sockets. It delivers up to
800 lumens of light with a warm
3000K color temperature, perfect for porch lights or outdoor fixtures.
Convenient and Easy Installation
- Installs easily in most outdoor light fixtures.
- Motion-activated lighting and instant alerts keep you informed.
- Supports local storage up to 256GB microSD card without subscription.
Weatherproof and Smart
With an
IP65 rating, the Bulb Cam is built to withstand outdoor conditions. It also supports two-way audio and color night vision for clear video day and night.
Ideal for users seeking a subtle, easy-to-install outdoor lighting camera solution.
Alt text: Wyze Bulb Cam installed in outdoor light fixture
Wyze Cam v4: Compact, Motion-Activated Spotlight Camera
High-Resolution Video and Enhanced Night Vision
Wyze Cam v4 offers
2.5K QHD video with
Enhanced Color Night Vision and a
115.8° diagonal field of view. Its built-in
motion-activated spotlight brightens your yard instantly when movement is detected.
Versatile Mounting and Connectivity
- Multiple mounting options including wall, ceiling, and magnetic mounts.
- Supports Wi-Fi 6 for faster, more reliable connections.
- Two-way audio and a loud 99dB waterproof speaker for communication and deterrence.
Weather Resistant and Durable
Rated
IP65, it performs well in outdoor environments from -4°F to 122°F, making it a versatile choice for both indoor and outdoor security.
Perfect for those who want a compact, powerful camera with motion-activated lighting and smart home compatibility.
Why Choose Wyze Motion Activated Outdoor Lighting?
Wyze’s outdoor lighting cameras combine
bright, motion-activated LEDs with
high-resolution video and
smart AI features to provide comprehensive home security. Whether you want the powerful illumination of the Floodlight series or the subtlety of the Bulb Cam, Wyze offers reliable, weather-resistant solutions that integrate seamlessly with your smart home ecosystem.
Protect your home day and night with Wyze’s intelligent outdoor lighting cameras — designed to keep you safe, informed, and in control.
What are the main features of the Wyze Cam Floodlight v2 for outdoor security?
The Wyze Cam Floodlight v2 offers 2800 lumens of bright LED light, a 2K resolution camera with Color Night Vision, a 160° wide-angle view, AI-powered light control, dusk-to-dawn automation, two-way talk, a 105dB siren, and supports 24/7 local recording with up to 256GB microSD card storage. It is IP65 rated for weather resistance and integrates with Alexa, Google Assistant, and IFTTT.How does the Wyze Cam Floodlight Pro enhance outdoor security?
The Wyze Cam Floodlight Pro features a 2.5K QHD camera, a 180° diagonal field of view, and 3000 lumens of brightness from three dimmable LED panels. It uses onboard AI computer vision to detect people and vehicles, reducing false alarms. The device supports dual-band WiFi (2.4 & 5 GHz), has a 105dB siren, two-way audio, and is IP65 water resistant for reliable outdoor use.What makes the Wyze Bulb Cam a discreet outdoor lighting solution?
The Wyze Bulb Cam combines a 2K HD camera with a smart LED bulb that fits into standard E26 sockets, providing up to 800 lumens of warm 3000K light. It installs easily in most outdoor fixtures, offers motion-activated lighting, instant alerts, local storage up to 256GB microSD card, two-way audio, color night vision, and is IP65 rated for weatherproof performance.What are the benefits of the Wyze Cam v4 for outdoor motion-activated lighting?
Wyze Cam v4 delivers 2.5K QHD video, enhanced color night vision, a 115.8° diagonal field of view, and a built-in motion-activated spotlight. It offers versatile mounting options, supports Wi-Fi 6 for fast connectivity, two-way audio, a 99dB waterproof speaker, and is IP65 rated for durability in outdoor environments.Are Wyze outdoor lighting cameras weather resistant?
Yes, all Wyze outdoor lighting cameras, including the Floodlight v2, Floodlight Pro, Bulb Cam, and Cam v4, are IP65 rated. This means they are designed to withstand rain, snow, and extreme temperatures, making them suitable for year-round outdoor use.Do Wyze motion-activated outdoor cameras support local video storage?
Yes, Wyze outdoor cameras such as the Floodlight v2, Bulb Cam, and others support local video storage with microSD cards up to 256GB, allowing for 24/7 recording without a subscription.Can Wyze outdoor lighting cameras be integrated with smart home systems?
Yes, Wyze outdoor lighting cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, enabling seamless automation and voice control.What types of motion detection do Wyze outdoor lighting cameras offer?
Wyze outdoor lighting cameras use advanced AI-powered motion detection to identify specific objects such as people and vehicles, reducing false alarms and ensuring lights activate only for relevant motion events.How easy is it to install Wyze outdoor lighting cameras?
Wyze outdoor lighting cameras are designed for easy installation. The Bulb Cam fits into standard E26 sockets, while other models offer versatile mounting options including wall, ceiling, and magnetic mounts, making setup straightforward for most users.Why should I choose Wyze motion-activated outdoor lighting solutions?
Wyze motion-activated outdoor lighting solutions combine bright LED illumination, high-resolution video, smart AI features, weather resistance, and seamless smart home integration to provide comprehensive and reliable home security for any outdoor space.
